How to Factory Reset LG Phone without Password
Learn how to reset a LG phone that is locked by scrolling this handy guide. This page provides 5 ways to reset LG phone without password, including hard reset with master code, buttons, and bypass tools.
Author Avatar Joy Taylor Last Updated: Dec. 13, 2023
DroidKit – How to Factory Reset LG Phone when Locked Out
How to factory reset LG phone, especially when you forget the password? DroidKit allows you to unlock and reset your device in simple clicks. No matter your LG phone is locked by a numeric password, pattern, fingerprint, etc. It supports all LG phones running Android 5 and above.
If you are locked out of your LG phone, you may need to factory reset LG phone to bypass the lock screen. A factory reset, often known as a master reset, is a way of restoring any electronic device to its original settings. During this process, all information stored in the device will be reset to its original manufacturer’s settings, including your lock code. Besides, a factory reset is also the best choice to save your phone from a virus, or when you need to sell your phone to protect personal data.
Here, we will focus on how to reset a LG phone that is locked, even when LG hard reset not working on your phone.
How to Reset LG Phone with LG Master Reset Code
You can usually factory reset LG phone via Settings > General > Backup & reset > Factory data reset > Click Reset phone to confirm. This will erase all data from your phone’s internal storage, including your Google account, app data, photos, settings, etc.
While, if you are locked out of your phone, you can also use the LG master reset code to reset the majority of the gadgets on the market. This is a perfect option for you to hard reset without a password. Here is how to reset an LG phone via LG master reset code without password.
To factory reset a locked LG:
  1. Press the emergency dialer button. Most devices would have their own icon or the word Emergency description. It will launch a rudimentary dialer from which you can make a few emergency calls.
  2. To factory reset your device, dial 2945#*# or 1809#*101#. Most of the time, these codes will work and reset your device. If it doesn’t work, dial #668 while pressing the power button at the same time.
  3. The code may also differ from one model to the next. However, you may always call *#*#7780#*#* as it is compatible with the majority of Android devices.
Reset LG with Emergency Code
That’s all! It will simply and painlessly reset your phone. You may also use these key combinations to learn how to unlock an LG Tracfone/Stylo, etc. when it is locked.
How to Reset A LG Phone That Is Locked in Clicks
If your LG hard reset not working, you can factory reset LG phone without password via DroidKit, a one-stop Android toolkit. No matter if you forgot a numeric password, PIN code, pattern or fingerprint, etc., you can reaccess the phone with DroidKit. All you need to do is click the buttons, and then your device will be unlocked and reset in minutes. Moreover, DoirdKit can also help you bypass FRP lock/Google account, fix common system issues, recover lost data, manage your files on your device, etc.
DroidKit – Reset LG Phone without Password/PIN/Pattern
It is software that allows you to unlock any lock code on any Android phone and tablet. No matter you own LG Tracfone, LG K51, LG G4, etc., you can bypass the lock screen without root. No technical knowledge is required either.
Steps to Factory Reset LG Phone When Locked Out:
Step 1: Download and Install the DroidKit. Once done, launch it and tap on the Screen Unlocker mode.
Choose Screen Unlocker
Step 2: Connect your device and tap on the Start button.
Connect your Locked Phone
Step 3: Once the configuration file is prepared for your Android device, simply tap on Remove Now.
Click Remove Now Button
Step 4: To confirm, select your device’s brand and click on Next button.
Step 5: Set your phone and remove the screen password by following the steps below.
Finish Settings on LG
Step 6: After the screen lock removal process is completed as below, you will be able to access your Android device without providing a password.
Lock Screen Removal Completed
Also Read: How to Reset LG Phone without Google Account >
How to Factory Reset A LG Phone That Is Locked via Buttons
If you want to learn how to reset LG phone without password, you may always boot it into recovery mode and do a factory reset. Needless to say, after executing the factory reset, your phone will be completely reset and will function as if it were a brand-new device. Recovery mode allows you to do a variety of activities including wiping data, rebooting system, rebooting to bootloader, partitioning, and more.
Follow the straightforward method to see how to reset a LG phone that is locked with side buttons:
  1. Make sure your device is turned off before you begin. If it isn’t, tap the Power button to turn it off.
  2. Hold down the Power, Home, and Volume Up buttons on your phone for at least 10 seconds. For some LG models, the key combination is also Power + Volume Down.
  3. When your phone enters Recovery Mode, press the Volume Up/Down keys to get to the wipe data/factory reset option. To select it, press the Power key.
    Wipe Data and Factory Reset your Device
  4. On the next screen, pick the Yes option to confirm your selection.
  5. Wait a few moments for your LG phone to be restored. Finally, choose to restart your device in normal mode.
Confirm to Delete All User Data
After you reset your phone, it will restart without a screen lock. However, all saved data on your LG device will be lost in the process.
How to Factory Reset LG Phone without Password via Find My
If LG hard reset not working, you can also use Find My Device, which is a free utility offered by Google. You can use it to remotely erase your phone, ring it, lock it when you lost it, or even find your lost phone. That is to say, no matter whether your phone is lost or not, Google Find My Device is a good way for you to erase all data on your phone, factory reset the code to unlock it, etc.
Follow these instructions to learn how to reset a LG phone that is locked:
Step 1: Navigate to the Find My Device official website using any phone or computer.
Step 2: Log in to your Google account using the correct credentials. Always make sure that this account is already associated with your locked LG phone.
Sign in Google Account
Step 3: Choose your LG phone from the list of connected devices. This will load its current location automatically.
Step 4: Now, tap on the Erase option on the left.
Tap on Erase
Tap on Erase
Step 5: It will confirm your selection and wait for a few moments before resetting your locked LG phone.
This will restart your phone and remove the existing lock. However, you must first have the Google credentials for the associated account. In order for this solution to operate, your LG device must be connected to the internet.
Also Read: Unlock an Android Phone Locked by Google’s Find My Device >
How to Bypass LG Lock Screen without Reset
When you are locked out of LG phone and enter the false pattern 5 times, you can bypass the lock screen without reset with the below steps:
Step 1: Click Forgot Pattern on the bottom-right corner of your lock screen.
Step 2: Choose Enter Google account details and Next. (You can also choose the Answer question to unlock with security question.)
Step 3: Enter your Google account and password and you can set a new pattern lock later.
These are the proven ways on how to factory reset an LG phone. And we highly recommend you try DroidKit first. It will unlock all Android screen locks without causing any damage, like rooting a phone. Give it a shot, and you’ll never have to deal with an unpleasant situation like a locked or disabled any Android phone again. Now, just follow the guide above to solve how to reset a LG phone that is locked.
