Do you find the lock screen of your phone boring and think it can be put to better use? If yes, then you’ve arrived at the right place. In this article, we’ll introduce you to some of the best android lock screen apps out there and familiarize you with their key features. After reading this, your phone lock screen won’t be the same anymore.
Smartphones are the rage in present times and the majority of smartphone owners have their backs held by Android phones. Owing to the superb quality and affordable prices, android phones have gained major market dominance in the ever-growing smartphone market.
This increase in demand has also made a major market for customizable android lock screen apps. After reading this post, you’ll get acquainted with plenty of good options you can have for your android lock screen together with their features and functionality.
There’s no point in arguing that lock screen apps are the entry point to one’s phone. Hence, you should use those apps which ensure great functionality and interesting features. There are many lock screen apps available today that can transform the look and feel of your lock screen.
Some of the android lock screen apps provide many features and widgets which you can use to customize your lock screen. The screen lock feature available in most Android smartphones has some wallpapers or basic features which won’t be of much use to you.
Moreover, interfaces of some of the major Android smartphones give the option to have beautiful wallpaper carousels but they too have limited functionality. However, with all the below-listed android lock screen apps you can perform various actions directly from the screen. Now let’s jump right into discussing some of the best android lock screen apps out there.
With an awesome design and performance, AcDisplay is one of the best android lock screen apps available on the play store. The intuitive design lets you easily get comfortable with the interface of the app and understand the functionality. The specialty of the app is an Active Mode which enables you to have a distraction-free background and prioritize the notifications
Key Features:
Ava Lock Screen is undoubtedly among the best android lock screen apps out there due to its huge levels of customization and widgets library. The main screen has a notification panel and one can switch to the widget corner by swiping right. It comes with an ad-free guarantee and runs over the existing android security features such as pin and pattern. With the huge amount of possible customization, you can change notification styles, clock designs, and even shortcuts as per your taste.
Key Features:
With a lightweight app size and a comparatively affordable pro version, Hi Locker is a good substitute yo your good old android lock screen. It not only provides you a fair control of the lock screen environment but also allows you to customize all the elements and widgets with different designs. One of the best offerings Hi Locker provides you is to display a custom message on your lock screen without any kind of word limit.
Key Features:
Wave is another great option for android lock screen apps because it has various useful features. It gives you a fresh customizable lock screen for your Android device. To enhance security, it offers multiple locking methods such as fingerprint, pattern, and PIN. You can pick any of the locking methods for your phone.
Key Features:
Solo Locker is an android lock screen apps that is available with multiple styles and features. It is an app with a custom lock pattern, interface, and wallpapers. It gives you quick access to your frequent apps displayed on the lock screen of your mobile phone. It has a lock screen with an informative tool that displays a notification, weather, news, timer, etc.
Key Features:
Sometimes you need to instantly reply to a message, but to do so you first need to unlock your phone then go to the messaging app, and then only you can reply to that particular message. Floatify is an android lock screen apps that let you reply to the messages from your lock screen. It allows you to customize your lock screen.
Key Features:
The lock screen of Android phones generally displays two apps on each bottom corner of the screen. Most of the time these apps are Phone and Camera, as they are most apps on a phone. But what if users need to use some other app constantly and what it to be on your lock screen.
Here are the steps to how you can put these apps on your lock screen.
Step 1. Switch to Apps sections from home screen.
Step 2. Go to Settings.
Step 3. Find Lock Screen and Security and tap on it.
Step 4. Click Info and App Shortcut.
Step 5. Click on App Shortcut.
Step 6. Tap on Left Shortcut.
Step 7. Scroll your screen to view all the apps available on your screen. Choose any app that you want on your lock screen.
Step 8. Tap on Right Shortcut.
Step 9. Scroll your screen to view all the apps available on your screen. Choose any app that you want on your lock screen.
Step 10. Now, lock the phone and check the lock screen apps. You will get the desired apps.
DroidKit is a complete Android solution that can remove any type of screen lock such as 4-digit PIN, 6-digit PIN, custom PIN, password, pattern, fingerprint, etc.
Step 1. Free download the Android lock screen removal apk – DroidKit. Tap on Screen Unlocker on the homepage.
Step 2. Connect your Android phone to the computer and tap on the Start button to initiate the process.
Step 3. When the configuration file is prepared you can click on Remove Now.
Step 4. Choose the corresponding brand or your Android phone and follow the on-screen instructions to remove the password.
Step 5. Wait for a few minutes until you see the Screen Lock Removal Completed page.
All these lock screens have different features and different layouts. These are some of the android lock screen apps that you can use according to their efficiency and your choice. These lock screen apps help you protect your phone and its data from others. Compared to the monotonous functions of other apps, DroidKit not only helps you to remove screen lock quickly, but also helps you to recover lost data easily, fix black screen of Android phone, etc. Just download and have a try.
