How to Bypass LG Lock Screen without Reset [2025]
If you forgot the password of your LG phone, how to unlock LG phone forgot password without resetting? Just read this article through and find a way to bypass LG lock screen immediately. All LG models are supported, including LG g6/g5/stylo 6, etc.
Author Avatar Joy Taylor Last Updated: Feb. 19, 2025
DroidKit – Bypass LG Lock Screen in 1 Click
How to bypass LG lock screen, if you forgot the password? Free download DroidKit to unlock all LG screen locks, like numeric passcode, Face ID, fingerprint, PIN, pattern, etc. Just click the buttons to unlock and no skills are needed. Supports all LG device models, like LG stylo 6, k51, g6, etc.
There are times when you forget the password of your LG phone, and as a result, you are locked out of the phone which stops you from accessing the data on it. So, if you are facing the same issue on your smartphone and want to know how to unlock LG phone forgot password without resetting, then this guide is for you!
Here, we have compiled a list of workable solutions that will help you unlock LG phone forgot password. And whether you are using LG g6, LG g5, LG stylo 6, or any other LG model, there is always a way for you. Let’s start with the easiest way to bypass LG lock screen!
If you use a Samsung phone, you can unlock it with this guide: How to Unlock Samsung Phone Forgot Password >
How to Bypass LG Lock Screen in 1 Click
What to do if I locked myself out of my LG phone? Many people are bothered by this question. Luckily, bypassing lock codes on LG phones is no longer a hassle with the right tool in hand, i.e., DroidKit – Android Phone Toolkit. This amazing Android phone toolkit can bypass LG lock screen in just a couple of minutes. No matter which kind of screen lock you use on your LG phone, number passcode, PIN, pattern, or fingerprint, it can remove them flawlessly. And because no skills are needed, it suits anyone to  unlock their LG phones.
To know more about DroidKit, have a look at its feature list and working guide below:
DroidKit – Bypass LG Lock Screen Easily
  • Bypass LG lock screen of any kind with four steps.
  • Support all LG models like LG g6/g5/stylo 6, etc.
  • Also support other Android brand like Samsung, Mi, etc.
  • No data loss will occur, 100% safe and clean.
What’s more, as a one-stop Android solution, DroidKit can also help you recover your lost data, remove Google account on your devices, fix Android system issues, etc.
Below is the step-by-step guide on how to bypass LG lock screen in simple clicks.
Step 1. Free download and launch DroidKit on your PC. Click on Screen Unlocker.
Choose Screen Unlocker
Step 2. Connect your LG phone to the computer with a USB cable and clickon the Start button.
Connect your Locked Phone
Step 3. Now, the tool will start preparing the configuration file for your LG phone. When it’s done, you can tap on Remove Now.
Click Remove Now Button
Step 4. Select your device brand to remove lock screen. Here you should choose LG.
Step 5. Follow the on-screen instructions to put your device into recovery mode. After that, DroidKit will start the removing process immediately. Just wait for a few minutes and the LG phone will be unlocked.
Lock Screen Is Removed Successfully
After the removal process is finished, your LG phone will be started, and you can gain access to your device without entering any password.
How to Unlock LG Phone Forgot Password without Resetting
How to unlock LG stylo 6 without password without losing data? Then try to use Google Account to do it. And bypass LG lock screen without reset in this way is not as challenging as it sounds with an easy-to-follow guide. So, refer to the steps below to learn how to unlock LG phone forgot password without resetting:
  1. Open a web browser and visit Google’s Find My Device. Use your Google credentials to log in.
  2. Once you log in, you will get the main interface, and the location of your primary LG device will be displayed on the screen.
  3. In the left panel, click on the device name, and three options will appear on the screen. Here, choose the Lock option, and a pop-up window will appear.
  4. In the window, you can enter the new password and overwrite the existing password.
  5. Lastly, click on the Lock button, and the password of your LG phone will be changed automatically.
Bypass Lock Screen on LG Phone Using Google Account
Make sure to keep your LG device connected to the internet even if it is locked; otherwise, this solution will not work.
How to Bypass Pattern Lock on LG without Factory Reset
Here are some users also wondering about the way to bypass LG lock screen without reset or computer. As all the Android devices set up Google Account, then you can use the Google Account associated with your LG phone to verify your device and bypass the LG screen lock. And all you need is your LG phone. One thing to note here is that this method works only on devices running Android 4.4. or earlier and has been linked with a Google account.
Here’s how to unlock LG phone forgot password without resetting in this way:
  1. Enter the wrong password 5 times and click on Forgot Pattern option at the bottom of the screen.
  2. Now, click on the Next button, and you will reach the screen where you are asked to enter the Google account details. Select Enter Google Account Details and hit the Next button to proceed.
  3. Sign in with the same Google Account that you used on the locked LG phone to verify your device. After completing, the screen passcode will be removed from your LG device permanently. If you need to bypass Google account verification, you can click to check the detailed guide.
Bypass Lock Screen on LG with Forgotten Pattern
Forgotten Pattern on Your Phone
Unlock LG Phone Forgot Password without Resetting via ADB
You can also use ADB to bypass LG k51 lock screen without reset or unlock other LG models. But this method to bypass LG lock screen is quite complicated as it requires a basic knowledge of the command prompt. Also, this method only works if you have enabled the USB debugging on your Android phone. So if these don’t matter, just follow the steps below to bypass LG lock screen.
If you meet all the requirements, follow the guide on how to unlock LG phone forgot password via ADB.
  1. Start by connecting your phone with the PC using the USB cable and open the command prompt window in the ADB installation directory.
  2. In the window, enter the command as ADB shell rm /data/system.gesture.key and press the Enter key.
  3. Now, restart your LG phone, and you will see the screen lock is removed.
Bypass LG Lock Screen via ADB
You can now access your phone seamlessly without much hassle. But remember that this method provides a temporary fix; therefore, opt for the method wisely.
Bypass LG Lock Screen without Reset or Computer in Safe Mode
If you use a third-party screen lock app on your LG phone, then you can also rely on Safe mode to solve how to bypass pattern lock on LG. Because this method will temporarily disable all the third-party apps on your device including your lock screen app. Thus if you are in this situation, why not try this way to bypass LG lock screen without reset. Here we will take LG stylo 6 as an example. Let’s see the steps to bypass LG stylo 6 lock screen without reset or computer.
Use Android Safe Mode
Step 1. Power off your LG phone by long-pressing power button.
Step 2. Press and hold the Volume Down button and turn on your phone at the same time. After that, you will find your phone has entered the safe mode.
Step 3. Open Settings and choose Apps option to find the lock screen app.
Step 4. Just wipe the data or cache of this app. Then restart your phone and it will be unlocked successfully.
How to Bypass LG Lock Screen with Hard Reset
If you have failed to unlock LG phone forgot password without resetting via the above methods, then the last way for you is to hard reset your phone to unlock it. But this way will earse all the data on your device, so please remember to back up your phone first. Then here is the guide to bypass LG lock screen via hard reset.
  1. Power off your LG phone > Press and hold Power button and Volume Down button at the same time until your phone gets into recovery mode.
  2. Press Volume Up or Volume Down button to select the Wipe data/factory reset option. Press Power button to confirm.
  3. Choose Yes to confirm to factory reset your device. After that, wait for the resetting process completes and then restart your phone.
Forgetting the password of your LG smartphone may initially get you into trouble. Still, with these effective solutions above, we are sure that you have known how to unlock LG phone forgot password without resetting. DroidKit is completely secure, easy to use, and fast which can help you unlock your LG phone in simple clicks. So, free download DroidKit now to unlock your device.
