How to Bypass Google Account without OTG Cable or Computer
How to bypass Google account without OTG? This guide provides the solution to these problems and shows you how to bypass the Google FRP lock without software or OTG cable.
Author Avatar Roger Smith Last Updated: Aug. 14, 2024
DroidKit – Bypass Google Account without OTG 1-Click
If you are locked by FRP, don’t panic. Free download DroidKit – Complete Android Toolkit to bypass Google account/FRP in no time. It is easy to operate and supports Android 6 and above versions.
I recently did the factory reset on my Android phone, and when it boots up, it appears that I am stuck. It says I need to sign in to my Gmail account. But the problem is that I don’t recall the login for the Google account to which I linked my device.
When you are the screen says “This device was reset.” Continue to sign in with an account already synchronized on this device”, you need to enter your Google account and password to unlock. Why would you receive this message?
If you forgot to disable FRP (Factory Reset Protection) before resetting your phone, Google smart lock will be activated on your phone and you need to bypass Google account verification after reset. It is one of Google’s security features for Android phones, which can prevent unauthorized users from deleting your device.
Usually, you can FRP bypass with OTG cable. Here in this post, we will show you how to bypass the Google FRP lock without an OTG cable or without a computer. Let’s get in!
What to Do About FRP Bypass?
There are some FRP bypass apps for your Android phone or Samsung devices. You can download Google Verification bypass tool software like DroidKit we mentioned in this post, which allows you to remove the old Google account and flash your phone generally. Those tools are usually running on computers and bypass Google FRP lock with the computerBesides, the FRP lock can be removed without a computer or OTG.
As we mentioned above, you can download an FRP bypass apk to your phone through a flash drive and OTG cable. Then, install the apk on your phone to remove Google account. However, if you don’t want to bypass FRP with several external tools, or bypassing FRP with online service can sometimes be costly, read the following method to remove the FRP lock on your phone without OTG.
OTG Cable
OTG Cable
An OTG (On The Go adapter cable) cable, allows you to connect your USB flash drive and device via a USB charging port. It helps you to download the FRP bypass apk to your phone device because it can access USB flash drives or external hard drives. Besides, with an OTG cable adaptor, you can easily plug in a mouse or external keyboard with your phone, transfer photos from an external camera to your phone, print data via a printer, etc.
1. Bypass FRP on Samsung/Xiaomi/OPPO/POCO/Redmi Directly [Safe & Easy]
DroidKit is a complete FRP bypass tool that provides you with a way to bypass FRP using a computer. No need for any external tools like an OTG cable or a flash drive.
With DroidKit installed on your computer, you will get a professional FRP removal to remove the previous Google account completely from your device, regain full access to your phone or tablet, and enjoy all Google services.
Key Features:
  • With the help of DroidKit, removing the FRP lock is quite simple for all users because you simply follow the instructions and click on buttons to finish the process.
  • It only takes a few minutes to bypass FRP. Much faster than you think and save your precious time.
  • It guarantees 100% data safety during the FRP lock removal procedure, so no data is deleted, and the device’s settings are not altered.
  • DroidKit has powerful functions, it can also help you unlock your Android device screen locks, and recover your lost but important data like photos, contacts, messages, WhatsApp data, etc.
Now, DroidKit supports all Samsung phones and tablets, Xiaomi, Redmi, OPPO, and POCO. More Android models will be supported soon.
How to bypas Google account without OTG:
Step 1: Once you get the latest version of DroidKit, launch it on your computer and select FRP Bypass.
Choose FRP Bypass Mode
Step 2: Connect your device to the computer, press the Start button. Now you just need to choose your device’s brand.
Choose Device Brand
Choose Device Brand
Step 3: The configuration file will be prepared for your device. Later, tap on Start to Bypass to continue. Select your device’s Android system version. Then, hit the Next button.
Click Start to Bypass
Step 4: Set up your phone according to the on-screen instructions.
Click Reset
Click Reset
Step 5: After completing the preceding steps, it will begin to circumvent the FRP lock. Finally, the Bypass will be completed, and your device will be restarted.
FRP Bypass Complete
FRP Bypass Complete
2. Remove Google FRP Lock on Any Phones with FRP Bypass APK
For Google phone, OPPO and other cell phone users, if you want to bypass Google account without pc what should you do? Then this time, you can choose FRP Bypass APK. FRP Bypass Apk is a tool that any Android users to bypass the Google Account Verification lock for free. Although it sounds like a handy product. But in reality it is a hassle if you want to use FRP bypass APK to bypass Google account. It varies from device to device, model to model and Android version to Android version. You need to follow the steps specially designed for your Android version to install and use FRP app on your phone. Here are our simplified steps:
  1. First, download FRP Bypass APK 2023 on your phone.
  2. Copy and paste the APK file to the USB flash drive.
  3. You need an OTG cable to connect the USB to your phone.
  4. Once the File Manager pops up, the APK will be launched automatically.
  5. Then you need to go to the Settings on your phone, choose Backup and Reset > Factory Data Reset > Reset Device.
  6. Wait for your phone to restart.
  7. Check if the FRP lock is removed and you can use your phone normally.
When you are using a computer, you may need to get an FRP bypass tool on your computer.
3. FRP Bypass Samsung without PC
On some Samsung phones, you can catch its bug and thus bypass Samsung FRP without PC.
  1. Reset your Samsung and follow the steps to enter “Verify your account” page, click on the “Email or Phone” field. When the keyboard appears, click and hold the @ symbol until the settings menu pops up.
  2. Click Google Keyboard Settings. And you’ll see More option, just click it. And then, you can click Help and Feedback from the list.
  3. Under the page, select “Use Google Keyboard“. Long press on any text to select it, then tap “Web search” in the top right corner. And then, delete the existing text until you see the search bar and type “Settings” in it.
  4. Go to Settings menu, and select About phone. Search Build Number and tap it seven times in a row, which will activate the “Developer Options” menu.
  5. Turn on OEM Unlock and then tap Back twice. Congratulations, you have successfully bypassed Samsung FRP without PC.
Does Factory Reset Remove FRP?
Yes! FRP is abbreviated from factory reset protection. It is a protective method for Android phones and tablets. FRP lock will be automatically set up once you added a Google account on your phone or tablet.
And once a device is performed factory reset by yourself or a thief, the FRP lock will be activated. You need to enter your Google account information to bypass it, or you can not get into your phone. Therefore, if you decide to wipe data on your phone, or sell it, remember to disable factory reset protection first.
If you need to bypass your Google account without an OTG cable, you can try the above methods. And, DroidKit is worth downloading. Because you can remove your Google account on any Samsung phone and tablet/Xiaomi/Redmi/OPPO/POCO with DroidKit.
Work for iMobie team for 5 years as well as an Apple fan, love to help more users solve various types of iOS or Android related issues.
