If you’re struggling with Samsung A71 not charging, this guide is for you. We have provided common reasons for this issue and their solutions. You will find effective methods here. We have also included an effective solution using DroidKit.
Have you plugged in your Samsung A71, only to find that it won’t charge? No charging icon, no battery percentage going up—just a blank screen. It’s frustrating, especially when you rely on your phone so much.
Don’t worry! Many people face the same problem. This step-by-step guide will help you fix this issue. In this guide, we will walk you through easy steps to solve the “Samsung A71 not charging” problem. One powerful tool that can help you fix this problem quickly is DroidKit. We’ll show you how to use DroidKit to resolve this problem effortlessly.
Let’s start and get your Samsung A71 charging again!
The “Samsung A71 not charging” issue leaves users unable to use their phone. If you rely on your phone for everyday tasks, this issue is really frustrating.
It is important to understand the problem before trying to fix it. There are a few reasons that cause the issue:
In the earlier section, we discussed common reasons for the “Samsung A71 not charging” issue. DroidKit is an easy-to-implement solution if some software problems cause the issue. Let’s start with using DroidKit to solve the problem in seconds.
DroidKit is an all-in-one solution for almost all problems related to Android phones. Its key features are listed below.
Let’s learn to use DroidKit for a quick system fix and resolve the Samsung A71 not charging issue.
Step 1. Download the software and install it on your computer. Turn On USB Debugging mode on your Samsung A71 and connect it to your computer.
Step 2. Launch DroidKit on your computer and select “System Fix” from the first screen that appears.
Step 3. If the connection works fine and the phone is detected, click “Start.”
Step 4. Click “Download Now,” and DroidKit will download the firmware package for your device.
Step 5. After the download is complete, follow the instructions on the DroidKit screen and put the Samsung A71 into download mode. Once done, click “Next”. DroidKit will now automatically start the Android system repair process. Wait for a while. Once the repair process is complete, you will see the screen below.
Check if your Samsung A71 has started charging now.
First, make sure you’re using an official charger and cable for charging. Chargers may look similar, but there is a difference between the voltage and power they deliver.
If you’re already using an official charger, check for any damages to the cable or adapter. If you notice any damage, stop using them. Even if there are no signs of damage, you can check their performance by connecting them to a different phone.
If the adapter and cable are working fine, then change the power socket. If the phone starts charging after changing the power source, the problem is likely with the original socket or port.
If the phone still doesn’t respond to the charger, move on to the next solution.
Dirt, lint, or debris stuck in the charging jack is usually the reason for the Samsung A71 not charging issue.
Step 1. Power off your mobile phone.
Step 2. Use a torch light to see inside the charging port of your device.
Step 3. Check if metal charging contacts are covered with dirt.
Step 4. Gently blow inside the charging port to remove the dust. You can also use an electronics duster spray.
Step 5. Seek professional help if the port is still clogged.
If the phone is still not charging, let’s try another solution.
Sometimes, minor glitches and settings cause the phone to misbehave. A simple reboot clears these temporary issues that are the reason your phone is not charging.
Restart your phone from the power options available or try to force restart it.
Step 1. Press and hold the Volume Down and Power button.
Step 2. Press until the Samsung logo appears.
Step 3. Your phone will now restart, so check if the charging is working.
Sometimes, third-party apps have settings that might stop your phone from charging. Turning on the phone in safe mode stops the interference from third-party apps.
Step 1. Tap on the “Power Options” button in the drop-down settings menu.
Step 2. Tap and hold the “Power Off” button.
Step 3. The “Safe Mode” option will appear. Tap this option to start the phone in safe mode.
Step 4. After the phone turns ON in safe mode, check whether it is charging now.
If the phone is still not charging, try the next solution.
Sometimes, an outdated OS causes problems with various phone functions, including charging. Software updates often include fixes for issues, performance improvements, and security patches. Updates resolve bugs affecting your Samsung A71’s ability to charge appropriately.
Step 1. Click the gear icon to open “Settings”.
Step 2. Scroll down and tap “Software Update.”
Step 3. Tap “Download and Install.”
Step 4. Your Phone will now download and install the updates. After the process is complete, check whether your phone is charging properly.
If nothing works, your mobile phone may have a hardware problem. In this case, you should contact a professional who can access the device and repair the fault.
This guide provides several easy ways to fix the “Samsung A71 not charging” problem. You can try everything from checking your charger to updating your phone or using a tool like DroidKit. DroidKit is a helpful tool for fixing software issues in Android phones without any technical skills. It usually solves minor issues. Follow these steps to get your Samsung A71 charging again in no time.
If these methods don’t work, you should seek professional help to check for hardware problems.
