Are you unable to connect Huawei phone to PC? Go through this post and learn all plausible ways to fix Huawei phone not connecting to the PC problem.
There are many scenarios when you find to transfer data from your Huawei smartphone to your Windows PC. And the trouble begins when your phone won’t connect to the computer. It is upset to find your pc doesn’t recognize Android device.
Well, it’s a common problem faced by many Android users, especially for those who own Huawei smartphones. The good news is that there are many ways to help you fix Huawei phone not connecting to PC. Please continue reading and trying every possible solution to resolve Huawei not connecting to PC issue.
There could be several reasons why can’t I connect my Huawei to my computer. Below we have covered a few effective workarounds and solutions to help you fix the issue.
If you’re seeking to connect your phone to the computer via USB, ensure that you have enabled USB debugging on your phone. USB debugging mode is preinstalled in many Android phones. Its primary function is to establish a connection between an Android phone and a computer through the Software Development Kit/Android SDK. Thus, you can activate it on your Android phone after connecting it to the PC via USB connection.
Enabling USB debugging mode on your Huawei phone can help fix the problem related to USB connections between your device and computer. So, let’s check how do I use USB debugging on my computer:
Connect Huawei to a Computer via USB Debugging
Trying a different USB cable or port can help you determine whether the issue is with the USB cable or port. Check for visible damage and if you find anything wrong, try a different USB cable and connect your phone to the computer again.
Performing a simple reboot on both your Huawei phone and computer can help resolve the issue if it’s due to a minor software glitch.
To restart your Huawei phone, follow the below steps:
To restart your computer, follow the below steps:
Then, try again to connect your phone to the computer.
DroidKit is a powerful Android solution toolkit that can satisfy Android users’ various demands. Free get the latest version of DroidKit and check its outstanding features as below.
Now, follow the steps below to fix Huawei not connecting to PC in a few simple steps.
Step 1. Get the latest version of DroidKit on your computer > Connect your Android device via a USB cable and tap on the Data Manager panel.
Choose Data Manager
Step 2. Connect your Huawei phone to the computer via a USB cable > Choose the Huawei model and follow the on-screen instructions to finish Huawei USB connection settings.
Fix Huawei Not Connecting to PC via DroidKit
Step 3. Until now, Huawei USB file transfer not working issue is fixed. Then you can click the Start button to continue. Afterward, you can preview and manage Huawei data on your computer.
Preview and Manage Huawei Data on Your Computer
Huawei USB drivers enable the phone to communicate with the computer properly. Your Huawei phone drivers will be necessary if you’ve never tried to connect your Huawei device to your computer. Once the drivers are installed, they will help your computer recognize your Android phone.
Well, the official USB driver for Huawei phones is Huawei HiSuite and you can download it from its official website to your PC computer. Below is a quick guide on what you need to do to fix the problem:
At the same time, retry connecting your phone to the PC. This would now probably fix the Huawei USB not recognized by the PC issue. You will see your Huawei phone in the list of external devices connected to your PC under “My Computer/This PC” if the computer successfully detects your phone.
Ensure that your Huawei phone is up-to-date. An outdated software version on your Huawei phone could be the reason to encounter this maddening issue. So, follow the below steps to update your phone:
Step 1: On your Huawei phone, go to “Settings”.
Step 2: Go to “System Updates”.
Step 3: Check if there are the latest software updates available. And it has the latest version, download and install it right away.
Connect Huawei to a Computer via Update
There are several ways out there to help you connect a Huawei phone to a PC. So, have you tried all methods for connecting Huawei to a PC? Well, no matter what’s your purpose to connect your Huawei device to a PC, the below ways can help you get the job done.
You can also connect your phone to your pc via Huawei HiSuite. For that, you need to get Huawei HiSuite app – an official Huawei connection manager, on both your phone and PC. And you also need a USB cable to establish the connection. Below is the step-by-step guide on how to connect Huawei phone to PC using a Huawei HiSuite:
Step 1. Download the Huawei HiSuite from its official website to your Windows PC. Once downloading it, follow the instructions to install it and then run it.
Download Huawei HiSuite and Connect Your Device
Step 2. Connect your Huawei phone to your PC with the help of a USB cable.
Step 3. Now, you need to allow HiSuite to connect to your phone. And Huawei has provided a particular setting for Huawei HiSuite in their Android device implementation.
Allow HiSuite to Use HDB
Step 4. If the HiSuite app is not installed on your phone, then the Windows app (HiSuite) will install it automatically on your phone.
Step 5. Finally, open HiSuite on your Huawei phone and enter the displayed 8-digit verification number into the verification number input box on the PC. Then, tap the “Connect Now” button.
You can connect your Huawei device to PC with a tap and thanks to Huawei Share OneHop. But, of course, there are some requirements:
If you meet these requirements, then follow the below steps:
Step 1: Turn on Bluetooth and Wi-Fi on your PC and run the PC Manager in the background.
Step 2: Swipe down your Huawei phone’s status bar to turn on NFC, Bluetooth, and Wi-Fi.
Step 3: Tap the NFC detection region on your phone to the Huawei share icon on your PC until the phone vibrates or rings.
Connect Huawei to a Computer via Tap
Step 4: Tap Connect on your Huawei phone, and then tap Authorize on your PC.
Bluetooth is one of the oldest ways to connect an Android device to a Windows PC. So, follow the below steps to learn how to connect Huawei to PC via Bluetooth:
Step 1: On your Huawei phone, just swipe down your phone’s status bar to enable “Bluetooth”.
Enable Bluetooth
Step 2: On your PC, use the search feature to enter Bluetooth settings. For that, type “Bluetooth” in the search field, click “Bluetooth Settings” and then, enable “Bluetooth”.
Connect Huawei to a Computer via Bluetooth
Step 3: Your Huawei phone should show in the list of nearby devices. So, choose your phone to connect it to your computer and that’s it.
If you’re using a Huawei or Honor laptop with PC manager installed, then you can go to “PC Manager”>” My Phone”>” Connect”. Your PC will begin searching for your Huawei phone. And follow the onscreen instructions to connect your phone to the computer.
If nothing above works to help you fix the Huawei not connecting to PC problem, then we recommend you try connecting your Huawei phone to PC using AnyDroid. This software comes in handy to manage your Android phone’s content on your computer. In short, it is an all-in-one Android data management solution that can even help you transfer the data between Android devices & computer, and between Android devices.
Below is a quick guide on how to use AnyDroid to connect your Huawei Phone to Windows PC. And at the same time, we demonstrate how to transfer photos from your Huawei phone to your computer with a few clicks.
Step 1. Download the AnyDroid from its official site on your computer. Once downloading the software, install and run it.
Step 2. Then, connect your Huawei phone to the computer. And AnyDroid lets you connect in two ways – USB Connection or Wi-Fi Connection.
Step 3. Once the software recognizes your Android phone, you will move to the main interface of the software. Here, you can select the function you want: Content to Computer, Add Content, or Files.
Click Device Manager and Choose Photos Category
Step 4. In the file management interface of the software, you can manage your data by using function icons in the upper right corner as shown below.
Connect Huawei to a Computer via AnyTrans for Android – Step 4
So, you now know several methods on how to connect Huawei to PC and what to do if your phone fails to recognize by PC. Nevertheless, we highly recommend you use DroidKit to fix Huawei not connecting to PC effectively and efficiently.
