Factory Reset Samsung S10 without Password [4 Ways]
Struggling to reset your Samsung S10 to factory settings but can’t remember the password associated with the device? Apply any of the 4 solutions provided in this post to wipe your Samsung device today.
Author Avatar Joy Taylor Last Updated: Aug. 22, 2024
DroidKit – Factory Reset Samsung S10 without Password in Minutes
How to reset Samsung Galaxy S10 that is locked? Just free download DroidKit to 1-click reset and unlock your Samsung Galaxy S10 device. It unlocks all screen locks like Touch/Face ID, passcode, pattern, etc. All Android devices like Samsung, Huawei, LG, etc. can be reset and unlocked by DroidKit.
How to Factory Reset Samsung S10 without Password
Whether you want to sell or just got a second-hand Samsung S10 smartphone, factory reset will come in handy for you to clear or wipe out the data on the device. Mind you, for a successful factory reset process, you must have the Google FRP password associated with the device.
But if for any reason you cannot recollect your Google FRP credentials, this write-up is for you. Here, we have a comprehensive guide covering all the available solutions that you can follow to reset your Samsung S10 without password. Let’s get started!
Further Reading: How to fix Samsung S10 black screen
Must Know About Samsung S10 Factory Reset
Before the solutions/techniques to reset a Samsung S10 smartphone to factory settings, here are some things you should know:
  • Factory reset often leads to the sudden loss of all data files from the corresponding device. So make sure you’ve successfully backed up your data before subjecting your device to factory reset.
  • Kindly charge the device to ~50% or more, so it doesn’t go off during restoration.
Once the aforementioned keynotes have been put in place, you can proceed to factory reset your Samsung S10.
There are 4 Ways to Factory Reset Samsung S10 without Password. Employ any techniques down here to reset your Samsung S10 device without entering a password.
1. Factory Reset Samsung S10 With DroidKit
The best way to perform Samsung S10 factory reset without password when locked is to use a professional tool like DroidKit – Android Phone Toolkit. With the help of DroidKit, you can successfully reset your Samsung device to default mode without a password. And it resets your device without crashing your operating system.
What Is DroidKit
DroidKit is a complete Android solution toolkit that can solve many of your problems like resetting a phone that is locked, unlocking Google locked phone, extracting data from a broken phone, Google account, or SIM card, Android data recovery, etc. You can use this software on a Windows PC or Mac computer. DroidKit provides you with an Android lock screen removal tool. No matter whether your Samsung s10 is locked by a numeric password/PIN/pattern/fingerprint, or Samsung won’t accept your password, you can reset your Samsung and remove the lock screen.
Key Features
  • Unlock any type of screen lock, including a password, pattern, PIN, face ID, fingerprint, etc.
  • Supports Samsung phones & tablets, and any other Android models like Motorola, Sony, etc.
  • Your privacy is 100% safe with the protection of SSL-256 encryption.
  • Resets your Samsung S10 to factory settings in a few seconds without data loss.
  • No skills, or technical knowledge is required, and no root on the device. You can perform by yourself and on your own computer.
  • One-stop Android repair solution; for data recovery, unlock Samsung FRP without Google Account, system fixing, data management and more.
Free get DroidKit now and follow the guide to Reset Samsung S10 without Password:
How to Factory Reset Samsung S10 without Password with DroidKit:
Step 1. Download DroidKit on your PC > Launch it and choose Screen Unlocker mode.
Choose Screen Unlocker
Step 2. Connect your phone and click Start. After the configuration file is prepared, tap on Remove Now.
Click Remove Now Button
Step 3. Select the device brand (Samsung) you need and tap on Next to unlock and continue the process.
Step 4. Follow the onscreen guide that appears to enter recovery mode on the Samsung S10 phone.
Finish Settings on Samsung
DroidKit will reset your device automatically. Wait until the process is completed, you will get the Screen Lock Removal Completed page. And, your phone is reset to factory resetting.
Lock Screen Removal Completed
2. Factory Reset Samsung S10 via Find My Device
Like Apple, Samsung also has the Find My Device feature integrated into its smart devices, including the Samsung S10. The feature is designed specifically to help you track your device in case it goes missing.
