“I erased and factory reset my Android phone without password, when I reboot the phone, it asked me to enter the Google account information before activation. Then I have to find a way to activate the phone without the existing Google account. Is there any Android unlock tool work for removing both the screen lock and the Google lock? Can you recommend?” – An Android user asked online.
No matter if you want to unlock the screen of your Android phone or tablet without a password or bypass FRP with your Google account, DroidKit can solve your problems. It provides an easy way to unlock Android, saving you time verifying and waiting for the unlock results. Download DroidKit now and enjoy your lock-free Android phone or tablet!
Many phone users lock their devices with pattern locks, passwords, fingerprints, or even facial recognition to secure important data. But sometimes, they can’t unlock the phone because they forgot the complex password, the wrong lock pattern was repeated many times, or their phone was attacked by malicious code, etc.
Then, is it possible to unlock a locked Android? Yes, for sure. A good way to unlock Android phone is to use professional Android unlock tool software to remove the lock screen. So in this article, we will introduce to you the best Android unlock tool as well as the pros and cons. Just keep reading.
You may also like: Best FRP bypass tools for Android
The most recommended Android screen unlocker is DroidKit. It’s capable of removing the screen lock on your Android phone without entering the password. No matter whether you are using PIN, password, pattern, fingerprint ID, or face recognition, you can unlock your phone with DroidKit. You can thus fully access your locked device again in minutes.
Step 1. Free download DroidKit and run it on your PC. Connect your Android phone to the computer via USB cable. On the interface, choose Unlock Screen.
Choose Screen Unlocker
Step 2. Read the instructions and click the Start button. When you see the interface below, click the Remove Now button.
Click Remove Now Button
Step 3. Select your device brand. DroidKit will unlock your phone accurately according to your mobile phone brand. Then you need to follow the on-screen instructions to remove the screen password.
Remove the Screen Password
Step 4. Once you finish the above steps, DroidKit will start removing the screen lock. Wait a minute, and the screen will be unlocked.
Lock Screen Removal Completed
That’s how you can use DroidKit to unlock Android screen password. You can reboot your phone once the unlock process is finished. After restarting, you may stuck on the Google account verification page. If you don’t have the Google account or password information, DroidKit also supports bypassing Google account after factory reset.
Many people will think about Android Unlock Tool when they talk about the phone unlock software. Maybe you forget the password you set or just receive a second-hand Android phone without knowing the lock screen password. No worries, Android Unlock enables you to unlock it in minutes. Pattern, PIN, password, and fingerprint lock screen on Android can all be bypassed, and you can use your phone without setbacks.
Android Unlock Tool
Pros:
Cons:
Dr.Fone – Screen Unlock (Android) is another mobile unlock tool that can unlock the screen with simple clicks and bypass the Android lock screen when you forgot the password. If you accidentally get a second-hand Android device with a locked screen, or just cannot enter a password due to a broken screen, this phone unlocking software can solve your problem. And you can learn more about this Android unlock tool below.
DrFone Unlock Android Phone
Pros:
Cons:
If you are searching for a user-friendly Android unlock tool or mobile password unlock software, you should give consideration to iMyFone LockWiper (Android). When you are locked out of your Android device, it allows you to unlock screen locks from most Samsung devices without losing data. With a few clicks, LockWiper is able to unlock most Android devices quickly. Here are the pros and cons of this Android unlock software.
iMyFone LockWiper Android
Pros:
Cons:
NokiaFREE Unlock Codes Calculator is probably one of the simplest mobile unlocks software to use. This Android unlock tool is highly suitable for inexperienced users. If you just enter the model, country, and IMEI of your phone, the program will search for the unlock code and show it on the screen. Read on and learn more about this Android unlock app.
Pros:
Cons:
If you are looking for a free Android unlock tool or mobile password unlock software, then you cannot miss KingoRoot. It is a phone unlocking software that relies on the Android SDK to unlock the Android bootloader. If you need to root your Android phone, then it will definitely be a good helper. Below are the pros and cons of this Android unlock tool.
KingoRoot
Pros:
Cons:
Another recommended Android unlock tool is Multi Unlock Software. This mobile password unlock software can unlock the screen of many Android devices, such as Samsung, Huawei, Sony, etc., which has been praised by many people. And compared with some password unlock software, the interface of this tool is more concise and intuitive, which is more suitable for technical novices.
Pros:
Cons:
In addition to the screen lock, many Android users may also be stuck on the SIM lock. Therefore, the last Android unlock tool, Unlock Your Phone, is here to help you unlock your SIM card. Using the IMEI code, this tool can easily help you remove the SIM lock on your device, so that you can freely use SIM cards from other network carriers.
Unlock Your Phone
Pros:
Cons:
In case you ever happen to forget your password or can’t unlock the phone with normal means, you can run some of the Android unlock tools from this list and very quickly solve the problem. As you can see, DroidKit can be your best software to unlock Android phones among these tools, because it can 1-click unlock all Android screen locks and supports all Android devices and Android OS versions. So, don’t hesitate to get DroidKit for free right now!
