SP Flash Tool Download & Use [2025 Ultimate Guide]
Do you own a MediaTek Android device and want to upgrade its firmware? SP Flash Tool can do so to revive a dead device. This guide will also focus on the SP Flash Tool and its alternatives. Moreover, we suggest using DroidKit to reinstall your Android software if you are looking for an alternative.
Author Avatar Joy Taylor Last Updated: Feb. 05, 2025
Do you want to download or upgrade firmware from your mobile phone or tablet or fix your dead Android device? The SP Flash Tool can help!  In this article, you will find detailed instructions on downloading and using the SP Flash Tool. If you don’t want to deal with the complex or hard-to-use interface– DroidKit is here! It can solve all Android-related issues, such as FRP bypass, screen unlocking, and firmware updates. So, let’s begin to explore this!
Also Read: Best Android flashing tools
What is the SP Flash Tool?
SP Flash Tool is an application that allows you to flash firmware and custom ROM on Android devices with MediaTek-powered Android devices. It assists users in downloading the newer version of their devices, fixing or reviving their devices from any software problems, and configuring recovery systems.
The main functions of this tool are firmware flashing, which enables the installation of the latest updates; custom ROM support, which allows the installation of a modified version of Android; and backup and restore to prevent the user’s data from being lost during the flashing process. It is also compatible with multiple operating systems, such as Windows, Linux, and even MacOS.
Main Features of SP Flash Tool
Updating MediaTek devices is effortless, thanks to the SP Flash Tool’s incredible capabilities. It simplifies the process of installing or changing software, especially for non-techies. Some of its key features are:
  • Firmware Flashing: With the help of this program, you will be able to update and improve the performance of your device’s software.
  • Custom ROM Support: The option enables users to incorporate modified versions of an Android system that will help improve the interface on the device.
  • Backup and Restore: This feature also helps you avoid loss since you can make copies of important data before making any changes.
  • Multiple Format Support: It can accept different types of files, such as .img and .bin files, which makes it flexible to a lot of settings.
  • Ease of Use: The program comes with buttons and menus that are easy for anyone to understand and use.
  • Multimedia Broadcast and Connectivity Systems: It supports many MediaTek devices and is suitable for many individuals.
How to Download & Use SP Flash Tool
Many of you might find it difficult to download the SP Flash Tool. Worry not, as we’re here to help. Here’s a step-by-step guide to downloading the SP Flash Tool and using it:
Step 1. Download the latest version of the SP Flash tool from the official site.
Step 2. Install the required drivers for your device and make sure they are updated.
Step 3. Unzip the SP Flash Tool file you downloaded. Then, find and double-click on “flash_tool.exe” to open the program.
Step 4. In the SP Flash Tool window, look for the option labeled “Scatter-loading File.” Click on it and select the “Android_scatter.txt” file from the folder where your firmware is stored.
Locate the Download in SP Flash Tool
Step 5. Choose the “Download Only” option to prepare to download the firmware.
Step 6. Connect your mobile and computer through a USB cable. Your mobile must be turned off before connecting.
Step 7. Once you connect the phone, the flashing process will start automatically.
Step 8. Wait a moment. When the download is complete, a green checkmark will appear on your screen, indicating that everything worked well.
Download the Firmware in SP Flash Tool
Step 9. Now disconnect the USB cable and turn on your phone. It should work perfectly.
If the process stops at any time, select the “Format All + Download” option and repeat the previous steps carefully.
SP Flash Tool has complicated and technical steps, making it challenging for users to flash or repair Android devices. As an easier alternative, DroidKit offers a more user-friendly solution with simple steps for flashing, system repair, and data recovery, catering to those who want a hassle-free experience.
Best Alternative to SP Flash Tool – DroidKit System Reinstall
DroidKit, as a powerful Android device manager, allows you to upgrade or reinstall your Android OS without complex steps. With DroidKit, even if your phone has issues, you can fix them without technical knowledge.
Moreover, the FRP Bypass function in DroidKit lets you bypass Google verification, and the System Fix feature helps repair system problems like freezing or crashing. Furthermore, there are plenty of other features to revive a dead or bricked device, such as a Data Extractor to recover files from a dead Android device and a System Fix to solve all other issues without rooting the device.
Key Features:
  • You can install the desired OS via the System Reinstall feature.
  • No need to download the right ROM and find the flash tool, as DroidKit will do it all.
  • There is no need to root the device to reinstall the operating system.
  • You can unlock the locked screen of your Android device without worrying about losing any crucial files or data.
  • Organize your Android files easily and move them from your phone to other devices.
  • Remove unnecessary junk files to increase your Android device’s capacity and general efficiency.
Now, let’s explore the simple steps to use the Droidkit Reinstall feature:
Step 1. Download and install DroidKit on your computer. Open it, and click on “System Reinstall.”
Choose System Reinstall Function
Step 2. Press the “Start” button, and connect your Android device. The tool will automatically find the right system version for your device.
Start System Reinstall in DroidKit
Step 3. Select the version you want to download, then wait patiently while the firmware downloads.
Confirm and Download the Firmware
Step 4. Once the download is complete, click “Start to Reinstall” to reinstall the system.
Step 5. Put your device in Download Mode.
Put the Device in Download Mode
Step 6. After putting your device into Download Mode, click “Next.” Disconnect and reconnect your device when prompted.
Step 7. Wait for the process to complete. Keep your device connected during the process. Once done, your device will restart with the new system installed.
DroidKit System Reinstall Finished
Due to its complex procedures, the SP Flash Tool might be difficult for novices to use for flashing firmware or repairing Android devices. It’s a fantastic choice for people comfortable with more involved procedures, but DroidKit is a great substitute if you’re searching for anything simpler. It offers a simple way to reinstall or upgrade the system without any hassle of rooting the device. For anyone wanting a straightforward and user-friendly tool, DroidKit makes fixing Android devices much easier.
