[9 Fixes!] Reasons Why Pixel Screen Turned Green
Seeing your Google Pixel screen turned green can be annoying, especially when you haven’t done anything out of place. This post will walk you through the potential reasons for the underlying issue and how to fix it.
Author Avatar Joy Taylor Last Updated: Mar. 06, 2024
Hello, I received the prompt to update my Google Pixel 7 to Android 14.0 which I did. Unfortunately, my device started displaying a green screen after installing the update. I don’t know the reason for this. Please, if you have any clue why my Pixel screen turned green and how to fix the underlying issue, kindly help.”
Google Pixel is one of the best smartphones to own. From the sleek design to the wonderful battery life, high-resolution camera, and lots more. Despite these qualities, this device isn’t without its fair share of issues as users now complain about the green coloration discovered on their screens just like we have in the scenario above.
Are you having a similar issue and seeking the appropriate solutions? You’ve made it to the right webpage. This post presents you with everything about Pixel screen turning green issues. Stick around as we walk you through.
What Does It Mean when Pixel Screen Turns Green?
When your Google Pixel device displays a green screen, it simply means there is something wrong with the device. We cannot pinpoint the exact reason why you experience this, but it could arise from wrong configuration settings, software and hardware issues. The next section of this post will discuss why your Pixel screen turned green.
Why Pixel Screen Turned Green?
The green coloration displayed on your Google Pixel screen could be seen because of the following:
  • Wrong Configuration Settings
Sometimes you experience Pixel screen turned green issues when you make alterations to your display settings.
  • Software Issues
The underlying issue can be attributed to software issues such as corrupt drivers and outdated operating systems. You can also experience a green screen when you install a beta version of your Android OS on Pixel.
  • Hardware Issues
Damaged screens, malfunctioning graphics chips, liquid penetration into LEDs, and more are hardware issues that can cause your Pixel screen to turn green.
9 Ways to Fix Pixel Screen Turned Green After Android 14 Update
Clear Pixel screen turned screen issues without hassles by applying one or more of the solutions listed down here:
Method 1. Reboot Pixel Phone
To begin with, we suggest rebooting the Pixel phone to resolve the issue you are faced with. By rebooting we mean turning the phone off and on. Employing this solution fixes a plethora of issues, such as glitches, bugs/errors, and more, that are causing your device to malfunction.
You can reboot your Pixel phone by following these steps below:
  • Locate the power button on the side of your phone or the top and press it down.
  • Next, the power icons will automatically come up on your phone.
  • Select Reboot or Restart depending on the options displayed on your screen.
  • Now, your Pixel phone will go off for a while and afterwards, it will come up again.
Method 2. Check If Night Light is Enabled
Night light is a built-in feature designed to help you manage the amount of light rays emitted from your Pixel phone. Turning on this feature changes the coloration of the light displayed by your device to green. To resolve the underlying issue, it’s best if you deactivate the feature. Following the simple instructions below can help you get this done:
  • Tap on the cogwheel icon on your Android phone to launch Settings
  • Scroll down to the path where you have Display and click on the corresponding ion.
  • Head to where you have the Night Light tab, click on it and disable the feature from operation.
  • After completing this, the green screen will be rectified.
Method 3. Disable Adaptive Brightness and Adaptive Color Features
Adaptive brightness and adaptive color feature has a significant effect on how your display screen would appear. Study showed that when you activate both features your screen turns green. So when you encounter the underlying issue and the aforementioned solutions fail to work, then deactivating adaptive brightness and adaptive color should come in handy.
Follow the illustrative guide down here to disable adaptive brightness and adaptive color on your Pixel phone:
  • Head to the Settings panel on your phone by hitting the cogwheel icon.
  • Swipe through the options and tap on Display
  • Proceed to the section where you have the Adaptive Brightness tab and disable the feature.
  • Now, head to the Adaptive Color section and toggle the corresponding icon to turn it off.
Method 4. Turn Off Dark Theme to Rule Out Software Issue
Ruling out software related issues by turning off dark themes is another helpful solution for putting an end to Pixel screen turned green. You can do this by following these steps:
  • Find the Settings icon and click on it.
