If you are facing Google Pixel Unresponsive black screen issue, just read this article in depth. Here you will get several proven ways to solve this problem quickly.
Google has finally released the most anticipated device: Google Pixel 7 Pro. The initial reviews have already been fantastic. Google is putting so much effort into improving the users’ working experience. But one of the major concerns for the users is google pixel’s unresponsive black screen. And it can be frustrating for the users.
In this article, we will explore possible reasons for the unresponsive black screen of Google Pixel. Besides, we will dive deeper into finding the best quick fixes and solutions to this particular problem. This article will answer some of the frequently asked questions as well. Let us have a look at its reasons first.
Bonus Tip: Other tips about Google Pixel you may like here.
There are many reasons why you are facing google pixel unresponsive black screen. A few of the reasons are listed below.
There may be something wrong with the operating system of the device. This issue happens when the software is not compatible with the device. It prevents your phone from turning on.
There is a chance that your pixel device is defective. It has a faulty screen. This issue happens when you dropped your phone recently or have performed a physical repair. It is due to the disconnection of the screen assembly cable from the motherboard.
There are chances that your phone has a low battery. That is why you are facing a google pixel unresponsive black screen issue.
There are sensors at the top of the phone. If the sensors get dirty, your device thinks it’s dark outside. In this case, your cellphone lowers the brightness.
Another reason might be the recently installed third-party apps.
After covering the reasons for the google pixel unresponsive black screen issue, let’s move on to see how we can fix this problem.
There are some quick fixes for your Google Pixel issues. The common problem is that your Pixel is stuck on an unresponsive black screen, but it still works. It means you can receive phone calls, hear notifications, and feel them vibrating. But the unresponsive black screen does not go away.
Whatever the reason is, there is always a way out. Here are some quick fixes for your Android device to start working again.
For most android phones, simply restarting your device might fix it. It can be effective in fixing screen glitches and black screens. The following are detailed steps.
Force Restart Your Android Phone
If your Google Pixel screen is black, move on to another fix.
Often, a black screen is caused by a dead battery. In this case, follow the steps given below.
Step 1. Connect your device to a charger for at least 10 minutes.
Step 2. Regardless of whether the screen shows it’s charging or not, leave it connected for 15 minutes.
Step 3. Fifteen minutes later, try to press the Power Button. Hold until the Google logo appears.
If your device is still stuck on a black screen, move on to the next step.
Please check and clean your device by following some steps.
Step 1. Check the power button. Make sure it is not filled with dirt. Now press the power button. And then release it. Repeat this a few times.
Step 2. Clean the charging port as well. It makes the phone unable to charge usually. You can blow into the charging port. You can also use a toothpick to remove anything stuck in the charging port.
Check and Clean Your Device
Step 3. After cleaning, charge your device for 10 to 15 minutes. Now try to restart your phone.
If the problem is still there, please try another quick fix.
This quick fix is used to see if the LCD has a loose connection.
Step 1. Press the front and back sides of your phone. Squeeze your phone with both hands.
Step 2. If the wire connection is loose, it will help to reset the link. And your screen will start working again.
Step 3. If your phone starts working, get it to a repair center. They will firmly reset the LCD cable.
If it doesn’t work, try restarting your phone in safe mode.
If your Google Pixel screen goes black instantly, you can enter Safe Mode. It is used to see if the issue results from a recently installed application. Safe mode allows you to turn on your phone with third-party applications. Follow the detailed steps below to delete incompatible applications.
Put Phone into Safe Mode
Step 1. Press and hold the Power button. And wait until the Google logo appears on the screen.
Step 2. Now press the volume down button and hold it.
Step 3. Wait to release it until you see the words “Safe mode”. It appears in the lower-left corner of the screen.
Step 4. When Safe Mode is enabled, it allows you to delete the apps, causing a black screen.
Step 5. After uninstalling the apps, turn on the phone again.
If all the above steps don’t work, try resetting your device. Let’s see how it goes.
Several factors cause the Google Pixel’s unresponsive black screen. In most cases, this can be caused by a software glitch. Sometimes, the problem can be caused by a firmware or hardware fault. We can tackle the problems caused by software or firmware. Solutions are given here.
When there is a fault in operating software, this step is taken. This step is taken as a last resort. You must boot the smartphone into Recovery Mode to perform a factory reset.
Step 1. Shut down your Google Pixel. To do this, press the power button and hold for a few seconds.
Step 2. Now press the Power and Volume Down buttons simultaneously. The phone boots up, and you should now see the Fastboot Mode screen.
Enter Fastboot Mode Screen
Step 3. Navigate to the Recovery Mode using the Volume buttons. Once the Recovery Mode option is highlighted, press the Power button.
Step 4. When a message says “No command” on the screen, press the Power and Volume up buttons shortly after.
Message “No command”
Step 5. Once you press both buttons correctly, your smartphone will enter Recovery Mode. Press the power key to Reboot the system now.
Step 6. Your phone will reset itself and turn back on automatically. It means that the google pixel unresponsive black screen on your Pixel 7/6/5/4/3/2 is successfully fixed.
Typically, you resolve this problem by factory resetting your mobile. Yet, when google pixel is stuck on an unresponsive black screen, you find it difficult to reset it. It is because your phone may suffer from some system errors. You cannot address the problem by resetting your device in this situation. Instead, it would be best to use professional system repair toolkits.
There are a lot of impressive tools, but we highly recommend the DroidKit – One-stop Android Phone Toolkit, to help you out. Because, as a professional fixer for Android system, DroidKit can repair the issues in it only with a couple of buttons, as easily as possible. And no matter what system error it is, this tool can fix it for you quickly. You can learn more about its features below.
What’s more, if you need to recover some important data like contacts from your Android device, DroidKit can also do it for you even without backup. And it can also help you unlock Android screen locks, bypass FRP lock, etc.
Now free download DroidKit on your computer and follow the instructions to fix the Google Pixel’s unresponsive black screen.
Step 1. Open DroidKit on your computer. Now connect your device to the computer. Please select the System Fix mode.
Click System Fix Function
Step 2. After detection of your device, please click the Start button. DroidKit will access your PDA code. Now please select the Download Now button.
PDA Code Matched
Step 3. Your firmware package will start downloading. Keep your device connected. After the download is completed, DroidKit will display the following interface. Please select the Fix Now button.
Firmware Downloaded and Click Fix Now
Step 4. You should put your device in Download Mode. Two ways for you: with or without the home button. Please choose one way, depending on your device status. After putting your device on Download Mode, please select the Next button.
Step 5. The system will automatically fix it. Please wait for a moment. After this, the package will restore your device. You can use your device now.
Completing the Repair Process
If none of the above fixes get your phone back to normal, there is some hardware problem. You should contact the nearest authorized repair center if the unresponsive black screen remains. The phone warranty might cover the damage and will be set free of charge.
Let’s answer a frequently asked question now.
Is my Google Pixel dead?
There are a few signs which will determine if your phone is dead.
If:
-then your phone is dead.
You must use a professional toolkit or visit an authorized repair center to eliminate the unresponsive black screen.
That’s all about how you can fix the most infamous google pixel unresponsive black screen. It is much easier than you might think. You don’t have to get frustrated at all now. You must follow the simple steps, and your headache of an unresponsive black screen will disappear. And to repair Android system issues, don’t forget to free download DroidKit to fix them with smple clicks. If you find it helpful, share it with your friends and family.
