You will find a lot of interesting and useful information, and maybe a few brilliant creative ideas for arranging your wallpaper. At the very least, it can be very intriguing to explore the pre-designed possibilities of your device.
The quality and high performances of the phone we use are very important, but for many people, the aesthetics of the screen of their device are just as essential. The visual taste of the average user has grown more refined taste and advanced design solutions are a huge point of interest when buying a new Android phone.
With this in mind, it’s good to know that there are options to change or move the clock on the Android lock screen and create personal wallpaper if you are not satisfied with the original configuration. Those options are very easy to activate, so if you have the right information on how to change the clock on the lock screen it won’t take more than a few minutes to do it.
Check some other Android tips:
If you have a phone running on the Android 12 operating system, you probably already know that there are no official options for easily changing the clock on your lock screen. This minor inconvenience bothers many users to the point they are actively seeking alternative solutions.
We listed some methods you can try that were demonstrated to be successful with making clock changes on your phone.
Bonus Tip: Text messages notification not working? Fixes here: How to Solve Text Message Notification Not Working on Android >
The clock on Android 12 is only displayed in full size when you don’t have a notification pending. The moment you get an alert, the clock changes its original position and size and then moves to the top left part of the screen. If you always keep an unread notification, a large clock will never appear on your screen.
Instead of constantly keeping an unread notification to get smaller digits of your clock, we suggest enabling permanent notification for some of your apps. This kind of notification stays on your display and prevents the clock from occupying the entire. This option isn’t available in all apps, but you can find some that do on the web, like the weather app which runs permanently in the background.
Android picks the color for the clock based on your wallpaper, with the system acting as a designer for you. However, if you change the wallpaper you are using, the colors of your lock screen clock will be also changed accordingly. Here is how you can do that:
Another convenient way to change or reconfigure the clock on the lock screen involves activating a screen saver on your Android. Follow these steps to complete this task:
Turn on Android Screen Saver on Android Phone
By turning off this option, you can eliminate the big clock on Android 12 so that you will see it only when you press the Power button. Take the following actions to disable Always on Display.
Turn off Always-on Display
If you want to modify the look of your clock and upgrade its style you can download a dedicated app from the Google Play Store. There are specialized apps that let you change the size of the clock, modify the colors, or completely redesign the clock face. Some of the apps are free for download so there are no downsides to having them on your device.
With Samsung phones the situation is a little bit better when it comes to customization of the clock. Samsung phones support various clock styles and even a total beginner can easily set up this feature. You can choose between a futuristic, analog, or digital clock, and you can try out multiple possibilities until you discover the ideal design for your phone lock screen. Just follow the next steps and you will be able to control clock styles on your Samsung smartphone:
Choose Clock Style
As a great software for unlocking Android phone, DroidKit allows you to remove the screen lock, regardless of the reasons why access is disabled on your phone. It is perfectly capable of bypassing different types of locks, including 4-digit PIN, 6-digit PIN, custom PIN, password, pattern, fingerprint ID, face recognition, etc. There are key features of DroidKit:
Before using this tool to remove the screen lock on your phone, you need to make proper preparations. You need to download DroidKit and install it on your computer. Then, follow the steps below to start unlocking your Android phone.
Step 1. Launch DroidKit on your PC and connect your Android phone to the computer via USB cable. On the interface, choose Screen Unlocker.
Choose Unlock Screen Function
Step 2. Read the instructions and click the Start button. When you see the interface below, click the Remove Now button.
Click the Remove Now Button
Step 3. Select your device brand and click Next. DroidKit will unlock your phone accurately according to your mobile phone brand.
Step 4. Follow the on-screen instructions to put your device into recovery mode and wipe the cache partition on your phone. Once you finished the above steps, DroidKit will start removing the screen lock. Wait a minute, and the screen will be unlocked.
Lock Screen Removal Completed
For users who have high expectations and insist on creative details, the design of the lock screen clock at Android 12 may not be the best solution. To improve the visual look of your device, we recommend some methods you can apply and change or remove the clock from the screen. With one of those approaches, you should be able to get your phone to look exactly like you want it to, without the default clock dominating your lock screen. Of course, if you want to remove your screen lock on Android, just try the best choice – DroidKit.
