If you have a Xiaomi phone and it’s not charging, worry not! In this article, we have rounded up the reasons why is your Xiaomi not charging, followed by 5 tried-and-tested ways to resolve the issue.
Are you having trouble charging your Xiaomi phone? Don’t worry, you’re not alone! Many Xiaomi users experience this issue sometimes. But the good news is that there are many reasons why this might happen, and most of them can be fixed easily.
In this guide, we’ll help you find out what’s causing your phone to not charge and walk you through some simple troubleshooting steps to get your phone back in action. We’ll cover everything from faulty chargers to software glitches so you can identify the problem behind Xiaomi not charging and get your phone up and running again.
There are a couple of reasons why your Xiaomi phone might not be charging. Here are the most common ones:
Now that you know the common reasons why your Xiaomi device might not be charging, let’s have a detailed look at how to fix it
Your Xiaomi phone refusing to charge can be a real buzzkill! But before you throw it across the room (don’t do that!), here are 5 simple troubleshooting methods to get your phone working again:
This might seem obvious, but it is the most common reason behind Xiaomi not charging.
Examine your charging cable for any cuts, frays, or damage to the connector. These can prevent a good connection and stop your phone from charging. Try using a different cable, preferably the original one that came with your phone, to see if that solves the problem.
Sometimes, a simple restart can work wonders! It can clear temporary software glitches that might be interfering with the charging process. Here’s how to restart your Xiaomi phone:
Over time, dust, lint, and other debris can build up in the charging port, creating a barrier that prevents a secure connection.
So, grab a soft-bristled brush (like a toothbrush you don’t use anymore) and gently clean the port to remove any gunk. Be careful not to shove anything sharp or metallic inside, as that could damage the delicate pins.
If a restart didn’t fix the problem, there might be a more stubborn software issue! In this case, you’ll need to use a professional Android system repair tool, like DroidKit. DroidKit is a software designed to help you solve almost all problems with your Android devices. The best part about this tool is that you can use it to get the job done without needing to root your device, so it is much more safe than other Android reapir tools. All Android systems are supported, including Android 14. You can learn more about DroidKit below.
Now you can follow the steps below to fix Xiaomi not charging issue with ease.
Step 1. Download and install DroidKit on your PC, and select System Fix from the interface.
Step 2. Connect your Xiaomi device to the PC using a USB cable, and click Start.
Step 3. Then you need to follow the instrcustions on the screen to put your device into recovery mode.
Step 4. Download the firmware and then click Fix Now to resolve any underlying system issues.
Step 5. It will take a few minutes for DroidKit to fix the OS, after which your Xiaomi phone will restart.
Sometimes, outdated software can have bugs that affect the charging process. Updating your phone to the latest version can fix these bugs and ensure your phone is using the most recent charging protocols for optimal performance. To check for software updates, follow these steps:
Don’t let a dead battery bring your Xiaomi phone down! By following the 5 simple troubleshooting steps discussed in this guide, you should be able to identify the reason behind your Xiaomi not charging and get your phone up and running in no time. These solutions are easy to implement and can get you back to using your phone worry-free. And if the issue is caused by system errors, just free download DroidKit to fix it immediately.
However, if none of these methods work, it might be time to consult a professional or consider a battery replacement. Remember, early detection and intervention are key to keeping your Xiaomi phone powered up and running smoothly!
