OK, got it
“My phone got locked, i want to factory reset it but no response for any tap. Any mobile factory reset software for pc?” Most Android users may encounter the same dilemma. Luckily, this post covered three effective ways to factory reset an Android phone from a PC.
Fatest way to facotry reset Android phones from a PC. With its easy steps and intuitive interface, you can reset your ANdroid effortlessly. Without root and any security risks.
In this era, factory resetting a phone is common due to devices’ insufficient memory or system issues. As known for all, easily resetting the phone within the Settings app on Android directly or hard resetting Android via Recovery Mode can fix issues like this. However, if the Android phone is frozen or broken, there’s no doubt that it can’t be factory reset on itself. That’s why mobile factory reset software for pc exists to help users reset phones on computers. Now, follow this article to learn how to factory reset an Android phone from a PC.
As we all know, factory reset means all the data on your Android phone, including photos, videos, downloaded apps, etc. will be erased. Besides, if you log into a Google account, you might face the difficulty of FRP bypass. Therefore, there are some preparations you need to do before factory resetting phones using PC software.
Having known the preparations, let’s move to the methods to reset Android phones using PC software.
As for mobile factory reset software for pc, DroidKit is a good choice for Android users. It supports to reset various Android devices, including Samsung, Xiaomi, POCO, etc. Whether the phone is locked or unresponsive, DroidKit can help users factory reset a phone effortlessly. Thanks to the wide compatibility, users can reset Android phones with this mobile factory reset software on both Windows and Mac OS. As a comprehensive Android toolkit, it can solve many other Android issues, including unlocking phones without passwords, unlocking a Google-locked phone, data recovery, etc.
Steps to reset Android phone using PC software without USB debugging:
Step 1. Get the latest version of DroidKit on your computer > Launch it and choose Screen Unlocker.
Choose Unlock Screen Function
Step 2. Connect your phone and click Start. After the configuration file is prepared, tap on Remove Now.
Click Remove Now Button
Step 3. Select your device brand and continue.
Step 4. Follow the on-screen instructions to put your device into recovery mode. After the unlocking process is completed, you will get the lock screen removed and your Android phone reset.
Lock Screen Removal Completed
Follow the steps above, you can successfully factory reset your phone using a computer with the Screen Unlock feature of DroidKit. Its intuitive interface and easy steps can solve your problem within a few clicks.
Android Device Manager is an effective tool for users to easily locate, remotely lock and factory reset their Android device. It is an extremely effective method to erase data stored on your device when your Android phone is missed or stolen. To successfully factory reset an Android device, you need to meet some preconditions for using this free mobile factory reset software for PC. Your phone should be turned on, signed into a Google account whose credentials you know, as well as connected to Wi-Fi, and the Location and Find My Device features should also be turned on. Now, follow the below tutorial to factory reset your Android phone from PC.
Step 1. Go to Google’s official website > head to Android Find My Device.
Step 2. Sign in to your Google account and choose the device you want to factory reset. You will see the Ring and Enable Lock & Erase options then.
Step 3. Click Ring will make your Android phone ring for five minutes even if you have set your Android phone into silent or vibrant mode.
Step 4. Select Completely Wipe the Data to reset your Android phone to its factory setting.
As a software development kit, Android SDK Tools also enables people to factory reset Android phones using a computer. It is also a mobile factory reset software for PC free of charge. However, users can only apply this method when the phone has turned on the USB Debugging, which might bring about potential network security risks. Besides, mistakes during the process could result in bricked devices. Here, I will show you the steps:
Step 1. Turn on the USB Debugging on Android
Step 2. Download and Install SDK Tools on your Computer
Step 3. Check Whether the Device’s Drivers are Installed.
Step 4. Connect your Android to your PC by using a USB cable.
Step 5. Wipe Data or Factory Reset your Android Phone
Q1: How to Hard Reset Phone Using Laptop?
Most brands have their own tools for managing and hard resetting phones, you can follow the steps to hard reset your Android using a laptop:
If this method doesn’t work, you can use some third-party tools like AnyFix, which can help you hard reset your phone effortlessly.
Q2: How to Restart an Android Phone Using a PC?
To restart an Android phone using a laptop, you can use ADB (Android Debug Bridge).
In this article, we introduced 3 methods to help you fix how to factory reset your Android phone from a PC with ease, including DroidKit, Android Device Manager, and Android SDK Tools. Among these mobile factory reset software for PC, DroidKit stands out for its ease of use and security. With its help, users can format phones using a PC without effort. Download it for free now!
