“Anyone has tried easy samsung frp tool for bypassing Samsung Google account? I learnt about this tool online but I don’t know if it’s worth trying. Can you recommend?” – A Samsung user asked in the forum. If you have the same questions, read the following content and understand the features of Easy FRP Tool.
Find it difficult to use the Easy Samsung FRP Tool? No worries, DroidKit allows you to bypass FRP on Samsung without technical skills or complex operations. It is the best alternative to the Easy Samsung FRP Bypass Tool.
Stuck on the Samsung phone FRP (Factory Reset Protection) after performing a factory reset? No worries! Easy Samsung FRP Tool can help you bypass this lock and regain access to your device. However, if you want something more versatile, we present you with the ultimate DroidKit. In this guide, you will be able to learn how to download and use the Easy Samsung FRP Tool V2.7 and a reliable alternative. So, let’s start to explore this in detail!
Also Read: FRP Bypass Apks for Samsung Phones
Easy Samsung FRP Tool is a reliable and easy-to-use program that helps users get around the Factory Reset Protection (FRP) lock on Samsung smartphones. The latest version is Easy Samsung FRP Tool V2.7. It is recognized that upon a device reset, the Google account linked to this device must be entered to access the FRP security feature. If you purchase a used smartphone with the FRP lock active or have forgotten your Google login credentials, this easy-to-use program will help you get back in.
Key Features:
Yes, Easy Samsung FRP Tool is free to use on Windows computer. That’s why Samsung users wonder how Easy Samsung FRP Tool helps to bypass FRP on their phones or tablets. However, it’s important to note that while the tool itself is free, using it may require certain technical steps, such as disabling driver signature enforcement on your computer and temporarily turning off antivirus software to ensure proper functionality.
Yes, Easy Samsung FRP Tool is safe to use as long as you download it from a trusted website. Without official Samsung validation, it works smoothly and doesn’t cause glitches or security problems. However, if you download it from unrecognized websites, the utility might contain a virus or other unwanted programs. If feasible, unlock your device via official, safer techniques or with expert help. Here are some precautions to follow:
If you need to bypass the FRP lock on your Samsung device, downloading the Easy Samsung FRP Tool V2.7 is a quick and reliable solution. Below, you will learn how to download and use the Easy Samsung FRP Tool V2.7 to unlock your device.
Download Samsung FRP Tool V2.7
For downloading the Samsung FRP Tool V2.7:
Here, you can download the latest update of the Easy Samsung FRP Tool from the official website.
● File Name: Easy_Samsung_FRP_2020_V1.zip
How to Use Easy Samsung FRP Tool V2.7?
Step 1. Download the Easy Samsung FRP Tool 2024 and save it to your PC.
Step 2. Unzip the file by 7-Zip or WinRAR.
Step 3. Run the setup by double-clicking on SamsungFrp. exe.
Step 4. Click on “Disable Driver Signature Enforcement” and restart your computer.
Step 5. Reconnect your Samsung phone to the computer and ensure it’s connected to a good Wi-Fi network.
Step 6. Open the setup file again and click “Bypass FRP.” Wait for the process to complete, and if a driver installation popup appears, click “Install this driver software anyway.”
Install Easy Samsung FRP Tool V2.7
Step 7. On your phone, follow the prompts in the Easy Firmware popup. A Chrome browser will open—type in https: // tiny.cc / frptools to download the FRP bypass APK. Install and open the app, select “Bypass FRP,” go to “Settings,” then “Security,” and set up a pattern lock. Reboot your phone to complete the process.
As Easy Samsung FRP Tool requires complicated operation steps on both your PC and the phone, some users feel it difficult to follow the instructions for FRP bypass. No worries, the best alternative to Easy Samsung FRP Tool – DroidKit is available to use with easy steps. It’s more than an FRP bypass tool. DroidKit provides an overall solution to Android screen unlock, data recovery, system repair, and more.
Key Features:
Now, let’s explore the simple steps to use DroidKit FRP bypass:
Step 1. Get DroidKit installed on your Windows or Mac computer.
Step 2. Access DroidKit and choose the “FRP Bypass” option from the menu.
Choose FRP Bypass Mode
Step 3. Attach your Samsung phone to the computer using a USB cable. Click on “Start” and select your device brand.
Choose Device Brand
Step 4. The tool will prepare a configuration file for your device. Once it’s ready, click “Start to Bypass.”
Click Start to Bypass
Step 5. Choose the Android version of your device. Once done, click “Next” button to continue. Follow the on-screen instructions to complete the phone setup.
Step 6. DroidKit will begin bypassing the FRP lock. When done, you will get a confirmation text.
FRP Bypass Complete
Here is the comparison chart that you can check the main features of DroidKit and Easy Samsung FRP Tool.
Freatures | DroidKit | Easy Samsung FRP Tool |
Ease of Use | Operates on the computer only. No technical skills are required. | Operates on both the computer and your phone. Technical skills are required. |
Supported OS | Windows and Mac | Windows only |
Supported Android Devices | Samsung devices running Android 5.1-13. | Samsung, Xiaomi, Redmi, POCO, Sony, Oppo, Vivo, Motorola, Realme and Lenovo running Android 5.1-15. |
Updates | Regular updates every month. | The latest version 2.7 was released in 2021. |
In conclusion, navigating FRP locks on Samsung devices can be challenging, but several effective tools can assist with the process. We’ve explored the Easy Samsung FRP Tool, highlighting its key features and usability of version 2.7. In addition, DroidKit is recommended as the best alternative to Easy Samsung FRP Tool for those seeking an effective FRP bypass solution. It enables you to bypass Samsung FRP without a password and is compatible with the latest Android devices (Android 15). Don’t hesitate to try it out now.
