“Anyone heard about samfw tool?” A user posted this question on Reddit and doubted its security and unity. Fortunately, this post is a full review of the SamFw FRP Tool, covering everything you need to know.
Want to make FRP bypass on your Samsung device but don’t know how? Just free download DroidKit, the top Samsung FRP tool, to bypass FRP lock on your device in minutes. Supports all Samsung, Xiaomi, and OPPO phones and tablets running Android 6 and above. Works well on Windows and Mac.
As we all know, Samsung’s Factory Reset Protection (FRP) prevents unauthorized device use after its factory reset. It requires a Google account authentication to access the device post-reset. However, FRP lock might cause trouble when you forget your Google account details or buy an FRP-locked device. To solve this common issue for Samsung, various FRP bypass tools have been created, including the SamFw FRP tool.
This article will explore how to download and use the SamFw FRP tool to bypass Google account verification, and also give you an amazing alternative if you don’t want to use the SamFw tool. Let’s start!
As Android unlock software, SamFw FRP Tool addresses various needs of Android device users. One of its primary functions is bypassing the FRP lock. So, this software is especially useful for those who have inadvertently locked their device or purchased an FRP-locked device.
SamFw official webpage interface
The safety of the SamFw FRP Tool is a subject of debate among Samsung users. Some antivirus programs may flag the software as potentially harmful. In most cases, It is generally safe to use without any malware or viruses, but remember to download it from a reputable source.
Yes, SamFw FRP Tool 4.9 is available for free. This tool allows users to bypass Factory Reset Protection (FRP) on Samsung devices without any cost. By providing functionalities free of charge, SamFw FRP Tool 4.9 offers a cost-effective solution for Samsung device management and customization.
Here are the key features of the SamFw FRP tool that make it such an excellent Android management tool.
Now that you have a grip on the key features of the SamFw FRP tool, let’s see how we can use it to bypass Samsung FRP.
Using the SamFw FRP tool to bypass Samsung FRP is not the least bit difficult. You just have to follow some simple directions, and then you can easily gain access to your mobile.
Steps to Bypass Samsung FRP with SamFw FRP Tool:
Step 1. Start by downloading the SamFw FRP Tool and running the software on your PC. Now perform a hard factory reset on your Samsung device.
SamFw FRP tool opening interface
Step 2. Now before you set up your device, connect it to the PC.
Step 3. After that, dial #0# on the Emergency call screen of your mobile to enable AT mode.
Step 4. Navigate back to the SamFw FRP Tool on your PC. Select SAMSUNG and click the “Remove FRP” button.
Enabling test mode on the Samsung device
Step 5. A notification will appear on your phone screen requesting USB debugging permissions. Tap “OK” to proceed.
Allow USB debugging on your Samsung device
Step 6. Now SamFw will start the FRP bypass process. After the FRP removal process, your device will automatically reboot.
The FRP lock will now be bypassed, and you can set up your device freely. Please remember this guide is intended for rightful device owners who’ve unintentionally locked themselves out and not for unauthorized use.
And also, keep in mind that the SamFw FRP tool is not out of flaws. Like any software tool, it also has its benefits and drawbacks. Users should consider them before using this tool.Here are the different Pros & Cons of the SamFw FRP Tool.
Pros
Cons
Due to the limited compatibility, the SamFW Tool may cause inconvenience for MacOS or Linux users. At the same time, some users have reported that the operation is too difficult, and they occasionally encounter failures to bypass FRP. If you are looking for a reliable and effective alternative to SamFw FRP tool, DroidKit is the best choice. It easily bypasses FRP without a password and is also suitable for Mac system users.
Multiple users seek SamFw FRP tool alternatives, especially those operating on non-Windows systems. Then, what is the best alternative FRP bypass tool for Samsung? It must be DroidKit – Android Phone Toolkit. As a professional Samsung FRP tool, DroidKit supports bypassing FRP lock on all Samsung, Xiaomi, and OPPO phones and tablets. And it connects perfectly to all computer operating systems, so it is a must-have FRP bypass tool for Mac or Windows. The high success rate in FRP bypass and easy steps make DroidKit stand out from many competitors.
Main benefits of DroidKit:
What’s more, as a one-stop Android solution, DroidKit is not just limited to FRP bypass. It can also be used for data recovery, system repair, and device unlocking. Moreover, its user-friendly interface and robust features make it the best tool for both novice & seasoned users.
How to bypass Samsung FRP lock with DroidKit:
Step 1. Download and launch DroidKit on your computer > Choose the “FRP Bypass” mode.
Choose FRP Bypass Mode
Step 2. Connect your device to the computer > Tap on the Start button.
Step 3. The configuration file will be prepared for your device > Later, tap on Start to Bypass to continue.
Click Start to Bypass
Step 4. DroidKit will scan your device and recommend a firmware package to bypass FRP. Kindly select your Android version and click Next.
Choose System Version
Step 5. Once complete, your device will restart with the FRP Lock successfully removed.
FRP Bypass Complete
To help you better understand the two tools, here is a simple comparison. To help you quickly and accurately choose the frp tool that suits you.
SamFw FRP Tool | DroidKit | |
Ease of use | User-friendly interface, suitable for beginners | Intuitive design, stress-free use for beginners |
Unlock speed | FRP bypass speed varies depending on the device | Bypass the FRP lock in just a few minutes |
Compatibility | Compatible with Windows only | Compatible with Windows and Mac |
Ability to bypass FRP | Effective removal of FRP, especially for Samsung devices | Bypass FRP on Android devices with a high success rate |
In conclusion, the SamFw FRP Tool is a robust yet free solution for FRP bypass. However, it contains some limitations, like system compatibility and potential security issues. As an excellent alternative for FRP bypass, DroidKit stands out with its high success rate and wide system compatibility. Whether you’re dealing with FRP lock or other Android issues, DroidKit is a trustworthy companion to consider. Learn more about DroidKit now>>
