How to Use AddROM to Bypass FRP on Samsung/Android [Full Guide]
Android security is getting stronger with time, but getting stuck at the FRP lock screen can be a trouble. This article provides simple and efficient methods to bypass the FRP lock on Samsung/Android devices using AddROM. With this full review, you will know everything about AddROM bypass.
Author Avatar Joy Taylor Last Updated: Aug. 15, 2024
Have you reset your Android phone? Are you stuck at the Google FRP lock screen and don’t know what to do? Don’t worry! We got you. Sometimes Android users need to reset their devices for any reason. But little do they know that Android phones now have a new security feature called FRP.
This feature requires their Google account credentials linked to their device to access it again. However, most of the time, users don’t remember their Google account details. There comes the AddROM FRP bypass to rescue you. In this guide, we will see how to use AddROM to bypass the Samsung FRP lock. Let’s dive in!
What Is AddROM?
AddROM is an Android app designed to help users bypass the FRP lock. It comes in various versions to support the relevant devices. However, the best part is it doesn’t require a PC or laptop to perform the action. All you need to do is install the suggested APK files on your Android phone, and you can bypass the Google account in a few minutes.
Click AddROM’s Official Website to explore more.
Supported Android Versions:
It supports all Android versions mentioned below:
  • Lollipop 5.0
  • Marshmallow 6.0
  • Nougat 7.0
  • Oreo 8.0
  • Pie 9.0
But if you have an Android version above 9.0, you can try another way explained in this article. Let’s move forward to the steps of using AddROM.
How to Download and Use AddROM FRP Bypass APK
As you already know, your primary device is locked, and you cannot download AddROM. Therefore, you need another Android device to do the job. You can download AddROM FRP bypass APK file from its official website. Once you have downloaded the file, you can follow the instructions for AddROM bypass given below:
Step 1. Make sure that your Locked phone has an active SIM card inside it. Then put it aside and take another Android phone.
Step 2. Now go to the official website of AddROM, scroll down, and download the HushSMS.apk file. Then navigate to My Files > Downloads and find HushSMS.apk to install it.
Step 3. Once the app is installed, open it and click WAP PUSH SL. Then enter the phone number of the locked device. In the Message box, type www.youtube.com/@addROMcom and click SEND WAP PUSH SL button.
Enter the Phone Number
Step 4. Wait a few seconds; the AddROM YouTube channel will automatically open on your locked phone. Click the Menu icon at the top right corner and select Terms & Privacy Policies.
Step 5. After clicking Terms & Privacy Policies, you will see a browser page. Click the search bar and type addrom.com/bypass. Then scroll down and download the relevant Google Account Manager (GAM) APK.
Download Google Account Manager APK
Step 6. Meanwhile, download the FRP bypass APK file from the same list. Once the downloading is completed, install both apps on your device.
Step 7. Open the FRP bypass APK app and click the Menu icon at the top right corner. Then click the Brower sign-in option, sign in with the Google account you want, and restart your device.
After a restart, you will not face the FRP lock again. It will be successfully removed. However, this method is very complex, and the success rate is not guaranteed.
Let’s walk you through the pros and cons of AddROM.
Pros and Cons of AddROM
Every tool has both advantages and disadvantages so does AddROM. So, before you let AddROM bypass FRP, you can learn the pros and cons of the AddROM bypass APK file first.
Pros:
  • A free tool that we can use to bypass the Android FRP lock.
  • It doesn’t require any PC or laptop.
Cons:
  • It does not work on Android with version 10 and above.
  • You won’t get any help because there is no official support team.
Therefore, we recommend you use an efficient alternative. Let’s explore it!
Best Alternative of AddROM – DroidKit
You may be helpless if the Android OS of your device is not supported by AddROM or you fail with FRP bypass AddROM. But luckily, here comes DroidKit – Android Phone Toolkit, a tool that offers an efficient solution to bypass the FRP lock without Google account and password. Most importantly, it supports Android 6-13, so you don’t need to worry about compatibility. And it will offer customized FRP bypass solutions according to the system version, ensuring a much higher success rate.
After FRP bypass, you can also log in to another Google account and freely enjoy various services on your device. Next are some highlights of DroidKit on bypassing FRP.
  • Simple operation, user-friendly – No technical requirements. You only need to follow the steps to bypass FRP lock at home easily. Anyone can use it.
  • No need to wait – With this tool, you can remove Google account and FRP lock in just a few minutes. You no longer have to spend days waiting for a technician to do it for you.
  • Support multiple Android devices and systems – Samsung, Xiaomi, Redmi, POCO and OPPO. All of their device models running Android 6 and above are supported.
  • 100% clean and safe – DroidKit guarantees that your device will not be damaged in any way. And your privacy and data will not be disclosed to anyone.
And as a complete Android solution, DroidKit can also help you unlock your screen lock, fix Android OS bugs, recover lost data, and more.
Before starting, free download and install DroidKit on your laptop or computer. Then follow the instructions given below to bypass FRP lock.
Step 1. Launch DroidKit, and select FRP Bypass mode on the main interface.
Choose FRP Bypass Mode
Step 2. Now connect your Android phone to the PC via a USB cable and select the Start button to proceed.
Step 3. After clicking the Start button, DroidKit will ask you to select your device brand. Here we choose Samsung.
Choose Device Brand
Choose Device Brand
Step 4. DroidKit will start preparing the configuration file for your device. After that, click on Start to Bypass.
Click Start to Bypass
Step 5. Then you need to choose the system version and click Next.
Choose System Version
Step 6. Follow the on-screen instruction to prepare the settings. Then, click Reset.
Complete Corresponding Settings
Step 7. DroidKit will start to bypass the FRP lock. Once it is completed, you will see the below interface.
FRP Bypass Complete
FRP Bypass Complete
FAQs about AddROM and FRP Bypass
Here are some frequently asked questions about AddROM bypass. Just read on to find out the answers.
Q. Is it free to use AddROM FRP bypass APK?
Yes, it is free! You don’t have to pay any fees to use it. However, some websites could require you to pay a fee to download the APK.
So, it is recommended to download the AddROM FRP bypass APK file from its official website. Or, you can browse the internet and download it from a source that doesn’t charge.
Q. What are the AddROM supported Android versions?
Here are the Android versions that can be unlocked using AddROM:
  • Android 5.0 (Lollipop)
  • Android 6.0 (Marshmallow)
  • Android 7.0 (Nougat)
  • Android 8.0 (Oreo)
  • Android 9.0 (Pie)
  • Android 10 (Q devices)
You can use DroidKit if you have the latest version of Android.
Q. Why are you locked by FRP lock?
It is a new security feature incorporated into Android devices. It helps to keep your data safe in case your phone gets stolen or lost. Once your phone is reset, the FRP lock will be activated. Therefore, users must enter the Google account credentials linked to the device to access the device again.
We can understand that the FRP lock can be annoying. But thankfully, there are several ways to bypass it. We hope you have found this guide helpful in removing the FRP and regaining access to your Android phone.
Although AddROM is helpful, it cannot support all Android OS versions. And some users couldn’t follow all the steps and left the process in the middle. Whereas, DroidKit is an easy and efficient alternative to bypass FRP. And it even supports Android 13. The best part is it is not just limited to FRP bypass. There are many other features, such as data recovery, data manager, system cleaner, etc, offered by DroidKit. So why not free download DroidKit to have a try?
