10 useful tips are offered to fix chrome freezing on Android. Besides, the post lists the main factors contributing to the problem so that you can better prevent Chrome from freezing next time. Just read to know why and how.
Recently I updated my Android phone. Since that I found my Chrome browser freezes after a few minutes of use. Sometimes half the screen goes black and the page stops responding, or even worse, my phone freezes and I can’t close the app or do anything else with my device. I wonder if it’s just me, or it has something to do with the update.
— An user from Android community
Actually many Android smartphone users say their Google Chrome not responding or Chrome keeps crashing after being updated to Android 11 or Android 10. It can happen when you’re searching for information for an urgent question, texting long sentences on Facebook with your internet buddies, or just watching some short videos. With a frequently freezing Chrome, it’s not just a thing of wasting time or losing top information, even reading the news can become an extravagant hope.
Sounds horrible, but thankfully it isn’t a problem without a solution. This article will help you figure out the reason why your Chrome browser gets a crash, or freeze, and offer you exact instructions on stopping chrome from crashing. Let’s take a look at what’s causing the problem first.
How to Fix: Android System Update Fails to Install >
There are several factors that can play a part. Some are easy to deal with while others are quite complicated. To pinpoint what the cause is, please carefully check every possibility listed below and rule out them one by one.
Now you should have a fair idea of why Chrome Keep Freezing on your phone. In this part, we will offer you 10 useful tips to fix it. Try these troubleshooting methods depending on your specific condition.
Everyone knows that when a phone stops responding, the easiest and quickest way is to restart it, which applies equally here. Reboot your phone helps to clear some of the temporary files and refresh Chrome and settings.
Close Apps You’re Not Using
It may be time to give your cache a good spring cleaning. follow the step-by-step guides in the drop-downs below to clean the cached data on Chrome and all Apps on your phone.
Clear Browsing Data on Chrome
Clearing app cache is kind of like a cleanse for your apps. It will get rid of residual files that could be slowing down the app.
In most cases, chrome keeps freezing, app crashes, Samsung phone keeps restarting, etc. are caused by software glitches on your Android phone. And DroidKit is software that provides you Android system repair tool to fix all system problems on a Samsung device, such as chrome keeps freezing, black screen, device frozen, touch screen not working, apps crashing, the camera failed, etc.
And you don’t worry about any security or viruses issues, because the ROM downloaded and installed on your device when fixing the problem is definitely official from Samsung, it’s 100% secure and stable. What’s more, DroidKit gives you a complete Android solution if you need it – Recover lost data, Unlock screen, Bypass FRP, etc.
Follow the steps below to fix chrome keeps freezing on your phone:
Step 1. Get DroidKit on your computer. Launch the software and click Fix System Issues.
Click Fix System Issues
Step 2. Connect your phone via USB cable and Start.
Click the Start Button to Continue Fixing
Step 3. Click Download Now button to get a matching firmware.
Start to Download Firmware Package
Step 4. After the firmware is downloaded, follow the on-screen instructions and put your device in Download mode.
Get Your Phone into Download Mode
Step 5. Later, DroidKit will start the repairing process.
System Fixed Successfully
Update Chrome or Other Apps
Reinstall Chrome
If all these methods mentioned above don’t work for you, you may consider a factory data reset, so all apps and their associated data will be uninstalled and make everything back to square one. But note this will remove all data from your phone, so remember to backup and restore data first.
Reset Your Phone to Factory Settings
Beyond Google Chrome, you can download other browsers from the Play Store, Microsoft Edge, Opera, Kiwi, and Dolphin are all good options.
If you are using Google chrome on your Windows PC and Google keeps crashing, here are some quick tips that you can try to fix the issue (Some are similar to the fixes on the phone):
Reset Chrome Settings
With all these solutions above, you should have a great possibility to fix the chrome freezing problem. Be free to send us an email or post a question in the comment section if you need more information about this article.
