It’s always a hassle when Android/Samsung phones keep losing internet connection. If you want to fix the network problem, then you are in the right place! This article is an extended guide on how to fix the issue of Samsung phones losing network connection for you! Read on>>
Fix Android Keeps Losing Network Connection
Have you ever been on an important phone call, only for your Android phone to lose network connection? Or you’ve been trying to send an urgent email, but your phone won’t connect to the internet? Losing a network connection on your Android phone can be frustrating. This can be especially true when you need to remain connected for work or personal reasons.
In this article, we’ll explore some common reasons your Android phone may lose network connection. Plus, practical solutions to help you get back online.
Let’s begin with the reasons for losing the network connection.
The average smartphone user experiences a network connection loss every three to four days. There can be various causes behind the frequent loss of network connection on your Android phone.
Understanding the reasons behind your Android phone’s network connection issues is essential. The problem can stem from several factors, including:
Now that we’ve explored some common reasons, your Android phone may be losing network connection. Let’s dive into some practical solutions to fix Android/Samsung Phone Keeps Losing Network Connection issue.
Don’t let a spotty network connection hold you back! Whether you’re trying to work or stay connected with friends and family. A stable network connection is essential. Here we’ll walk you through some practical solutions to help you fix your Android network connection issue.
You can try refreshing the network connection if you’re experiencing network issues while using WiFi. Here’s how:
1. Turn off the WiFi on your phone and switch on airplane mode.
Airplane mode
2. Turn off airplane mode and switch on WiFi.
3. Try to connect to the network again.
DroidKit – Complete Android Solution is a versatile Android utility app designed to help users optimize their devices and solve common problems. One of its standout features is the ‘System Fix’ module. It fixes almost all system problems on a Samsung device, such as Android black screen, Android phone frozen, Android stuck in fastboot mode, and Android touch screen not working, etc.
Free get DroidKit to experience the comprehensive functions and dive into its easy-to-follow steps to fix Samsung network connection:
Step 1. Download and install DroidKit on your computer > Choose System Fix mode.
Click System Fix Function
Step 2. When your device is detected by DroidKit > Click on the “Start” button to start a scan of your device for system issues.
Start to Repair Samsung Phone
Step 3. DroidKit will access the PDA code on your Samsung device. Once done, click the “Download Now” button to download the firmware.
PDA Code Matched
Step 4. After downloading, choose “Fix Now” > Follow the instructions to put your device into Download Mode.
Step 5. Finally, DroidKit will begin repairing your Android system automatically. Once the repair is complete, you will get the System Fixed Successfully page on the screen.
Completing the Repair Process
Improperly inserting your SIM card can disrupt your network connection. This can happen even if your area has good network coverage and the ISP server performs well. Removing the SIM card and re-inserting it correctly into the SIM tray is recommended to fix this issue.
Bring out SIM tray
If you have recently bought a new SIM card, contacting your service provider to ensure it has been activated is essential. Remember that activation may take a few hours after inserting the SIM card into your phone.
One of the simplest ways to fix network glitches on your Android phone is restarting it. You can simultaneously press the side and volume up buttons to access the power menu or directly from the quick settings panel.
Step 1. To restart your Android phone via the power menu, swipe from the home screen to access the Notification Center.
Step 2. Then swipe down again to expand the quick toggles menu.
Step 3. Finally, tap the power button at the bottom and select “Restart” to reboot your phone. This can help refresh your network connection and resolve any issues causing it to drop.
Restart Option
If traveling outside your state, enabling roaming on your Android device is a good idea. This ensures that you don’t lose network connectivity while using mobile data. Here’s how you can enable roaming on your device:
1. Open the Settings app.
2. Scroll down to the ‘Connections’ option and tap on it.
Tap Connections
3. Tap on ‘Mobile networks.’
Mobile networks
4. Find the ‘Data roaming’ option and tap the toggle next to it to allow the feature.
Find and Enable Data Roaming
You may have forgotten to pay your carrier bill, which can lead to your network connection being disabled by the company. You must check your carrier plan and pay any pending dues to resolve this issue. By taking this step, you can ensure that your phone’s network connection is reinstated, and you can stay connected.
If you’ve tried every other solution to fix your Android phone’s network connection problem. But nothing seems to work; a factory reset may be your last resort. This will obliterate all data on your device and set all settings back to their default parameters. It’s a common practice to go for a factory reset when technical issues persist on your device.
To perform a factory reset, follow these steps
Step 1: Go to Settings, then the ‘General management’.
Select General Management
Step 2: Scroll down to ‘Reset’.
Step 3: From there, select Delete All Data (Factory data reset).
Select Factory data reset
Step 4: Finally, scroll down and ‘Reset’ button to confirm and proceed with the factory reset.
Tap Reset to erase all data
Remember that the steps may differ slightly from one device to another. The factory reset option is found under System Settings on all Android devices.
In conclusion, losing a network connection on your Android phone can be frustrating, but there are several ways to fix it. By following the information outlined in this article, you should be able to resolve your network connection issue and stay connected quickly.
DroidKit not only provides flexible alternatives but also ensures that you do not experience data loss. Aside from that, it safeguards your data and device security. Don’t need to worry if you accidentally have phone system problems. And with DroidKit’s help, you can save your phone in no time! Learn more about DroidKit >>
