FRP Bypass Motorola with or without PC
If you are a Motorola user and are currently experiencing problems with Google lock, then how to bypass google lock on Motorola without PC? Well, in this article, you’ll know 4 ways for FRP bypass Motorola.
Author Avatar Joy Taylor Last Updated: Apr. 18, 2024
DroidKit – Motorola FRP Bypass with Ease
How to unlock Motorola phone without Google account? Free download DroidKit to bypass FRP lock on Motorola in simple clicks. Support all Motorola models running Android 6 to 14.
Have you bought a second-hand phone and don’t know the prior Google account but want to unlock it? Then, you must bypass Google lock on Motorola.
There is no need to worry if you forget your Google account or password. Because you’ll discover all the compatible ways for FRP bypass Motorola. Whether you have a PC or not, you can find suitable way to bypass Motorola FRP lock with ease.
Can I Bypass FRP Motorola?
Yes! You can easily bypass FRP on Motorola Phones by using the various tools or methods to bypass FRP.
In fact, the FRP feature is introduced to secure the latest Android phones, allowing only the device holder to access the phone. But if you forgot your old google account or your employee left the device after resigning without unlocking, then it’ll be a problem. Then, you may’d like to find out how to bypass Google lock on Motorola. Just keep reading and try the methods for Moto FRP bypass.
FRP Bypass Motorola in Simple Steps [Best]
If you are stuck on the Motorola FRP lock, the most efficient and easiest methods to bypass Motorola FRP is using DroidKit – Android Phone Toolkit. It is a one-stop solution to almost all Android problems, including FRP bypass. It allows you to remove the FRP lock in simple steps to get full access to your device. If needed, you can also log in to another Google account to enjoy the services.
In addition, DroidKit can also help you unlock Android screen lock, fix or reinstall Android OS, recover your lost data, and more. Here are some key features of this tool.
  • Bypass Motorola FRP lock in clicks and 3 minutes.
  • Offer customized bypass solutions according to devices and systems.
  • Cover all Motorola models running Android 6 to 14.
  • Also support Samsung, Xiaomi, Redmi, OPPO, POCO, Realme, etc.
Step 1. Now, Give DroidKit a free trial on your computer (Windows or Mac), choose FRP Bypass mode.
Choose FRP Bypass Mode
Step 2. Connect your device to the computer, press the Start button.
Click on Start
Click on Start
Step 3. Now you just need to choose your device’s brand.
Choose Device Brand
Choose Device Brand
Step 4. The configuration file will be prepared for your device. Later, tap on Start to Bypass to continue.
Click Start to Bypass
Step 5. Set up your phone according to the on-screen instructions.
Follow the Bypass Steps
Step 6. After removing your Google account, you can regain full access to your Android phone or tablet immediately.
FRP Bypass Complete
FRP Bypass Complete
Bypass Google Lock on Motorola without PC [2 Ways]
Method 1. Bypass Google Lock on Motorola without PC via Emergency Call
If you don’t have a PC, how to bypass Google lock on Motorola phone? Emergency call is also a good option for FRP bypass Motorola. It requires some time to complete this process; thus, stay with us till the end. Follow the ongoing instructions as shown!
Step 1. First, turn the Motorola device on and connect to your Wi-Fi connection. As the lock screen appears, choose the Emergency Call option.
Step 2. After selecting, the preview of Emergency Information will pop up. Then select pencil icon > Name> Change the profile image.
Emergency Information Preview
Step 3. Choose Menu > Photos > Permissions > Contacts > See All applications> Search Settings > Tap Settings App Info > Open > Pick Accessibility Menu and enable it.
Accessibility Menu on Motorola
Step 4. And from there, return to the settings and select Apps and Notifications > App Info.  Choose some applications from the available list.
Step 5. Then touch the three dots icon, select Show System Apps > Android Setup > Force Stop > tap on OK > delete the Cache > select Disable App.
Step 6. Simply hit the blue Android Setup settings button > select Force Stop > erase all storage and cache data. Open Google Play Services > Disable > Disable App.
Step 7. Return to the main Hello homepage. Hit Start > connect to the Wi-Fi connection screen > look for updates.
Step 8. Then return to the previous screen, and select Skip > Continue > Select More > Accept > Screen Lock screen appears > return to the home screen.
Step 9. Finally, navigate to System > Advanced > Reset. Select Erase All Data to remove all that on the device, along with the Google FRP lock.
