Want to log into a new Google account on your Samsung Galaxy 9 only to find that you don’t know the password? Hope to bypass Samsung FRP without computer? Don’t worry, this article will introduce 7 Samsung FRP bypass apk to remove existing Google account without PC.
Download DroidKit and quickly bypass Samsung FRP on computer without restrictions. Best Samsung FRP bypass APK alternative for computer users.
Some Samsung users want to download an FRP bypass tool so that they can remove their existing Google account and log into another one on their Samsung phone. However, the Google Play store doesn’t provide a proper choice for them and they turn to download Samsung FRP bypass APK. What’s the best Samsung FRP bypass APK and how can I download it? Here we introduce some popular APK for Samsung users to bypass Google accounts efficiently.
Also Read: Best FRP Bypass Tools for Android 2025
An FRP bypass APK is a tool for users to remove Google factory reset protection on their Android phones without computer. Users who don’t have the Google Play store on their Samsung phones but want to use the FRP bypass tool, then they have to download Samsung FRP bypass APK. Moreover, some developer doesn’t upload the program to the GP store, so they provide an APK to download.
According to the users’ feedback, there are 7 popular Samsung FRP bypass APK widely used to remove Google accounts on Android phones. Check and free download the APK in the following list:
Since we have listed 7 popular Samsung FRP bypass APK to download and use, it’s necessary to introduce how to bypass Samsung FRP without PC. Let’s take FRP Bypass APK as an example.
That’s all about using Samsung FRP bypass APK to remove Google account. You can follow the steps and finish the bypass process without PC.
Further Reading: How to Bypass Google Lock on LG >
It’s complicated to use Samsung FRP bypass APK, especially for some unprofessional users. They may worry about the safety and reliability of the APK files. As a result, you’re recommended to use an alternative to Samsung FRP bypass APK on computer for convenience. DroidKit is a wonderful FRP bypass tool for kinds of Android brands like Samsung, OPPO, Xiaomi, Huawei and more. You can check the features of DroidKit FRP bypass tool in the following:
Here’s how to use DroidKit to bypass FRP on Samsung phones.
Download and install DroidKit on your PC > Click on FRP Bypass mode.
Choose FRP Bypass Mode
Connect your Samsung > Hit the Start button to proceed > Choose the device brand.
Now, DroidKit will start preparing the configuration file for your Samsung device. When the process is completed, hit the Start to Bypass button, as shown in the image below.
Click Start to Bypass
On the next window, find and select the system version of your device and hit the Next button.
Choose System Version
Follow the on-screen instructions to complete the corresponding settings.
Complete Corresponding Settings
Now, DroidKit will start bypassing the FRP lock on your Samsung device. Once the bypass process is completed successfully, your Samsung device will restart.
FRP Bypass Complete
After restarting, you can use your Samsung phone with another Google account without restrictions. The FRP is bypassed successfully with DroidKit.
Further Reading:
The OTG method of bypassing the Google FRP lock after a factory reset on your Samsung device is a great solution. This method works perfectly for Android users, especially Samsung users, to bypass Google account verification.
One thing to note here is that the OTG method works for devices running 5.0 or 5.1 Android device lollipop. So, before we get into the guide, we like you to get the Android OTG cable, Fast Wi-Fi connection, and PC.
Step 1. Download a suggested Samsung FRP bypass APK file on your PC.
Step 2. Copy-paste the APK file on your flash drive.
Step 3. Connect your flash drive to the Samsung phone via the OTG cable.
Step 4. Once the File Manager app pops up, install the APK file on your phone.
Step 5. The Android devices Settings will now be accessible to you. Here, scroll down and select Backup and Reset.
Step 6. Here, click on Factory Data Reset > Reset Devices/Erase Everything. All the settings, accounts, and apps will be removed from the device.
That’s all about Samsung FRP bypass APK without PC. You can choose which you prefer to bypass FRP on your Samsung phones. Also, it’s a good choice to bypass Samsung FRP on computer with DroidKit. Download DroidKit and quickly bypass Google account now.
