What to do if the Google maps on your Android phone suddenly stops working? Have you ever think about the reason why does your Google map not work? Don’t worry, you can find answers in this article.
In modern life, due to the rapid development of smartphones, when people go to a strange place, they no longer rely on paper maps but more often use electronic maps on their mobile phones, such as Google Maps on Android or iPhone Google Maps.
However, problems may happen with the Google Maps app on your phone, for example, Google location history not working, Google Maps crashes when starting navigation or while driving. It may not show direction or voice not working at all. At this time, you may ask How do I fix Google Maps on my Android?
Google Maps on Android Phone
If you are also confused by this problem, now, this article shows you the four methods to solve this error.
You May Like: How to Fix iPhone Maps Not Working >
Usually, it is because of the internet connection and GPS that cause Google Maps can not work on your Android phone. However, if there is an unknown bug on an Android phone, it can cause this problem too.
In this case, you can follow the methods below to check and fix the Google Maps not working issue.
Sometimes, the problem is caused by too much cache and data that has not been cleared for a long time. This may be why your Google Maps is running abnormally. Therefore, clearing the data and cache of Google Maps can solve this problem. Please follow the steps below to resolve the Google Maps stop working.
Tap Settings on your Android phone > Apps > Scroll down to find Google Maps > Click on the Store option and then tap Clear Cache.
Clear Google Maps Data and Cache
Checking the network connection and GPS location services is the most basic method to eliminate the possible causes of Google Maps not working error. Because you can only normally and fully use Google Maps if you are connected to a stable network (whether it is Wi-Fi or cellular network) and GPS location services.
You can refer to the steps below to reset the internet connection and ensure the GPS settings:
Go to Settings > Connection > Scroll down and tap on Location > Choose Locating method > You can change to High accuracy.
Check Wi-Fi Connection and GPS
Settings > Connection > Wi-Fi (or cellular network) > Then you can close and enable the wifi connection or change to a stable Wi-Fi.
Check Wi-Fi Connection on Android
If you have checked network, GPS connection and also clear the app’s cache but still can not use Google Maps. We suggest uninstall and re-install the app on your phone.
Just go to Google Play Store > My app and games > Tap on the UNINSTALL option.
When the process is finished, you can now reinstall the app on your Android device > Reboot your phone.
Uninstall and Reinstall Google Maps
Sometimes, due to a short-term bug of the system in Android phones certain functions or certain apps may become unavailable. However, this is not a serious problem, and restarting your phone will usually fix this problem. Therefore, for the problem that Google Maps suddenly cannot be used in Android phones, try to restart your phone to fix it.
Restart the Device
Also Read: How to Get Out When Android Stuck in Recovery Mode >
If you want to fix crashed system on Android to cause Google Maps not to work, DroidKit is able to revive your crashed Google Maps easily. It is software that can save you from various Android OS problems, including Google Maps not working, Google Maps is running slow, Apps keep crashing, an Android phone won’t charge, Samsung black screen, etc.
What’s more, it’s easy for you to free up phone storage and speed up Android phones with a click. You can also force update Android with it. DroidKit is designed to be a complete Android solution that helps you solve the system issues like above, also recover Android data, unlock Android, etc.
First, here are the steps to fix Google Maps not working with the system repair tool:
Step 1. Get the latest version of DroidKit on your Windows PC or Mac. Launch the software and click Fix System Issues.
Click Fix System Issues
Step 2. Connect your Android via USB cable and hit Start button.
Click the Start Button to Continue Fixing
Step 3. Get the firmware package downloaded.
Start to Download Firmware Package
Step 4. After that, click Fix Now button. Then follow the on-screen instruction to put your device into download mode.
Get Your Phone into Download Mode
Step 5. Later, DroidKit will start repairing automatically. Wait for the process to be completed, you will get the completed page as below. Google Maps not working issue will be fixed successfully.
System Fixed Successfully
All of the above is about how to fix the “Google Maps not working on Android” error. If you get help from it, please share this article with friends and family.
