“I have an Android device that I use every day, and it is linked to my Google account. The issue is that I lost the password for that Google account and am unable to recover it using my PC. Now I need to know the ways on how to bypass Google account verification or the factory reset protection that came with my phone. How do I fix this error?”
Locked out of Google account can’t verify? Free get DroidKit to bypass Google account without entering Google account & password. Then you can remove the previously synced Google account and sign in with a new account. It now supports all Samsung, Xiaomi, Redmi, and Oppo devices.
It’s quite inconvenient to be trapped at the Verify your account page after you’ve reset your device, especially if you don’t recall the Google Account details you previously entered. Therefore, if you are stuck in this situation, you come to the right place to bypass Google account. Here you can get the detailed steps to bypass Google account verification. It includes bypassing Google account verification with/without a computer. Let’s start to figure out what Verify your account or Google account verification is!
You may also like: How to bypass FRP with computer
If you factory reset a phone without disabling Factory Reset Protection(FRP), Google lock will be initiated. Your phone will be Google-locked until Google account verification is bypassed. Then, can Google verification be bypassed? You can bypass Google account with your email or phone with ease. On the other hand, if you forgot Google account information, you can also FRP bypass Google account with some other methods that we described in this post. Let’s dive in!!
How to Bypass Google Account Verification
Some users may delete Google search bar accidentally, and you can read the guide on How to Get Google Search Bar Back on Android Phone to get it back.
How to bypass Google account on Android? A more straightforward option is DroidKit FRP Bypass. DroidKit is a complete Android solution that allows you to overcome FRP with a computer. There is no need for any extra gear, such as an OTG cable or a flash drive. With DroidKit installed on your computer, you will get a professional FRP removal to remove the previous Google account completely from your device, regain full access to your phone or tablet, and enjoy all Google services.
Now, you can follow the steps below to bypass Google account verification after factory reset.
Free download and install DroidKit on your Windows PC or Mac > Preview DroidKit and select FRP Bypass.
Choose FRP Bypass Mode
Once you are on the FRP Bypass screen, connect your phone and hit the Start button. And then choose Android.
Connect your Phone and Start
After that, it will begin preparing the configuration file for your device. Once the preparation process ends, press the Start to Bypass button.
Click Start to Bypass
Then you need to select the System Version and tap on the Next button.
Select the System Version of the Device
Then, follow the full instructions in the DroidKit interface and click on the Reset button.
Click Reset Button
After completing the steps above, the device will be restarted and the FRP Lock is also removed successfully.
FRP Bypass Complete
If you don’t want to use the third-party tool, you can also bypass Google account manually. And here we will recommend 2 proven ways to you.
Step 1. On the Google verification page, click the cursor in the blank of Email or Phone to initiate the keyboard.
Step 2. Press and hold the “@” character on the keyboard.
Step 3. When the Android keyboard Settings pops up, click it.
Step 4. Click on the Three dots and choose “Help & Feedback”.
Step 5. Click the “Using Google Keyboard” option, select any text on this page, then click on “Web search”.
Step 6. Enter “Settings” and choose “About Phone”.
Step 7. Find Build Number and tap on it 7 times.
Step 8. Back to the previous menu and click the Developer Option.
Step 9. Enable OEM Unlocking.
Step 10. Restart your device and connect with Wi-Fi. You will find Google verification is bypassed, and you just need to add a new Google account now.
Step 1. Insert a SIM card into your Android.
Step 2. Call your SIM card number using another phone.
Step 3. Accept the call on your Android.
Step 4. Click the number and Add it to your new contact.
Step 5. When you open “Add Contact”, enter a string of numbers and Save.
Step 6. You need to create a new Google account to save it. Later, restart your Android, and Google verification is bypassed.
To avoid Account Verification, you must first turn off Factory Reset Protection before factory reset. When you set up a device with your Google account, this feature is enabled immediately. Although few people are aware of this, we believe Google has made it a default feature to make it easier for consumers. Therefore, just follow the guide below to remove Google account before you factory reset your phone.
How to Remove Google Account Verification
After confirming that your account is deleted from this device (but if you want to go elsewhere, your existing Google account is intact), your FRP function will also be deleted from the device.
Hope you know how to bypass Google account verification after reset now. In this section, we will answer some questions related to bypassing Google accounts.
No. A factory reset can not remove the previously synced Google account, however, it will initiate Google account verification. That’s why this post was created. DroidKit will absolutely bypass Google account verification after factory reset using a computer. After that, you can log in with a new email and password to enjoy Google services as normal.
There is a QR code for you to sign in on a computer, to avoid entering your Google account and password and protect private information. However, if you are stuck on Google account verification, you can not sign in with a QR code because you need to use the camera to scan the QR code and sign in. However, your phone is now locked by FRP lock.
Yes, using some FRP bypass apk is possible to bypass Google account verification without PC. Before using an apk, you’d better check how to bypass FRP with it and avoid potential risks.
Google account verification protects your data by preventing others from wiping your phone if it is stolen. Basically, it is intended to make it more difficult for someone else to use your phone if it is stolen. However, as mentioned in the above article, there are situations when you need to bypass Google account. Obviously, there are a plethora of options available to help you conquer this problem. So whenever you are stuck in a situation where you need to bypass Google account verification after reset, then look no further than DroidKit as it is a very reliable option for you to remove your Google account or FRP lock.
