Is your Samsung A72 touch screen not working? How to fix this issue? Don’t worry! This article provides several solutions to fix touch screen issues. Just read now.
The Samsung Galaxy A72 is a mid-range smartphone that boasts impressive features such as a 6.7-inch Super AMOLED display, a quad-camera setup, and a long-lasting 5000mAh battery. Running on the latest Android version, it offers a seamless user experience with new features like enhanced security and improved performance. However, like any other device, it can sometimes encounter issues, one of which is an unresponsive touch screen.
An unresponsive touch screen can be frustrating, especially when you rely on your device for daily tasks. Whether it’s due to a software glitch or physical damage, there are various solutions to get your touch screen working again. This guide will walk you through several methods to troubleshoot and resolve touch screen issues on your Samsung A72.
There are several reasons why the touch screen on your Samsung A72 might stop working. Common causes include:
Restarting your device can resolve minor software issues that may cause the touch screen to become unresponsive.
Restart Samsung Phone
Remove any case or screen protector that might be affecting the touch sensitivity. Sometimes, accessories can interfere with the screen’s responsiveness.
Optimizing your device’s performance can help resolve touch screen issues by ensuring your phone runs smoothly and efficiently.
This process will close unused apps, clear cache, and optimize your device’s overall performance, which can help improve touch screen responsiveness.
If the touch screen issue persists, you can use DroidKit to fix system problems. DroidKit is a comprehensive Android toolkit designed to resolve various issues that may affect your device, including the unresponsive touch screen problem on your Samsung A72. Its System Fix feature is designed to address numerous Android OS issues, ensuring your device runs smoothly and efficiently. Here are some main features:
To fix Samsung a72 touch screen not working using DroidKit, follow these steps:
Step 1. Download and install DroidKit from the official website. Launch DroidKit and choose the System Fix option on the home screen.
Click System Fix Function
Step 2. Connect your Samsung A72 to the computer using a USB cable. Click Start to proceed.
Start to Repair Android System
Step 3. The program will automatically match the PDA code of your Samsung device. Click Download Now to acquire the necessary firmware.
PDA Code Matched
Step 4. After the firmware is downloaded, click Fix Now and put your device in download mode by following the on-screen instructions.
Step 5. DroidKit will begin repairing your system immediately. Wait for the process to complete, and a success page will be displayed.
Completing the Repair Process
Keeping your Samsung A72’s software up to date can often resolve touch screen issues caused by software bugs or incompatibilities.
Click on the Software Update
Sometimes, the touch sensitivity settings on your Samsung A72 might cause responsiveness issues. Disabling this feature can help improve touch screen performance.
Disable Touch Sensitivity
Booting your device into Recovery Mode allows you to perform system-level troubleshooting that can resolve touch screen issues.
Wipe Cache Partition
If other methods fail, a factory reset can resolve persistent touch screen problems by restoring your device to its original settings. Note that this will erase all data on your device.
tap on Factory Data Reset when the next screen appears
If your Samsung A72 touch screen is still not working after trying all the software fixes, there may be physical damage to the device. This can include issues such as a cracked screen, internal hardware damage, or problems with the digitizer. In this situation, just take your device to an authorized Samsung service center or a reputable repair shop. Professionals can diagnose and fix hardware issues accurately.
Samsung a72 touch screen not working can be inconvenient, but they are often resolvable with the right approach. Whether it’s a simple restart, a system fix using DroidKit, or a factory reset, there are multiple ways to get your device back to normal. By following the steps outlined in this guide, you can troubleshoot and fix the touch screen problems on your Samsung A72 effectively.
