If you are worried about losing everything on your phone after rebooting, this article is the one to read. It will ease your worries and guide you on rebooting your phone. Furthermore, it will also show you different methods of backing up your data and resetting your phone. Read on>>
How to reset a phone that is locked? Just free download DroidKit to 1-click reset and unlock your Android device. It unlocks all screen locks like Touch/Face ID, passcode, pattern, etc. All Android devices like Samsung, Huawei, LG, etc. can be reset and unlocked by DroidKit.
Have you ever been in a situation where you’re forced to reboot your Android phone? Did you start to wonder if you’ll lose everything on it?
Will I Lose Everything If I Reboot My Phone
Whether it’s due to a glitch or routine maintenance, losing all your data can be scary. But fear not; we’ll put your mind at ease and answer all your questions!
In this article, we’ll explore the ins and outs of rebooting and resetting your Android phone. We will also tell you what happens to your data and how to back it up before you hit that reset button.
So, grab your phone, and let’s dive in!
Further Reading: How to Recover Data After Factory Reset Android?>>
What is reboot in phone? On an Android phone, a reboot means to turn the phone off and then back on again. It’s like restarting a computer.
When you reboot your phone, all apps close, and the phone’s operating system restarts. This helps clear any temporary glitches or software issues causing your phone to slow down or behave erratically. It’s also a common troubleshooting step for many Android problems.
There are two ways to reboot your Android phone: a “soft” reboot and a “hard” reboot. A soft reboot is done by holding the power button and tapping the “Power off” option. A hard reboot involves physically removing and reinserting the battery from the phone (if it’s removable). However, most modern Android devices don’t have a removable battery, so a hard reboot is not an option.
Now let’s see what happens if you reboot your phone.
What does rebooting your phone do? As mentioned above, rebooting your Android phone is a common troubleshooting step for issues such as freezing, crashing, etc. When you reboot your phone, it clears out any temporary files and processes contributing to the problem.
For example, if an app is causing your phone to freeze, rebooting can close that app and free up the phone’s resources. This will allow it to function normally again.
Additionally, if any background processes consume a lot of resources, a reboot can help clear them out and free up memory.
One of the benefits of rebooting your phone is that it can help to improve performance. Over time, as you use your phone and install more apps, it can slow down. This is because more processes are running in the background, and the phone’s memory can become full.
You can clear out this clutter and start fresh by rebooting your phone. This can help your phone run more smoothly and respond quickly to your commands.
If you want to reset your phone, there are different methods you can use to do that. The easiest method is to use DroidKit’s Screen Unlocker Mode. But you can also use the settings menu and the recovery method to reset your phone.
Now let’s look closely at each of these methods.
If you wanna factory reset your Android phone, is there an easy, safe, and fast way to help you? The answer is YES! The most recommended method here is using a professional Android phone unlocker to solve your problem. Here let’s meet DroidKit – Android Phone Toolkit, which is exactly what you are looking for.
DroidKit is a mobile toolkit that facilitates Android device management, backup, restoration, and reset. DroidKit guarantees a safe reset approach. With the help of DroidKit, you can successfully reset your device to default mode without a password. And it resets your device without crashing your operating system.
Next, you can get DroidKit for free on your computer, and learn how to reset your phone with the simple steps below:
Step 1. Free download and launch DroidKit > Click the “Screen Unlocker” option.
Choose Screen Unlocker
Step 2. Connect your phone to the computer via a USB cable > Tap on Start > Then, click on “Remove Now.”
Click Remove Now Button
Step 3. Follow the instructions given on the screen to put your Android phone in Recovery Mode.
Finish Settings on Samsung
Step 4. DroidKit will start the unlocking process immediately. Wait a minute, you will see Screen Lock Removal Completed page.
Lock Screen Removal Completed
Using the built-in Settings menu, you can reset your Android phone to its factory settings. This method will erase all the data and settings from your phone, so it’s essential that you back up your data before performing a factory reset.
1: From the main menu, go to the Settings app.
2: In the app, scroll down to click on the “System” menu.
3: Select the “Reset” option.
4: Out of the available options, choose the one that suits you best.
Different Reset Options
5: Follow the instructions on the screen to complete the process.
If your phone is unresponsive or not booting up correctly, you can try resetting it using the Recovery mode. This method involves booting your phone into a special mode that allows you to perform various maintenance tasks, including resetting your phone to its factory settings.
Scroll to “Recovery Mode”
The key combinations may vary depending on your phone’s brand and model.
If you’ve lost your phone or it’s stolen, use the Android Device Manager to remotely erase all the data from your phone and reset it to its factory settings. This method requires that you have the “Find My Device” feature on your device and have access to your Google account.
You must also have the Android Device Manager app.
Step 1: Ensure your lost or stolen Android device is signed into your Google account and has an active internet connection.
Step 2: Using a PC or another device, access the Android Device Manager and locate your lost device.
Reset phone using Android Device Manager
Step 3: Select the option to “Erase all data” to remotely factory reset your device.
Step 4: If your device runs Android 5.1 or higher, a password will be required to reset the device, providing additional security.
Rebooting your Android phone won’t delete any of your data or apps. All of your photos, contacts, and other files will still be there when the phone starts back up.
However, it’s important to note that a reboot is different from a factory reset.
With a factory reset, all data will be erased, and the phone will return to its original settings. So, if you’re just looking to fix a minor glitch or speed up your phone, a reboot is a safe and effective option.
But a factory reset may be necessary if you plan to donate or sell your phone or if you want to start fresh with a clean slate. Just ensure that your data is backed up to avoid losing anything important.
If you are looking to reset your phone, the first step is to back up your data. You can do this using various techniques, such as third-party backup solutions. One such solution is the DroidKit.
DroidKit – Complete Android Solution is a helpful tool for Android phones that can help you manage and optimize your device. It has various modes like Data Manager, Screen Unlocker, and others. Such modes make it easy to manage your data, bypass FRP lock, reset your phone, unlock your screen, and more. Read on to learn more about its features:
Free get DroidKit and explore its powerful functions:
Step 1. Download and install DroidKit on your computer > Launch DroidKit and connect your phone to your computer using a USB cable > Select the “Data Manager” option.
Choose Data Manager
Step 2. Once the connection is established, please select Export Content > Choose the Photos file folder to transfer to the computer.
Select Photos to Manage
Step 3. And you can preview all the files in these categories and select what you want > Tap on To PC to backup them to your computer.
Transfer Photos to PC
Now that you can save your data let’s look into resetting your phone.
What if you have already lost your phone data for various reasons? How to Recover Data After Factory Reset Android? Don’t worry! DroidKit is here to help you out!
DroidKit is a very comprehensive software, besides the above-mentioned functions that can backup data and reset your phone. It can also recover your lost data. As a professional Android data recovery tool, DroidKit can easily scan, preview, and selectively recover data without root, as there are some disadvantages of rooting an Android phone.
Free download DroidKit>> and enjoy its recovery feature to recover lost data with simple clicks!
You can follow the detailed step-guide post to recover your data: How to Recover Data After Factory Reset Android>
In conclusion, rebooting your Android phone can be a great way to troubleshoot common issues and give your phone a fresh start. What’s more, it’s essential to avoid any potential data loss by backing up your data beforehand.
With DroidKit’s user-friendly interface and powerful features, you can easily manage your phone’s data and reset it to its factory settings without any hassle. You can even recover lost data with one click. Free get now and enjoy the powerful features of DroidKit! Manage your Android device, just having DroidKit is enough!
