If you frequently experience issues on your Android device, you need to find the best Android system repair app and use it to fix your issues once and for all. If you are not sure what a good app is to do this, here we list some of the best Android repair software for you.
Download DroidKit to repair your Android system without data loss. No need to root your device. No technical skills are required. Free download it to repair Android system issues on Windows and Mac.
Any phone may encounter some system issues from time to time. Android users can experience different types of errors, such as AndroidOS suddenly crashing, Samsung stuck in a black screen, a watered phone system, Android OS flashing failed, etc. If you are experiencing this, you will probably want to find an app that can repair Android issues and get your phone back to normal.
Luckily, here in this post, we will show you what is the best Android repair tool, and how to use Android system repair with ease. Now, pick the suitable Android system repair software for PCs for you.
Keep in mind that hardware problems cannot be resolved using the software. Therefore, you first need to make sure the issue you are experiencing is due to a software problem on your phone.
Many issues like app crashing, the phone getting frozen, and misbehaving tools are related to your phone’s software. If you have any of these issues, you likely have a software problem.
Android has a few apps to let you scan and find software issues on your phone. You can grab one of these apps from the Play Store and let it find software problems on your device.
When it comes to choosing the best Android repair app, some criteria are applied. Here are some of those factors.
Fortunately, some Android repair tools meet these criteria. These Android repair software are sure to help you fix many types of issues on your Android-based devices.
DroidKit Android system repair allows you to repair Android system problems like Android black screen, Xiaomi touch screen not working, Samsung logo stuck, Samsung phone not charging, etc. You can also repair system issues without root. DroidKit is a complete Android solution for you, which enables you to recover lost data, unlock a locked Android screen, clear cache files, etc. Therefore, you can not only repair software problems on your device but also revive your phone from a locked screen, sluggish device, data loss, etc.
Supported AndroidOS: Android 6 to 15
Step 1. Free get DroidKit and launch it on your computer > Tap on the System Fix mode.
Click System Fix Function
Step 2. Once DroidKit detects your device, click the Start button to continue. DroidKit will match the PDA code of your Samsung Device Automatically > Then click Download Now to download the firmware.
PDA Code Matched
Note: If there is no matching PAD code, you need to put your device into recovery mode and get PDA code.
Step 3. Put your device into Download mode. Once finished, it will automatically start repairing your Android system. After completing the repair process, you will get the system fixed successfully page as below. All the system issues are fixed and your Android device will be restarted.
Completing the Repair Process
Dr. Fone – System Repair (Android) focuses on helping you resolve nearly all kinds of issues rather than some specific ones on your Android devices. Whether you are experiencing a serious issue like the black screen of death, or you have a minor issue like the Play Store not working, this app can fix all those issues for you.
Dr. Fone Android Repair Software
Features
Supported Devices: Android 2.0 or later
Advantages:
Disadvantages:
Repair System for Android is an Android repair app that you can install on your Android device and be able to fix many issues. There are issues like your CPU temperature suddenly going up, your phone experiencing sudden slowdowns, and your phone’s RAM suddenly getting filled up. With this app, you can fix all these issues in a few taps.
Features
Supported Devices: Android 4.2 or later
Advantages:
Disadvantages:
Fixppo for Android is similar to other Android repair tools and you can use this app to fix dozens of issues on your Android device. This app lets you resolve Android turn-on/off issues, black and white screen issues, stuck issues, touch screen issues, as well as any other kind of issues that you can potentially experience on your phone.
Fixppo Repair Android System
Features
Supported Devices: Android 2.0 to Android 9.0
Advantages:
Disadvantages:
To fix issues, you need to know what issues exist on your Android device. This is what the Phone Doctor Plus app tells you about. Phone Doctor Plus is also a good Android repair software. This app scans your device for issues and lets you find out about them so you can get issues fixed. Your phone often has many issues that you are not aware of, but this app quickly recognizes those problems and notifies you about them.
Phone Doctor Plus
Features
Advantages:
Disadvantages:
All-in-One Toolbox is a powerful Android system toolkit. It can be your good assistant such as a junk cleaner, speed booster, memory optimizer, battery optimizer, CPU cooler, app manager, file manager, etc.
All-in-One Toolbox
Features
Advantages:
Disadvantages:
As a powerful Android software, Greenify keeps your Android phone system in a good situation. With Greenify, never should your Android devices become slower and battery hungrier after lots of apps are installed.
Greenify Interface
Features
Advantages:
Disadvantages:
For Android system repair, Assistant for Android is also a good choice. To help users manage Android phones well, Assistant for Android is equipped with 18 features, such as CPU monitor, Process Manager, Cache/System Cleaner, Power Saver, File Manager, Startup Manager, etc.
Features
Advantages:
Disadvantages:
Feature | DroidKit | Dr. Fone – System Repair (Android) | Repair System for Android | Fixppo for Android | Phone Doctor Plus | All-in-One Toolbox | Greenify | Assistant for Android |
Fix system issues | Yes | Yes | Yes | Yes | No | No | No | No |
Wide device support | Yes | Yes | No | No | No | Yes | Yes | Yes |
Success rate | High | High | Low | Moderate | Low | Moderate | Moderate | Low |
Speed | Fast | Fast | Moderate | Fast | Fast | Fast | Fast | Moderate |
Data Loss | No | Yes | No | Yes | No | No | No | No |
Rating | ★★★★★ | ★★★★ | ★★★ | ★★★ | ★★ | ★★★★ | ★★★★ | ★★★★ |
If you are wondering how to fix corrupted software on your Android device, the Android repair tools above should help you do that on your phones and tablets. As the table above shows, DroidKit is undoubtedly the best choice, why not download and try it out now?
