Fast charging not working with your Samsung device? If so, it’s nothing to worry about, as you’ve made it to the best platform where all Samsung troubleshooting methods are readily available. Discover the 10 simple hacks to fix Samsung fast charging not working here in this post.
Samsung is well-known for its mind-blowing innovations. With the recent fast charging technology tucked into its mobile devices, you don’t have to wait all day for your Samsung phone to be fully charged.
While the fast charging feature is highly appreciated, it isn’t without its loophole, as there are instances where it can stop working. If you’ve experienced Samsung fast charging not working on your device, and need to fix it, then you are in the right place.
In this post, we will look at the possible reasons why Samsung fast charging is not working. In addition, we discuss how to fix the issue without compromising your device.
The Samsung fast charging feature should work with your device, so far your device supports the feature, and you have the right charger at hand. However, if it doesn’t, then it could be because of the following:
For fast charging to work with your Samsung phone, you must have enabled the feature on the device. Failure to do that means you cannot use the feature with your device.
As we all know, the fast charging feature is a tech that comes with the recent OS. Folks who aren’t running their devices on the updated OS cannot enjoy the benefits of fast charging. So you need to check your device OS and confirm it’s up to date, and if not, install the update.
There are several hardware issues that can cause your Samsung device not to fast charge. From damaged flex to spoilt charging points, and more. In a case like this, you need to meet with a competent technician to help you fix your device.
Fix Samsung fast charging not working issues on your device by employing any of the solutions below:
One of the primary reasons why fast charging isn’t working on your Android or Samsung device could be that you haven’t enabled the feature on it, just as mentioned above. The best way to resolve this is to navigate to the right panel on your phone to activate the feature.
You can simply get that done by applying the stepwise guide below:
Enable Samsung Fast Charging
Samsung has its own knob (also known as an adapter) and knob which is capable of charging your device to the highest battery life within the shortest possible time. Should you use something contrary, your device may charge at a slow rate, which can be frustrating. So we advise that you use the right adapter and charger.
Should the solutions above fail to work for your device, kindly consider checking the battery life, there could be a problem with it. Sometimes, you might have abused the battery by the continuous connection to power, which weakens it. When such happens, your device takes time to charge.
The best way to resolve this is to change the battery. However, before then, we advise that you uh h check the battery health of the corresponding device, just to confirm it’s the battery. Here’s how you can do that on your Samsung phone:
Check Samsung Battery Health
If the battery health shows Good, then there’s nothing to panic about. But if it shows otherwise, then you consider buying another one.
Have you activated the USB Debugging feature on your Samsung device in the past? If yes, you may suffer Samsung fast charging not working issues. Fixing this requires that you disable USB Debugging on your device.
The approach to this is given down here:
Disable USB Debugging Mode
Did you notice Samsung fast charging not working after installing or launching an app on your phone? There’s a possibility the app is slowing down operations on your device, which can affect the charging speed.
To verify this, kindly boot your phone to Safe Mode, and check if fasting charging is working or not. Here’s how to boot a Samsung device to Safe Mode:
Put Phone into Safe Mode
The OS of any smartphone or computer system plays a crucial role in its functionality, which is why an update is usually required. You need to update your Samsung OS occasionally to boost the performance, and enjoy the latest benefits configured to it.
Failure to install the latest update may result in Samsung fast charging not working issues, and other critical problems which you don’t want to deal with. To avoid that, apply the procedure below to download and install the latest update for your device:
Check Software Update on Android
Factory Reset should come in handy if the aforementioned solutions fail to work. You can reset your Samsung phone to fix fast charging not working issues by following the instructions below:
Perform Factory Reset
If the above solutions don’t work, then DroidKit is the functional tool you can try to fix your Samsung. With this software, you can easily repair an Android system by simply downloading a compatible firmware package to scan, and fix your device without crashing it.
More than fast charging not working, it also can fix various Samsung OS problems, including Samsung tablet black screen, touch screen not working, apps keep crashing, etc. And this software works for all Samsung models, and it’s very simple to use.
Now, follow the steps below to repair your device in a few simple steps:
Step 1. Get the latest version of DroidKit – Android System Repair on your computer.
Step 2. Launch DroidKit > Connect your Android device and tap on the System Fix Issues function.
Click System Fix Function
Step 3. Once DroidKit detected your device, click the Start button to continue.
Start to Repair Samsung Phone
Step 4. DroidKit will match the PDA code of your Samsung Device Automatically > Then click Download Now to download the firmware.
PDA Code Matched
If there is no matching PAD code, you need to put your device into recovery mode and get PDA code.
Step 5. After firmware is downloaded, click Fix Now button.
Firmware Downloaded and Click Fix Now
Step 6. Put your device into download mode.
Step 7. Once finished, it will automatically start repairing your Samsung system. After completing the repair process, you will get System Fixed Successfully page as below. All the system issues will be fixed and your Android device will be restarted.
Completing the Repair Process
System cache could be a major problem to your device, when there are too many of them. If your device is filled with several cache, the performance reduces, which in turn compromises it. To fix this, you have to clear the system cache.
Here’s how to wipe system cache on a Samsung device to enhance the charge speed:
Do the above for all of the apps appearing on your screen, and the system cache will wipe away immediately.
Lastly, we recommend that you check your battery settings to fix Samsung fast charging not working. It could be that you’ve activate low power mode on your device which slows down the charging speed.
Should such happen, try deactivating low power mode and your device, so your device can fast charge.
Enabling fast charging is pretty easy to activate on a Samsung device. You can do that by simply heading to Settings, select Battery and device care, then tap on Battery > More battery settings.
A new page will come up, just toggle the sliders for the options underneath Charging right to activate fast charging, and that’s all.
Your Samsung device should charge at optimal speed, however, there are scenarios where otherwise may occur, and your phone will charge slowly. There are several reasons for this, ranging from hardware issues, to OS/firmware issues, poor settings, and more. Sometimes it could be because you are using the wrong charger for your device.
Obviously, fast charging is one of the best selling features that has been integrated into Samsung devices. An error or issue with the feature can frustrate the corresponding user. However, with the solutions above, you need not worry. Just select any one of the solutions to fix Samsung fast charging not working., that’s all.
Mind you, the most recommended solution involves DroidKit software. The software offers a quick and straightforward solution to fix your Samsung phone without compromising it.
