Act Unlock Tool V6.0 Free Download for Android Unlock
One popular program for unlocking Android smartphones is the Act Unlock Tool, which lets users bypass various locks and limitations. This article thoroughly explains the tool’s functionality and step-by-step directions for downloading and efficiently utilizing it. Additionally, you’ll learn about a reliable alternative – DroidKit to unlock your Android device in easier ways.
Author Avatar Joy Taylor Last Updated: Feb. 07, 2025
Is it difficult for you to unlock your Android device? The Act Unlock Tool is what you need! With the aid of this program, you can access your phone by getting around screen locks, including PINs and patterns. This tutorial will walk you through downloading and using the Act Unlock Tool, regardless of whether you purchased a locked used device or have forgotten your password. In case you find it hard to use, you can unlock your device using alternative methods such as DroidKit. Let’s get you back on your phone and get started!
What is the Act Unlock Tool?
Act Unlock Tool was created to assist users in swiftly unlocking Android without password. It will help those who may have forgotten their screen locks or bought a used phone that is still locked. One of its main features is Screen Unlock, which bypasses various screen locks, including PINs, patterns, and fingerprints. FRP Bypass is another feature offered in this program that assists users avoid Google account verification when resetting devices. The tool is also user-friendly and requires no technical skills. It accelerates the unlocking process and has a high success rate while dealing with all lock problems.
In addition to unlocking capabilities, the tool also supports operations like bootloader unlocking, bypassing security features (SLA/DAA), and even data recovery in certain cases. It’s updated regularly, with recent versions, like V5.5, supporting an extensive range of models from Xiaomi, Huawei, and other major manufacturers.
What Does Act Unlock Tool Do?
The Act Unlock Tool is designed to help users easily unlock their Android devices. Here are its best functions:
1. Screen Unlock
The Screen Unlock feature allows users to bypass various screen locks, such as PINs, patterns, and fingerprints. This program can assist you in regaining access to your phone without erasing any data if you forget your lock or cannot access it.
2. FRP Bypass
After a reset, users can deactivate Google account verification with the Factory Reset Protection (FRP) Bypass. This feature is quite helpful if you purchase a used phone and are unable to access the Google account page. It walks you through how to bypass the account verification so you can easily set up the device as new.
3. Data Recovery:
If you unintentionally erase files while attempting to unlock your Android smartphone or lose crucial data during a factory reset. In that case, you can use the Data Recovery option to recover deleted data from your device. It automatically checks your device for file recoverability, keeps important data from being erased forever, and lets you get back what you need.
4. Removal of Third-Party Lock Screen
This function allows users to remove third-party lock screens that may prevent device access. If a previous owner used a custom lock app, the Act Unlock Tool can eliminate it, restoring your ability to access your phone as intended. This makes it easy to regain control over your device.
5. Unlock Multiple Android Models
The Act Unlock Tool is flexible for any user as it supports many Android devices. Regardless of the brand—Samsung, LG, Oppo, Xiaomi, Pixel, and many more—the tool can assist you in unlocking your cellphone. This function guarantees a dependable unlocking solution for any smartphone.
How to Download & Use Act Unlock Tool
Now, let’s explore the simple steps to download and use the Act Unlock Tool:
Step 1. Download the latest version of the Act Unlock Tool from the official website.
Step 2. Install the tool and run it as an administrator.
Step 3. Open the Act Unlock Tool to see the main menu.
Act Unlock Tool Menu
Step 4. Connect your mobile phone to your computer using a USB cable.
Step 5. Select your phone model from the list or click “Automatic Detection” to let the tool identify it.
Step 6. Choose the action you want to perform, like “Unlock Bootloader,” “Bypass FRP,” or “Reset Lock.”
Step 7. Wait for the process to finish. Disconnect your phone from the PC and start using it again.
Better Way to Unlock Android Without Password
While Act Unlock Tool works with MTK and Qualcomm devices, its compatibility doesn’t extend to all chipsets or newer security patches, potentially leaving some users without a solution for their devices. That’s where DroidKit comes in! With several tools intended to unlock Android smartphones effectively, DroidKit is an effective alternative to the Act Unlock Tool. PINs, patterns, and fingerprints are among the many screen locks that users may get around with its Screen Unlock feature. Furthermore, following a reset, users can eliminate Google account verification with the FRP Bypass feature, facilitating access to used devices.
DroidKit unlocks over 20,000 Android phone and tablet models, ensuring compatibility for nearly all clients. Even those without much technical experience can use the tool because of its intuitive design. DroidKit combines convenience and efficacy, making it a reliable choice for unlocking Android phones.
Key Features:
  • Works with both Android phones and tablets, making it versatile for various devices.
  • No technical skills are needed, making it easy for anyone to use the tool.
  • It provides a fast unlocking process, and tasks are often completed in just a few minutes.
  • It previews recoverable data before unlocking it so users know what to expect.
  • Regular updates ensure compatibility with the latest Android versions and device models.
Now let’s explore the simple and easy steps to use Droidkit for unlocking Android:
Step 1. Begin by downloading and installing DroidKit on your computer.
Step 2. Open DroidKit and select “Screen Unlocker” from the main menu. Connect your Android device to the computer using a USB cable.
Choose Screen Unlocker
Step 3. Click “Start” to begin the unlocking process.
Step 4. DroidKit will set up a configuration file. Wait a moment for this to be completed.
Step 5. Once ready, click “Remove Now” to continue. Follow the instructions to enter Recovery Mode based on your device type, then select “Wipe Cache Partition.”
Put Your Android Phone into Recovery Mode
Step 7. DroidKit will start removing the lock. Wait for the process to finish. When done, your device will restart, allowing you to access it without a password.
Click Remove Now Button
In this post, we covered the Act Unlock Tool, a useful tool for unlocking Android smartphones. It assists clients in rapidly and simply regaining access to their phones with capabilities like screen unlocking and FRP bypass. The Act Unlock Tool can be complex and limited in device compatibility, whereas DroidKit offers a broader, user-friendly solution for unlocking, data recovery, and Android maintenance. It is a flexible choice for unlocking Android phones and tablets because it provides comparable capabilities and supports over 20,000 devices.
