How to Bypass OPPO FRP Lock with/without PC
If you have forgotten your Google account credentials and factory reset your OPPO phone, you will be locked out due to FRP lock. This article discusses tried and tested methods for OPPO FRP bypass.
Author Avatar Joy Taylor Last Updated: Apr. 15, 2024
DroidKit – Top OPPO FRP Bypass Tool
If you are locked by OPPO FRP, don’t panic. Free download DroidKit – Complete Android Toolkit to bypass Google account/FRP lock on OPPO in no time. It is easy to operate and supports Android 6 and above versions.
Whether you have tried resetting your OPPO phone and forgotten your Google account credentials or bought a pre-loved phone, you will have a hard time bypassing the FRP lock.
However, if you’re having trouble dealing with the OPPO FRP lock, don’t worry! This guide will walk you through the process of OPPO FRP bypass.
From using emergency FRP codes to exploring alternative techniques, we’ve got all the tricks up our sleeves. By the end of this article, you’ll breeze through bypassing the OPPO FRP lock with or without PC and gain access to your device in no time. So, let’s get started!
Further Reading: How to Unlock Android Phone if Forgot Pin>>
OPPO FRP Bypass with PC in Simple Clicks [SAFE & EASY]
If you’re stuck on the FRP lock on your OPPO phone, you’re not locked out of your device for good! A safe way to bypass OPPO FRP lock is to use a professional Android unlocker like DroidKit – Android Phone Toolkit. With this software, you can quickly get rid of FRP lock/Google Accounts on your device without entering passwords.
With this tool, you can bypass OPPO FRP lock with easy clicks on you PC/Mac. And DroidKit also stands out as it offers different FRP bypass solutions according to the your OPPO phone models and system versions, ensuring the highest success rate. In addition to OPPO, it also bypass FRP on Samsung, Xiaomi, Redmi, POCO, Realme, etc.
Key Features:
  •  It only takes a few minutes to bypass FRP. This means you don’t have to spend days waiting for a technician to solve this problem for you.
  •  If you have forgotten your Google account password, DroidKit FRP Lock Bypass can help you bypass FRP Lock without a Google account.
  • This tool uses the most advanced encryption technology to ensure that your privacy will not be leaked during the whole process. 100% safe.
  • DroidKit has powerful functions, it can also help you unlock your Android device, upgrade your system, fix underlying system errors, and recover your lost but important data like photos, contacts, messages, WhatsApp data, etc.
Now that you know what DroidKit FRP bypass can help you with, free get DroidKit now>> and have a look at how to use it to complete OPPO FRP bypass.
Step 1. Download and Install DroidKit on your PC > Launch it and choose FRP Bypass mode.
Choose FRP Bypass Mode
Step 2. Connect your device to your PC > Click on the Start button > Choose OPPO as your device brand.
Choose Device Brand
Choose Device Brand
Step 3. Then, DroidKit on detecting your device will quickly prepare a configuration file to fix it > Click on Start to Bypass
Click Start to Bypass
Step 4.  Set up your phone according to the on-screen instructions, including wiping the cache partition.
Follow the Steps on Oppo
Follow the Steps on OPPO
Step 5. After completing the steps above, the device will be restarted and the FRP Lock will also removed successfully.
FRP Bypass Complete
FRP Bypass Complete
OPPO FRP Bypass without PC via OPPO FRP Code
How to bypass OPPO FRP without PC? One of the quickest ways to bypass OPPO FRP lock is by using the emergency OPPO FRP bypass code. For this method, you need to enter the code using the “Emergency Call” option on your Oppo device to unlock it. Then, what is the FRP bypass code for OPPO? And how to bypass OPPO FRP Lock with OPPO FRP code? Here are the steps for OPPO FRP bypass in this way.
  1. Turn on your OPPO device, connect it to a Wi-Fi network, and select the “Emergency Call” option.
  2. Now dial *812# or *813# and tap “Ok.” Wait until you see the home screen.
    Dial Emergency OPPO FRP Code
  3. Go to “Settings > About” and click the OS Version 7 times until you enter “Developer Mode.”
  4. Return to “Settings > Developer Options > Enable OEM Unlocks.”
  5. Go back to “Settings > Extra Settings > Reset Options > Erase All Data.”
This will reset your OPPO phone with all data erased, and you can access it as usual.
How to Bypass OPPO FRP Lock with FRP Bypass APK
If you don’t know the OPPO FRP Code or the previous method doesn’t work, you can still bypass the FRP lock using an FRP Bypass APK. This method is a bit technical; therefore, attempt it only if you have some tech knowledge. Here is how to bypass FRP on OPPO.
1. Connect your OPPO phone to a Wi-Fi network.
2. Tap the arrow next to the Wi-Fi network and select the “Manage Network Settings” option.
Tap Manage Network Settings
3. Next, tap on “Static IP > IP Address.”
Tap on Static IP
Tap on Static IP
4. Type anything randomly in the space for the IP address, and long-press it until you see the “Web Search” option.
5. Search for “FRP Bypass APK” and download and install it.
6. Now, launch FRP Bypass APK, and go to “Settings > Try.”
7. Go to “Fingerprints, Face, and Password > Screen Lock > Pattern” and set a new pattern for your device.
8. Go back to the main page and enter your new lock screen pattern.
9. When you come across the FRP lock, tap on “Skip” to bypass it.
And that’s how you can bypass FRP lock without OPPO FRP code quickly and easily.
Sometimes, your phone is not locked by FRP Lock, but by screen locks. If you forget your OPPO phone’s screen lock password, then the next solution is for you!
What Is OPPO FRP Code?
What is the Google FRP code? What is the FRP bypass code for OPPO? OPPO FRP Code refers to a specific code used to bypass the FRP lock on OPPO devices. It is a powerful security system designed by OPPO, specifically for smartphones running Android version 5.1 or above.
Its purpose is to keep your OPPO smartphone safe from unauthorized access. This feature requires you to sign in using the Google account associated with your device. So, even if your OPPO phone is lost or stolen, the FRP lock prevents anyone from accessing it without signing in with the synced Google account.
Even if someone tries to perform a factory reset, they’ll hit a roadblock. As a result, your OPPO device remains secure, ensuring your peace of mind.
In this guide, we have put together 3 different methods to bypass OPPO FRP lock with and without PC. We hope they come in handy if you ever get locked out of your device.
And if you’re looking for the safest and most reliable way for OPPO FRP bypass, DroidKit should be your go-to option due to its convenience, high success rate and high compatibility. Try DroidKit for free now!
