An in-depth review of the Android multi-tools helps you understand what these tools are used for, the benefits and downsides. Also, you get to know how to operate them. In a situation where the tool doesn’t give the best result, we’ve got the best Android multi-tool alternative that you can use here in this post.
DroidKit supports unlocking Android screen, bypassing FRP without password. Also, it can recover lost data from Android phones in several ways. Download DroidKit directly and solve your Android problems easily.
Hi there, Browsing through the internet for an Android unlock tool and I discovered the Android multi tools as one of the best programs to bypass screen lock. I don’t know how true this is. Please, has anyone interacted with this tool in the past? Kindly help with a review.
Android Multi Tools is a popular software designed specifically for handling security lock issues, from FRP lock to screen lock and more, on any Android device. It claims to offer top-notch results without compromising end-user data.
The aforementioned claim has been questioned by several folks, and it’s for this reason our team decided to write this review to verify the authenticity of the Android Multi Tool. Here, we will discuss what the Android Multi Tool is, how to download it, its merits & demerits, and a detailed guide on how to use it.
Furthermore, an alternative tool will be introduced. Continue reading to catch everything we’ve got to share with you!
Android Multi Tools is a software dedicated to fixing screen lock and FRP lock issues on Android smartphones. It helps you unlock your device and reclaim access easily and quickly. The software fixes screen lock and FRP lock by resetting your device to factory mode, so all content and settings on it are automatically cleared from its system.
As the name implies, the Android Multi Tools also extends its functionality to system rooting/firmware flashing. The software helps you manipulate your Android device to suit your preferences.
It’s among the most reliable Android unlock tools to invest in. However, you must be cautious of the download source. The majority of the download links online are untrusted, as they are filled with viruses and malware.
Android Multi Tool Features:
Android Multi Tool Limitations:
Android Multi Tools is a powerful Android unlock solution readily available for computer systems. It’s super easy to download and install. But you must be very careful when doing so, as most sources are breached.
Here’s a simple guide to download Android Multi Tools:
Using the Android Multi Tool software to bypass screen lock is simple with the detailed instructional guide shared down here:
Step 1: Install the Android Multi Tool software on your computer system. Once done, proceed to enable USB Debugging on your Android phone. You can do this via the Settings menu screen, select System > About.
Step 2: Connect the locked Android phone to your computer system using a reliable lightning cord. Launch the Android Multi Tool and a screen with the various features supported by the software will come up. Here’s a pictorial representation for better understanding:
Tap on 2 to reset PIN or pattern lock on your device.
Step 3: After the aforementioned step is finished, follow the on-screen guide to commence screen unlock. Ensure your phone is still connected to the computer during the unlock process to avoid data loss and complete screen unlock.
Although Android Multi Tool is a cool Android unlock program, the dark sides outweigh the benefits which makes it far less an effective tool. If you need a professional Android unlock utility with top-notch features, DroidKit is the right tool to invest in.
The Fascinating Features of DroidKit
As required of every top-quality software, DroidKit powers an interactive interface that you can easily operate. It doesn’t matter whether you are tech-literate or not, the UI is sleek and super responsive to clicks.
DroidKit tackles all forms of security lock you may encounter on your Android smartphone. From 4-6 numeric passcode to alphanumeric locks, Face unlock, fingerprint, pattern lock, and many others. It uses X-Unlock, a highly intelligent unlock algorithm that scans and communicates with your Android OS security system to understand how it works and then recommends a firmware package to remove the screen lock.
Do you use an Android smartphone running on Android 5.0 (also known as Lollipop) or later OS and lose the Google Account details linked to it? DroidKit offers a convenient way to unlock the device. This software bypasses FRP lock on popular Android brands like Samsung, Xiaomi, OPPO, and others, and grants you full control of the corresponding device within the shortest possible time.
Lost or missing data are super simple to retrieve with DroidKit. The software helps you rescue your permanently deleted data from any Android smartphone at a remarkably high speed without compromising the quality. It recovers more than 20+ types of Android data, from photos to videos, contacts, and many others.
Another interesting function of the DroidKit software is the excellent data management feature. The software helps you manage data between devices without hassles. It lets you migrate data from Android to Android, iOS to Android, and Android to computer conveniently without losing quality.
DroidKit is also capable of fixing system-related issues on Android smartphones. It helps you tackle problems like unresponsive keys, Android black screens, frozen screens, and many others, by clearing bugs and errors disrupting the operations of your device.
Step 1. Launch DroidKit on your Windows or Mac computer. On the main screen, select Screen Unlocker on the right.
Step 2. You need to connect your phone to the computer with a USB cable. And if you connect it successfully, click on Start.
Step 3. It will prepare the configuration file for your device. Please wait for a while and then you need to tap on the Remove Now button.
Step 4. Now you need to put your phone into recovery mode. It will give a detailed guide on the screen. Just follow the guide according to your device.
Step 5. After that, it will unlock your device immediately. And you will receive a notification if it has completed the unlocking process.
The Android Multi Tool is a great tool to own. We’ve discussed everything that the tool has in store for users, how it works, and the download process. However, DroidKit is an advanced Android unlocker loaded with everything you need to bypass screen lock on your device without damaging the system. It handles screen lock issues and helps you regain access to your phone within the shortest possible time. It’s worth trying out!
