Turning on your Xiaomi phone only to find out that its not booting is one of the most frustrating events you could experience, but it’s fixable. In this post, we will explore how to fix Xiaomi phones that won’t turn on.
Your Xiaomi device can’t turn on? Free download DroidKit to fix the Xiaomi phone won’t turn on in clicks. No need to root your device and no technical skills are required.
Fix Xiaomi Phone Won’t Turn On
Undoubtedly, our mobile device is an integral part of our lives, and the Xiaomi phone isn’t left out. With this brand of phone, you can easily host and participate in calls, send and respond to text messages, take mind-blowing photos, etc.
However, mind you, all of these activities can only be completed when the device is turned on. What happens when your Xiaomi phone won’t turn on? Definitely, none of these activities can be executed and the device becomes useless. If this is a problem you are experiencing and need a guide on how to fix it, then this post is for you. Here, we present to you the reasons for the underlying issue and how to put an end to it easily and quickly by yourself. Let’s dive in!
By default, when you long press the right set of buttons on your Xiaomi phone, the device comes up automatically. But if it doesn’t, then there’s something wrong with the device. In this section, we will look at the common reasons why your Xiaomi phone won’t turn on. Check them out below:
Since firmware or OS-related issues are one of the common reasons why your Xiaomi phone won’t turn on, subjecting the corresponding device to system repair would be helpful to reinstate it. To achieve this, you must employ the services of an Android system repair tool like DroidKit – Android Phone Toolkit.
DroidKit is one of the most versatile tools for fixing Android issues, from unresponsive screen to black screen, and 50+ more. It’s also great for resolving boot loop issues, like Xiaomi won’t turn on. Your data is safe and intact when using the DroidKit Android repair solution, as its operation doesn’t extend beyond the system repair you subject it to.
Step 1. Free install DroidKit and open it on your computer > Connect your Android phone to the computer > Click the Fix System Issues.
Click System Fix Function
Step 2. Once DroidKit detected your device, click the Start button to continue. And choose the Xiaomi brand.
Select Your Device Brand
Step 3. DroidKit will get PAD code matched for your device > Click Download Now button to get the firmware package. After downloading, click on Fix Now. And follow the on-screen instructions to put your device in Download mode> Tap on Next button to continue.
Put Xiaomi in Recovery Mode
Step 4. The device system will start to get repaired. Wait for a few minutes, your Android phone will get back to normal condition.
Completing the Repair Process
Perhaps you don’t have access to a computer system and you are struggling to turn on your Xiaomi phone, then the application of one or more of the following basic solutions should resolve the underlying issue:
When your Xiaomi phone fails to turn on after pressing down the right button, a quick restart could fix the problem. By restarting, we mean turning off the faulty device and then waiting a while before rebooting it. This solution is highly beneficial in fixing boot loop issues as it refreshes your system, clear junks in RAM, and removes bugs.
Here’s how to restart your Xiaomi phone to fix the issue you are currently experiencing:
Restart Your Xiaomi Phone
Flat or low battery life was listed among the common reasons why your Xiaomi phone won’t turn on. Charging the device helps you restore power so you can now turn it on without complications. However, mind you, we strongly recommend that you use the original charging accessories to charge the device to avoid further issues, such as power discharge and battery not charging.
Checking your Xiaomi phone for damaged hardware components is another vital solution to implement when the device isn’t coming up. We suggest that you check the screen if it’s not broken, or look at the power buttons to confirm it’s not damaged. If all of these components are in good shape, then you can move to the next solution to fix the Xiaomi phone won’t turn on issues you are facing.
Dirt and dust are some of the greatest enemies of a mobile device. When either of these two is present in the power buttons or the screen of your Xiaomi phone, the device may not respond when turning it on. Wiping the phone screen with a clean napkin and also removing diets from the power buttons are great solutions you could try out in this scenario.
Another easy way to resolve the problem of the Xiaomi phone won’t turn on is to eject the SD Card you installed in it. This solution is suggested because you never can tell if the SD card is corrupt or filled with viruses. Try it out to see if the underlying issue will be fixed.
A cache partition is a section of your device storage that collects and stores temporary data files about your previous actions on specific apps and programs for future reference. When this section is filled up, your device may malfunction and fail to come up while turning it on. You should consider wiping the cache partition to reinstate the operations of your Xiaomi phone.
Use the detailed procedure below to wipe cache partition on your Xiaomi phone:
Long press the three hotkeys simultaneously; Power + Home + Volume Down.
Wipe Cache Partition
Hard resetting the Xiaomi phone with the underlying issue is another cost free solution you could implement. When you do this, all content and settings (installed) that might be responsible for the issue are automatically cleared leaving behind the preinstalled apps, data and configurations. You can hard reset your Xiaomi device by following the detailed steps shared below:
Hard Reset Your Device
Force starting is one of the troubleshooting techniques for refreshing a device, as it clears bugs and removes unwanted data (junks) from the RAM. This technique is similar to restarting your device, but doesn’t require you to interact with the power screen. You just have to long press a button while your device goes off and comes on by itself.
Here’s how to force restart your Redmi phone:
Without holding the power button, you can easily command your Xiaomi phone to go off and on. This can be done using the Quick ball feature on your device. Here is how to go about this:
When you notice your Xiaomi phone won’t turn on, the guide above should come in handy. Our most preferred solution from the list is the one involving DroidKit. The software not only fixes the boot loop issue but also clears corrupted data that might be responsible for Xiaomi won’t turn on issues. It can solve almost all Android-related issues without much trouble. Free get DroidKit to have a try!
