If your Samsung keyboard keeps stopping for no apparent reason, there is probably something wrong with the keyboard settings or your Samsung system. This guide takes a look at some of the possible causes of the issue and shows how to fix Samsung keyboard keeps stopping.
You are typing a text to someone and suddenly your Samsung phone says “Unfortunately, the Samsung keyboard has stopped”. This can easily become irritating if it happens over and over again. If you are wondering why your keyboard is not working as it should, this guide offers some information about that.
Samsung Keyboard Keeps Stopping
There are actually various reasons why you receive the message ‘Unfortunately samsung keyboard has stopped’. Fortunately, there are several solutions for fixing Samsung keyboard problems, and you can apply these fixes to potentially get rid of the keyboard crash issue on your Samsung phone.
While most users would prefer to jump right onto the solutions to fix their keyboard, some users might be interested in finding out what does it mean when Samsung keyboard has stopped. Here are some of the possible causes of the issue.
Samsung Keyboard App Issue: Like other apps, your Samsung keyboard also stores cache and data files on your storage. Over time, these files build up and you have numerous keyboard cache files sitting on your device. This huge number of files actually confuses the keyboard and this leads to the issue that you are currently facing on your phone.
Keyboard Settings Issue: When your Samsung keyboard stops working, that is often the result of an incorrectly specified setting option in the keyboard settings menu. Unlike old keyboards, modern and newer keyboards have a designated settings menu where you can define how your keyboard should work on your phone. If you or someone else has modified these settings in an incorrect way, that is probably why you are experiencing issues with it. Your keyboard will continue to crash and remain dysfunctional until and unless these settings are fixed. It is recommended to remove cache files every once in a while to ensure the smooth running of your device.
Keyboard Bug: If you use a modified version of the Samsung keyboard or you use a third-party keyboard app on your Samsung phone, that app could have bugs in it and that can prevent you from using the keyboard smoothly on your device. Like other apps, keyboard apps can also keep crashing on Android devices. Since these app bugs are not something you can fix yourself, you need to rely on the developer to check for these bugs and resolve them from their side.
It is a good idea to learn why your Samsung keyboard keeps stopping, and now that you have done it, you can follow along to learn some of the ways to fix the keyboard issue on your device.
There are actually multiple ways to Samsung keyboard not working issue. You can try to reset, update, repair your Samsung keyboard or even use another keyboard alternative.
One of the effective ways to fix it when the keyboard stops working on a Samsung phone is to reset the keyboard settings. If you have specified incorrect settings, or if there are other settings-related issues with the keyboard, this should likely fix it for you.
There are three main ways to reset the Samsung keyboard.
You can actually tap an option on your phone to reset all the keyboard settings to their defaults. This will reset all your language options and any other modifications you may have made to the keyboard. You can always reconfigure the keyboard after it has been reset if you want.
Reset the Samsung Keyboard
The following is how you reset your keyboard settings on a Samsung device.
Make sure you do not end up resetting any other settings on your phone.
Like said earlier, the cache and data files for your keyboard app can actually cause the keyboard not to function properly on your device. There is actually an easy way to fix this problem. You can head into a menu in the Settings app and delete all of the cache and data files for the keyboard.
Clear Keyboard Cache and Data
This should not delete the keyboard but rather delete its preferences. You can perform this deletion process as follows on your phone.
It might be that there is a minor glitch with your keyboard and that is stopping the keyboard from working properly. In this case, the best and quick way to get around the issue is to restart your keyboard.
Force Stop Samsung Keyboard
Relaunching your Samsung keyboard is as easy as tapping an option. Make sure you close all the apps on your phone before you do this.
If you have replaced your stock keyboard with a third-party one, make sure your keyboard app is up to date. Older versions of the keyboard app often have many issues that have been fixed in newer versions. Updating a keyboard app is as easy as updating any other app on your phone.
Find Your Keyboard in Google Play
Make sure you have a stable Internet connection and ensure the Google Play Store is workable. Then you can follow the following steps to update your keyboard.
If your Samsung keyboard keeps stopping regardless of what fixes you apply, one way to deal with this issue is to use an alternate keyboard option. This option could either be a hardware keyboard or a software keyboard. You can choose from either of these depending on your personal preferences.
You can actually get yourself a physical keyboard that you can attach to your phone to type text. This should help you get going with your tasks until you find a way to fix your Samsung keyboard.
Another option is to get a third-party keyboard app on your phone. The Google Play Store is loaded with tons of keyboards, and you can try out various of those apps and see which one works for you.
To fix the “Samsung keyboard not working” issue, you need the help of DroidKit. As an Android manager, DroidKit offers full solutions for Samsung system repair, Android data recovery, Android lock screen removal, Samsung data extraction, FRP bypass, etc. Whenever your Samsung device meets system problems, like system UI not working, touch screen not working, Samsung black screen issue, stuck on Samsung logo, etc., DroidKit will help you solve them with simple clicks. Check the tutorial below to fix the keyboard issue on your Samsung phone.
Step 1. Free Download and install DroidKit. This is totally safe and no viruses will be brought to your device. Launch DroidKit and click the Fix System Issues panel.
Click Fix System Issues
Step 2. Connect your device to the PC first, and then tap on the Start button.
Click Start Button to Continue Fixing
Step 3. Click the Download Now button to get the firmware. If there is no matching code detected, put your device into recovery mode first.
Download Firmware Package
Step 4. When the firmware package is downloaded, click the Fix Now button. Then put your device in download mode following the instruction, and click the Next button to continue.
Click Fix Now and Start Fixing
Step 5. Wait a minute, and the software will fix the keyboard problem for you.
System Fixed Successfully
One of the possibilities is that the issue is actually not with the Samsung keyboard but is with other apps installed on your device. Some other apps might be causing interference with your keyboard, and this can sometimes lead the keyboard to crash on your device.
Resolve Keyboard Issues in Safe Mode
One way to investigate and fix this issue is to reboot your phone into safe mode. This mode should only load the essential system files to boot up your phone, and then you can check if your keyboard works. If it does, the issue likely sits with one of the apps on your phone and you need to remove them one by one to see which one is the culprit.
Once your Samsung keyboard recovers to the normal situation, don’t forget to turn off the safe mode on your Android device.
There are several factors responsible for the Samsung keyboard keeps stopping on your device. If you are unsure why this is happening and what to do, the guide above should tell you the possible reasons for this issue and how to rectify the issue using various ways. Download DroidKit and following the steps we listed for you would be an excellent choice.