Successfully, you’ve done the bypass without a Computer, but if you want to use tools to bypass, then check below!
Method 2. Bypass Google Lock on Motorola without PC via FRP APK
To Bypass FRP Motorola when you don’t have a computer, you can also download the APK tool to do that. FRP APK tool is free and easy to use for all types of users on all android devices. This process needs just a few clicks to accomplish access to the device.
Now, let’s see how to remove Google account from Motorola phone after factory reset without PC!
Step 1. To begin, download the Bypass Google Apk file to your computer. You can use any other Android device instead of a PC.
Step 2. Transfer the downloaded file to a USB flash disc or Pendrive > Switch On the Motorola device.
Step 3. Plug the OTG cable and Pendrive with the other end to your mobile when instructed to input the email address.
Step 4. Now that you have access open your File manager > tap on the FRP Bypass Apk file to activate it.
Step 5. Another alert notice about “Unknown Sources” will show. Select Settings and tick the box next to Unknown Sources.
Step 6. You can now download the app on your phone by selecting the install option.
Install the Application
Step 7. Allow some time for the installation procedure to complete > click the launch button to access the app.
Step 8. The Settings of your smartphone > do a Factory Data Reset to erase any previously stored information.
Step 9. Lastly, your Google account will be deactivated on your device. Reboot your phone and configure your smartphone with a new email address.
FRP Bypass Motorola with Computer [2 Ways]
Way 1. Recover Google Account to Bypass Motorola FRP Lock
If you forgot your previous Google account or didn’t get your password, then you can use two methods to recover them. In this process, you don’t need any tool or program; you just need a Computer to get rid of this. The following are the methods:
  1. Recover Google Credentials.
  2. Remove Google Account.
If you remember the Google Email or Phone, you can follow the steps mentioned to get your password back!
Step 1. On your PC, launch any browser, and go to the Google homepage or the Gmail site.
Step 2. Enter your Google Username or Email after choosing “Sign in.”
Sign in Google Account
Step 3. Then select “forgot password” > follow the instructions that will show up.
Step 4. After 24 hours of completing the password reset, Google will sync it across all of your devices.
You can deactivate the FRP lock if you still can’t get access and can’t even remember about the Google account. It will remove the Google account but remember that if you have an account, then FRP will work otherwise, there is no use.
Follow the below instructions to make it work!
Step 1. Turn on your Motorola device and head to Settings.
Step 2. Navigate to Accounts > tap on Google accounts.
Locate Google on Motorola
Step 3. In the upper right corner of the screen > tap the “account options” > click “remove account” to finish the operation.
Way 2. Bypass Google Lock on Motorola with Third-party Tool
Motoreaper is a good Motorola FRP tool for computer-based Motorola FRP bypass if you have access to one. It’s also a Windows-based program created by the Phonlab team, supports the range of Motorola smartphones, including Moto G, G23, etc.
Follow the steps mentioned below to how to unlock Motorola phone without Google account on computer!
Step 1. Initially, download, and activate the Motoreaper program on your computer. After launching, the screen will display as below.
Starting of Motoreaper Software
Step 2. You must now Power Off your Motorola phone and thereafter turn it on by pressing and holding the Power and Volume Down keys simultaneously for a few seconds. This will put your phone in a bootloader state.
Step 3. The software will display the device after connecting your phone to your PC via a USB cord.
Put Your Phone into Bootloader Mode
Step 4. Then, disconnect your Motorola phone and use the power and volume down buttons to boot it into the factory model utilizing the bootloader mode.
Step 5. Reconnect your phone to your computer and let it fully power up. Then choose I’ve Connected My Device from the menu.
Device in Factory Mode and Connected to Computer
Step 6. Enable Debugging on your smartphone and then press I confirm at Moto Rapersoftware to complete the Motorola Google bypass.
Step 7. The Unlock Now button in the Moto Reaper program has to be clicked to finish the Google bypass Motorola procedure and unlock the FRP.
Click Unlock Now to Start FRP Bypass
Finally, the unlocking is all done, and the confirmation screen is shown. Now you have access to the entire features of the device.
Final Words
FRP bypass Motorola is quite easy if you can access the above methods. Whether you have a computer or not, there’s a proper way for you. And as you can see, DroidKit is the easiest way to bypass Google lock on Motorola in a few steps and minutes. So why not free download DroidKit to try it first?
If you successfully get the features of your device back, then tell us in the comments and share your experience. We love to hear from you guys!
