2025 How to Bypass Google Verification on Samsung Galaxy
Are you wondering how to bypass Google lock on Samsung Galaxy? Don’t worry, this guide covers two useful ways to help you bypass the Google verification on Samsung devices without Google account.
Author Avatar Joy Taylor Last Updated: Feb. 19, 2025
DroidKit – Bypass Google Lock Without Account
Free download Droidkit to bypass Google verification on Samsung Galaxy phones without account credentials. Supports all Samsung phones running Android OS 6-15. No Technical knowledge is required.
Google account verification, also called FRP lock (Factory Reset Protection) on Samsung mobile phones is a mobile phone security protection mechanism. If the Samsung screen lock is bypassed by restoring the factory settings, the FRP lock will be activated. If your Samsung phone is unfortunately lost, it can protect your phone and information from being used by anyone who finds it. However, it also brings inconvenience to people who forget their Google password. You can’t access the phone and finish settings normally, and cannot request a Google account screen through your Samsung phone. Don’t worry, here we will show you how to bypass Google lock on Samsung Galaxy with/without a computer.
How to Bypass Google Lock Samsung Galaxy Without PC
If you are looking for a method to bypass Google verification on Samsung Galaxy without a computer, Google Keyboard may be a helpful tool. It is free to bypass FRP on a Samsung device using Google Keyboard, but this way only works on older Android versions and may not be effective on newer security updates. Besides, the steps are a little complex, and there is a risk of the device crashing.
Here are the specific steps about how to bypass Google lock Samsung Galaxy after a factory reset:
Step 1. Just reset your device the first you set up your phone (selecting the language and connecting it to the Wi-Fi network).
Step 2. After that, you will see the Google Account verification interface.
Step 3. When the keyboard comes up to the screen you need to tap and hold “@” to get the Settings menu > Choose Google Keyboard Settings.
Google Account Verification on Samsung
Step 4. Tap on the button with 3 dots at the top-right corner then select the “Help & Feedback”.
Step 5. Click on the “Using Google Keyboard” in the Help section and then tap and hold to select any text on that page and then click “Websearch”.
Step 6. When the search bar comes up and you need to type “Settings” > Scroll down the menu again to select “About Phone”.
Step 7. Find the Build Number and tap on it 7 times in order to activate the Developer Options.
Step 8. Then go back to the previous menu and enter Developer Option > Click on the OEM Unlocking button and tap on “back” twice.
Step 9. Now, what you need to do is restart the device and connect to Wi-Fi again. This time you just simply add a new Google account and you will have complete bypass the FRP lock to access your device normally.
How to Bypass Google Lock Samsung Galaxy [Easy & Secure]
Considering the reliability and ease, DroidKit is highly recommended to bypass Google Lock on Samsung Galaxy. Compatible with both Windows and Mac, this tool contains regular updates and supports all Samsung devices running Android OS 6 – 15. With a few clicks, it helps you to bypass the Google account from your Samsung phone without a password effortlessly. Its easy steps and user-friendly interface make DroidKit a better choice for users with less technical skills. After bypassing the FRP lock with DroidKit, you can remove the previously synced Google account, and log in to another Google Account of yours to enjoy all Google services.
Main Benefits of DroidKit:
  • Works with both Windows and Mac to help you regain access to your device easily.
  • Wide compatibility to bypass FRP on Android, including Samsung, Xiaomi, OPPO, etc.
  • Higher success rate in bypassing Google lock on Samsung Galaxy.
  • Easy steps and fast process, more suitable for beginners.
Here is how to bypass the Google account on Samsung:
Step 1. Get the latest version of DroidKit on your Windows PC or Mac, launch it and choose FRP Bypass mode.
Choose FRP Bypass Mode
Step 2. Connect your Samsung Galaxy to a computer with a USB cable and click on the Start button as the picture shows.
Step 3. After that, the configuration file will be prepared for your device, the below interface will be displayed. Please click the Start to Bypass button.
Click Start to Bypass
Step 4. Then follow the instructions to complete the corresponding Settings.
Complete Corresponding Settings
Step 5. After completing the setting steps above, it will start to bypass the FRP lock. When the bypass process completes, your device will be restarted.
FRP Bypass Complete
FRP Bypass Complete
FAQs about Bypass Google Lock Samsung Galaxy
Q1: How Do I Access my FRP Locked Phone Settings?
You can only access FRP-locked phone settings after Google account verification is bypassed. And, you can bypass any Samsung Google account with or without a computer with the above methods. Besides, a video tutorial is available for you to follow.
Q2: What is the Google FRP code?
There is no universal Google FRP code to bypass Google lock Samsung Galaxy. However, some Samsung devices allow you to enter secret codes in the emergency dialer.
Try This FRP Code on Samsung:
  • *#*#0852#*#*
  • *#*#4636#*#*
If it works, it may open a menu where you can access settings and disable FRP.
In conclusion, this post covers two effective ways to bypass Google lock on Samsung Galaxy both with or without a PC. Between them, DroidKit is highly recommended for its easy steps and higher success rate in bypassing Google accounts effortlessly. With only a few clicks, you can bypass Google verification without an account. Learn more about DroidKit FRP Bypass Tool now >
