“I have an A51 Samsung and it won’t charge. It is dead and I need everything on it transferred to my new phone. What do I do?” – A user asked on Quora.
The Samsung A51 is a popular mid-range smartphone known for its balance of performance and affordability. However, like any electronic device, it can encounter issues, one of the most frustrating things can be the Samsung A51 not charging. But don’t worry, whether you’re dealing with slow charging, intermittent charging, or no charging at all, these problems will disrupt your day and hinder your productivity. This article will guide you through five practical solutions to fix your Samsung A51 charging issues.
One of the simplest yet often overlooked solutions is to try a different charging cable. Over time, charging cables can wear out, leading to poor connectivity or no connection at all. So check your charging cable, if there is something wrong, then try a new one.
Steps to Try Another Charging Cable:
Dust, lint, and debris can accumulate in the charging port of your Samsung A51, obstructing the connection between the cable and the port. But don’t worry, there are three steps to help you clean your charging port with ease.
Steps to Clean the Charging Port:
If cleaning the charging port or using a different cable doesn’t solve the issue, consider using a wireless charger. This method bypasses the charging port altogether. Here is how you can do it.
Steps to Use a Wireless Changer:
If your Samsung A51 charges well on a wireless charger, then the problem can be caused by your wired charger or the charging port. You can go to the support and get it repaired. If it’s not charging on the wireless charger, you can check the following ways.
Sometimes, software glitches can cause charging issues. Performing a hard reset can resolve these problems by restarting the device and clearing any temporary bugs. Now, you can follow some steps to reset your Samsung A51.
Steps to Reset Samsung A5:
Here is the full guide on hard reset Samsung phones you can check.
If none of the previous methods work, the issue might be system-related. Using a system repair tool like DroidKit can help fix underlying software issues that affect Samsung A51 charging.
DroidKit System Repair can help fix common Android system issues for Samsung, Xiaomi, Redmi, and POCO. It’s good at fixing touch screen not working on Xiaomi, Samsung not charging, Redmi stuck on boot loop, etc. DroidKit is worth trying if your Samsung A51 not charging due to some system failures.
Steps to Use Droidkit to Fix Samsung A51 System:
Step 1. Download and install DroidKit. Next, use a USB cable to connect your phone to the computer.
Step 2. Launch it on your computer and select System Fix mode.
Click System Fix Function
Step 3. Wait for Droidkit to detect your device and next click on the Start button. Now the program starts to download the firmware page. As it completes, click the Fix Now button.
Start to Repair Android System
Step 4. Follow the on-screen instructions to put your device in download mode and click Next.
Step 5. After downloading and verifying the firmware, DroidKit will automatically start repairing your Android system. You will see the interface below as the process completes, and your Android device will be restarted.
Completing the Repair Process
After the system repair, try charging your Samsung A51 again to see if the issue is resolved.
1. Why is my Samsung A51 plugged in but not charging?
There could be several reasons why your Samsung A51 is plugged in but not charging:
2. How do I know if my Samsung A51 charger port is damaged?
Signs of a damaged charger port include:
3. How to fix Samsung A51 fast charging not working?
If fast charging isn’t working:
You can also refer to the fix Android fast charging not working guide for more solutions.
Charging issues with your Samsung A51 can be frustrating, but there are several effective solutions you can try. From using a different cable to performing a hard reset or even using a wireless charger, these methods can help resolve most charging problems. If the issue persists, consider using a system repair tool like DroidKit to fix any underlying software problems. By following the steps outlined in this guide, you can restore your Samsung A51’s charging functionality and keep your device running smoothly.
