Odin is a common flashing tool for Samsung devices; however, sometimes, Odin does not recognize Samsung. In this article, we have discussed 7 quick solutions for Odin not detecting Samsung phone with reasons.
If Odin does not recognize Samsung, just free download DroidKit to fix this issue easily and quickly. You don’t need to root your device. And no skills are needed. Most importantly, it supports all Samsung devices running Android 5 and above.
Odin is the go-to choice for Android users looking to flash their devices. However, although it is a pretty straightforward tool, it may encounter technical issues like Odin not detecting phone. If you have installed Odin on your computer and are trying to install your Samsung phone’s firmware but can’t because Odin does not recognize samsung, there is no need to worry. You can start by uninstalling and reinstalling Odin.
And, if it still fails to detect your device even after re-installation, it’s time to go for some alternative quick fixes. Below, you will find 7 tried and tested methods to fix the Odin not detecting Samsung phone issue. But before we get to the “hows,” let’s go over the “whys!”
Bonus Tip: Here are some other tips about Odin you may like.
There could be a number of reasons for Odin not detecting Samsung phone. For instance, if you have an obsolete version of Odin installed on your PC, it might fail to detect newer versions of Samsung devices. Similarly, other factors could be causing Odin’s incompatibility with your Samsung phone. We have listed some common reasons below:
Now that you know the basic reasons for Odin not detecting Samsung phone, let’s go through some quick fixes for this issue.
The first method to fix Odin not detecting Samsung phone is by using DroidKit – Android Phone Toolkit. It is a complete Android solution to multiple issues with your Android devices. If Odin cannot detect your Samsung phone or Odin doesn’t recognize phone in Download mode, using DroidKit to quickly fix this issue is definitely your best choice. And you just need to click buttons to easily fix this issue instead of rooting your device. You can learn more about what DroidKit can do for you below.
And DroidKit also does more than that. It can also help you remove screen locks, resolve known and unknown system issues, bypass Google accounts and FRP, recover lost data, and more.
Now just get DroidKit for free and follow the steps to resolve Odin not detecting Samsung phone:
Step 1. Open DroidKit on your computer, and select System Fix from the interface.
Click System Fix Function
Step 2. Connect your Samsung phone to the computer using a USB cable, and click Start.
Start to Repair Samsung Phone
Step 3. DroidKit will detect and match your device with the firmware based on the PDA code. Then click Download Now to download the firmware.
PDA Code Matched
Step 4. Once DroidKit has downloaded the firmware, click Fix Now to resolve underlying system issues causing Odin not to detect your Samsung phone.
Firmware Downloaded and Click Fix Now
Step 5. Follow the on-screen instructions to put your Samsung phone in Download Mode.
Step 6. Then, DroidKit will start fixing the system issue. It will take a few minutes for DroidKit to fix Android OS, after which your device will restart.
Completing the Repair Process
If Odin could not detect your Samsung phone due to an underlying system issue, it will detect it now.
If the previous method doesn’t work, or you don’t want to use a third-party app to fix the Odin not detecting Samsung phone issue, you can try the following alternative methods:
There’s a high possibility that Odin doesn’t detect phone because the USB port you have used to connect your device to the PC is defective. Therefore, try another USB port before you use other further methods to fix Odin not detecting Samsung phone.
If the USB port is working fine, a broken USB cable may also cause Samsung Odin not detecting phone. If your USB cable has been around for a long time, it could be that it has become too old to function properly. The solution? Get a new USB cable, or use the original one that came with your Samsung phone.
Another primary reason for Odin not detecting Samsung phone is that you may not have USB debugging enabled on your device. To enable USB debugging:
Step 1. Go to “Settings > About Phone” and tap the “Build Number” 7 times to enter Developer’s Mode.
Tap Build Number
Step 2. Now go back to “Settings > Developer Options” and select the “USB Debugging” option to enable it.
Select the USB Debugging Option
Once you have enabled USB debugging, Odin will successfully detect your device. However, if this method fails, it’s time to enter the Download Mode manually.
You can also fix Odin not detecting Samsung phone by entering Download mode. You can put your device into Download Mode using the side buttons. But you should note that if your issue is Odin not detecting phone in Download mode, then this method is not for you. You can try AnyUnlock or the next way to fix Odin not detecting Samsung in Download mode.
And as the methods for entering Download Mode may differ based on your Samsung model, here’s a guide for it:
Samsung Phones with Home Button
If you have a relatively older Samsung phone with a home button, here’s how to enter Download Mode:
Samsung Phones Without Home Button
If you have a newer Samsung model that comes without a home button, follow these steps to enter Download Mode:
Samsung Phones with Bixby
If your Samsung phone has a Bixby button, here’s how to put it into Download Mode:
Once your device has successfully entered the Download Mode, Odin will most probably detect it. Otherwise, you can use Device Manager to connect to Odin.
Another way to fix Odin not recognizing device is through the Device Manager on Windows. This method updates your phone’s drivers via Device Manager, making it possible for Odin to detect it. Here’s how to fix the Odin not detecting phone in Download mode issue:
Step 1. Connect your device to your PC. Go to “Start > Control Panel > Device Manager” or simply search for it in the search bar.
Launch Device Manager
Step 2. You will find your Samsung phone under the “Other Devices” option in the menu on the left.
Step 3. Right-click on it and select “Update Driver Software > Browse my Computer for Driver Software.”
Step 4. Now select “Let Me Pick From a List of Device Drivers on my Computer” and choose “Samsung Mobile USB CDC Composite Device.”
Step 5. Install the driver, and then unplug your device from the PC.
Step 6. Connect it to the PC again, and launch Odin. It will definitely detect your device this time.
Usually, when you connect your Samsung device to your PC, it automatically installs the drivers. However, it could be possible that the Samsung driver did not get properly installed or your PC failed to install it together. In such a case, Odin does not recognize Samsung.
This calls for installing or reinstalling the Samsung driver. Here’s how:
Step 1. Go to Samsung Android USB Driver, and download the latest version available.
Step 2. Connect your device to your PC and use Odin.
These were the 7 ways to resolve the Odin not detecting Samsung phone issue. However, for your ease and convenience, we have also added some common queries.
We have talked about the reasons and fixes for Odin not detecting Samsung phone. And here we would like to answer some related questions about Odin.
1. What is Odin mode on a Samsung phone?
Odin mode is a special state on Samsung phones that allows users to manually flash firmware and software updates and custom ROMs, kernels, and recoveries using a desktop tool called Odin. It is commonly known as Download mode and is typically used for advanced troubleshooting and customization of your Samsung devices.
2. How to enter Odin mode on a Samsung phone?
To enter Odin mode on a Samsung phone:
3. How to exit Odin mode on Samsung phones?
Exiting Odin mode is almost like rebooting your device:
Also, note that it is important to follow these steps to exit Odin mode; otherwise, it can cause issues with your device.
Just like with every software, Odin does not recognize Samsung for some reasons. In this article, we have put together 7 ways to solve the Odin not detecting Samsung phone issue. You can try the method that suits you best. And if you cannot fix this issue in common ways, don’t forget to get DroidKit for free to solve it immediately. Have you ever faced a similar issue with Odin? Let us know in the comments which method worked seamlessly to get Odin to detect your device.
