Are you searching about how to update Samsung phones and tablets to their latest version? If yes, then here you will read about detailed steps to update the device. Continue reading to get a bonus tip as well.
Samsung’s phones and tablets are one of the best Android devices that are available around. As they are equipped with tons of features, amazing screen display and great camera they always stay in demand. If you are a Samsung phone or tablet user, then you would already know that with every new software update, Samsung introduces exciting features and fix bugs as well.
So, if you are looking for the steps on how to update Samsung phones and tablets to their latest version, then stick around. When you update the Android device to its latest software version, you will notice that your device has running extremely smoothly.
It will also help in enhancing the user interface and security. If your Samsung phone or tablet is having any system-related issue, for example, apps keep crashing, Android can’t send text messages, etc., usually, you can easily solve it by installing and updating the device to its latest version. This post entails all the steps that you should follow to update your device. So, ensure that you read till the end.
Also Read: Can I Force an Android Update? >
Smart Switch is a manager for Samsung devices to update systems, transfer data, or back up files with convenience. Manually updating Samsung phones or tablets can be achieved in Smart Switch.
Step 1. Launch Smart Switch on your computer.
Step 2. Use a cable to connect your Samsung to your computer.
Step 3. Let Smart Switch detect your device status and check for updates.
Step 4. Click update when it shows the new Android version information and wait for the process.
Then your Samsung phone or tablet will be upgraded with Smart Switch successfully.
If you fail to update Android system automatically on your Samsung phone, or Samsung Smart Switch stuck in updating your system, then you can try a third-party program to upgrade the Samsung system. DroidKit is a powerful tool for updating Android systems, fixing system issues and more. With just a few steps, your Samsung system will be updated with DroidKit easily.
Free Download DroidKit and follow the steps to upgrade Samsung phones or tablets.
Step 1. Launch DroidKit and click System Reinstall.
Step 2. Click Start and use a cable to connect your Samsung device with DroidKit.
Step 3. Download the Firmware for your Samsung phone.
Step 4. Follow the instructions to install the latest Android version.
DroidKit is an all-in-one tool that helps to solve kinds of Android issues quickly. The full features of DroidKit are as follows:
With DroidKit, there is no worry about Samsung system update problems or system issues anymore.
If there is a system update available on your Samsung phone, then you can easily download it with a simple procedure. However, you need to note that you will not be able to use the device or even make calls during the update process. Your Samsung phone will become inaccessible till it is updated to the latest version. Follow these below-listed steps to manually update AndroidOS in Samsung phones:
How to Update Samsung Phone to Latest Version
Just like Samsung phones, you can manually update the Samsung tablet to the latest version on your device. There are many advantages to getting the latest Android version installed on your tablet. Some of the common ones are better power usage, performance improvements, security and glitch fixes, etc. So, if you are having the problem of how to update your Android tablet to the latest version, then you can follow the steps shown below. The options may vary as per models.
Choose Software Update Option
Select Update and Confirm
That’s how you can update and solve the issue of how to update Samsung tablet Android version.
Further Reading: How to Fix Android System Update Failed to Install >
That’s all about how to manually update Samsung phones and tablets. You can choose Smart Switch or DroidKit to upgrade Samsung systems or simply check for updates in settings without computer. For those who require a powerful tool to manage Samsung devices, DroidKit is surely the best choice. Download DroidKit now and update Samsung phones or tablets effortlessly.