You can also bank on it to help you reset or erase your device. However, there are certain preconditions you must fulfill to achieve this. Find them below:
  • The Find My Device must be enabled on the corresponding Samsung S10.
  • Ensure you still have the password to the Samsung account associated with the Samsung device. If you can’t, try resetting it before you proceed with this solution.
Should you meet all the conditions above, follow the detailed instructions below to reset your Samsung s10 to factory mode:
1: Go on the official website for Samsung and log in to the Samsung credentials associated with your device. Follow the onscreen prompts to verify your identity if you have 2FA linked to your account.
2: Once you’ve gained access to your Samsung account, the screen down here will come up:
Locate your device on the left sidebar. Tap on Settings, and select Devices from the options that appear.
3: Next, tap on Erase Data, and a drop-down menu will come up. Click not the Erase data icon to proceed.
4: Now you will be directed to a new window labeled, Erase Phone data. Click on Erase to automatically wipe your Samsung S10 remotely.
Click on Erase to Automatically Wipe  Samsung S10 Remotely
3. Factory Reset Samsung S10 in Recovery Mode
Here is another straightforward solution you can apply to reset your Samsung S10 to default settings right from the comfort of your home. Like the Find My Device solution,  this one also clears your entire mobile system. So we advise that you backup your data before employing the solution.
Follow the stepwise guide below to reset your Samsung S10 to factory settings without a password via recovery mode:
Step 1: Using the appropriate keys, turn off your Samsung S10 smartphone. Once done, press down the following buttons simultaneously:
  • Volume Down
  • Power
Step 2: Next hold down the Power + Home + Volume Down buttons concurrently. Keep holding unto these keys until your device starts vibrating.
hold Down the Power + Home + Volume Down Buttons Concurrently
Step 3: Should everything go well in step 2, a No Command message will automatically pop up, and your device will enter recovery mode in no time.
Step 4: Now that you are on the recovery mode screen, use the Volume Up or Volume Down button to scroll through the options appearing on your screen. Navigate to Factory Reset, and tap the Power button to activate it.
Step 5: Another screen should come up with the prompt requesting whether or not you want to delete all user data. Kindly tap on Yes- Delete All User Data
Step 6: Wait for the factory reset to complete, then tap on Reboot system now to restart your device. Once the device comes up, kindly follow the onscreen guide to reconfigure it.
4. Factory Reset Samsung Galaxy S10 Using Android Device Manager
Android Device Manager can also be an option. To factory reset Samsung s10, you can alternatively use Android Device Manager; follow the instructions to find out how:
  • Visit android.com/find and log in with the Google Account that is synced on your locked Android to find it.
  • Select “Erase Device” after selecting the device you want to delete at the top of the screen.
Select Erase Device on Google Find My Device
  • Select “Erase Device” once more, and then login into your Google Account once more.
  • After selecting “Erase all data,” click “Erase” in the menu that displays and wait for the wiping and resetting procedure to be complete.
Tips for Factory Reset Samsung S10
1. How to Change Password on Samsung S10?
Changing the password on a Samsung S10 is a straightforward process. After successfully bypassing the lock screen, you may need to set a password on your Samsung S10.
  • Unlock your Samsung S10 and navigate to settings, followed by “Lock Screen.”
  • Then, select “Lock Screen Type.”
  • On-screen lock type, select password lock system, and configure it, then click “Done” to save your settings.
2. Samsung Phone Locked after Factory Reset?
Sometimes factory reset can go wrong and your Samsung phone gets locked automatically. When such happens, you lose access and full control of the device. If you are currently faced with such issues, you need not panic.
DroidKit is a great Android utility that you can count on to help you fix such an issue. The software isn’t limited to screen unlock. It also lets you bypass screen locks and other related issues without stress. It’s one of the most efficient Android repair tools.
Resetting your Samsung S10 without it a password shouldn’t be a challenge anymore with this tutorial guide at your disposal. We have 4 official solutions to reset your Samsung device to default mode without entering your credentials. Which do you wish to use?
We recommend that you choose the DroidKit solution for quality results. The software resets your device to factory settings without password smoothly with no data loss. So just follow the steps above to solve how to reset Android phone when locked with DroidKit now>>