  • When the subsequent screen appears, select Display to proceed.
  •  Navigate to where you have Dark Theme and toggle the corresponding icon to show white.
  • Once done, Dark Theme will be deactivated immediately.
Method 5. Update Android Version
Your Android version has a significant effect on the functioning of your Pixel phone. When you install  a beta version or run an outdated OS on your device, you may see the green screen. Updating your Android operating system to the most recent one should fix the underlying problem.
To do this, here’s the quick guide you have to follow:
  • Launch the Settings menu on your Pixel phone.
  • Swipe down and select System Settings or About Device depending on what’s displayed on your phone.
  • Click on System Update on the subsequent interface.
Choose the "System Update" Option
Choose the “System Update” Option
  • Next, tap on Check Updates and a screen showing if there’s an update or not will come up.
  •  In case there is an update, you will see the Download and Install option. Click on it to commence the Android version update.
A stable internet connection is needed for the Android update to occur. Please ensure that you are connected to a reliable internet.
Method 6. Uninstall Troublesome App
Still experiencing the same issue after applying the aforementioned solutions? Then it could be that there are some troublesome apps on your device that are causing the underlying issue. In this case, uninstalling the app from our device would resolve the issue.
To do this,
  • Open the Settings panel.
  • Head to the Apps & Notifications section and click on the corresponding button.
  • Now, a screen with all apps available on your Pixel phone will appear. Find the one responsible for the underlying issue and uninstall it.
Method 7. Perform Factory Reset
If the problem persists after applying the solutions above, we recommend that you perform a factory reset on your device. This solution wipes all data and custom settings you have on your Pixel phone, so it looks as if you just purchased it.
Here’s how to perform a factory reset on your Pixel phone:
  • Click on Settings
  • Locate and click on System.
  • Next, head down the subsequent screen and select Reset
  • Click Erase all settings (also known as Factory reset on some devices).
  •  Validate your action by clicking on the appropriate icon.
Without delay, your Pixel phone will be returned to factory settings.
Method 8. Repair Android System
Perhaps the Pixel screen turned green after updating to Android 14 update still occurs, you should consider repairing your system. You need a professional Android repair tool to get this done. Though there are many options online, DroidKit is the most effective.
DroidKit is an outstanding software when it comes to Android repair operations The software fixes all Android related issues, including green screen, black screen, frozen screen, unresponsive volume button, and 50+ more. It powers a comprehensive interface tailored for users of all levels, so your tech proficiency has no value when operating this software.
Key Features
  • 1-click to fix more than 50 Android system related issues, including green screen, frozen screen and more.
  • Bypass FRP lock issues on your Samsung, OPPO, Huawei, and Xiaomi phone.
  • Additional functions; data recovery, data extraction, system cleaning, and more.
  • Applicable with all Android OS including version 14.0 and later.
Step 1. Free install DroidKit and open it on your computer > Connect your Android phone to the computer > Click the Fix System Issues mode right in the middle.
Click System Fix Function
Step 2. Once DroidKit detected your device, click the Start button to continue.
Start to Repair Samsung Phone
Step 3. DroidKit will automatically match the PDA code of your Android phone > Click  Download Now to get the firmware package, which is used for repairing the Android system errors.
PDA Code Matched
PDA Code Matched
Step 4. When it finishes downloading the firmware package, you will see the following interface, where you should click on the Fix Now button to initiate the fixing process.
Firmware Downloaded and Click Fix Now
Step 5. The device system will start to get repaired. Wait for a few minutes, your Android phone will get back to normal condition.
Completing the Repair Process
Method 9. Contact Google Pixel
Lastly, you should contact the Google Pixel support team to help you resolve the Pixel screen turned green. In order to get this done, you should proceed to the official website for Google Pixel support, send your complaint and wait patiently for the team to fix the underlying issue.
Final Words
We successfully highlighted the reasons for Pixel screen turned green issues and the potential solutions. Hopefully they help you resolve the problem and return your device to normal. Our best solution is the one with Android repair software- DroidKit. The software handles nearly all Android related issues without damaging your device. Install it and try it out.
