How to Fix Android No Command Error
No command error is pretty common on Android devices. If your Android device displays this error message, this guide shows what that means and how you can get rid of that issue from your phone or tablet.
Author Avatar Joy Taylor Last Updated: Feb. 25, 2025
DroidKit – Fix No Command Android Without Root
Do you encounter a question that Android has no command in Recovery Mode? Don’t worry, free download DroidKit to fix no-command Android without data loss. DroidKit can help you fix no command error effortlessly!
Android no command in recovery mode has become one of the hot topics in many forums & community websites. Many Android users urgently need to know why a phone says no command when in recovery mode, and how to fix the Android recovery mode no command issue. There are various reasons this happens, and you can experience this on both Android phones as well as tablets. If you are facing the same dilemma, this guide is all that you need to fix Android no command.
What Does Android No Command Error Mean?
Android recovery mode enables you to simply reboot the Android system, apply the latest updates, factory reset the phone, reboot to bootloader, etc. No command in recovery mode usually means that Android won’t boot into recovery or unlock bootloader failed and shows you the error message. That is to say, your phone has not received any commands when it expects a command.
Why No Command on Android Appears?
Why does it say no command in recovery mode? The following points are the most likely causes of this problem on your Android device:
  • Improper resetting of your Android device may be the main reason that your Android no command screen appears.
  • Another reason you may encounter this error is whether there is a problem with the app on your device.
  • This can also happen if your Android phone denies superuser access.
  • The other reasons why this happens include a failed firmware update or a software problem.
Top 5 Ways to Fix Android Recovery Mode No Command
As everyone knows, commands in recovery mode are essential for managing and troubleshooting Android devices, especially during system malfunctions or software issues. Recovery mode allows users to perform critical tasks like wiping cache partitions, performing factory resets, flashing updates, and installing custom ROMs. No-command error will cause big trouble for users, and potentially render the device unusable in cases of severe software corruption or boot failures. However, Fixing the Android recovery mode with no command issue is not impossible. Here are 5 ways for you to solve it.
Fix 1. Fix Android No Command Error with DroidKit
When it comes to no command errors in Recovery Mode, DroidKit is a good choice standing out from many competitors. With wide compatibility, DroidKit can fix system issues on most Android devices, including Samsung, Xiaomi, POCO, etc. As a third-party tool, this software provides an easier and more reliable solution with a higher success rate in fixing the no-command error. With DroidKit’s help, users can fix Android no command in Recovery Mode without effort.
  • Works on both Windows and Mac computers to repair Android phones.
  • High success rate in fixing phone issues with advanced technology.
  • No need to root your device and no technical skills are required.
  • Fast fixing process and easy steps to solve problems within minutes.
  •  Also provides solutions for fixing stuck AndroidRecovery Mode not working, etc.
Now, follow the steps below to revive your dead device in a few simple steps:
Step 1. Get the latest version of DroidKit – Android System Repair on your computer. Launch DroidKit > Connect your Android device and tap on System Fix.
Click System Fix Function
Step 2. Once DroidKit detects your device, click the Start button to continue.
Start to Repair Samsung Phone
Start to Repair Android Phone
Step 3. DroidKit will match the PDA code of your Android Device Automatically > Then click Download Now to download the firmware.
PDA Code Matched
PDA Code Matched
Note: If there is no matching PAD code, you need to put your device into recovery mode and get the PDA code.
Step 4. After the firmware is downloaded, click the Fix Now button. Put your device into download mode.
Put Android into Download Mode
Step 5. Once finished, it will automatically start repairing your Android system. After completing the repair process, you will get the system fixed successfully page as below. All the system issues are fixed and your Android device will be restarted.
Completing the Repair Process
Fix 2. Force Restart the Android Device
Regardless of the issue, when your Android phone or tablet gets stuck anywhere, the first thing you should do is to force reboot your device. When you do this, the operating system of your phone is forced to turn off and then turn back on. This helps fix many minor bugs that cause the issue, and there is no harm in trying this method out. However, forcing a restart of your device might not work for all issues, and the success rate might be low for fixing the Android no command error.
1. Force Restart an Android Device
Press and hold down the Volume Down and Power buttons at the same time. Your phone should reboot.
Force Restart Android Phone
2. Force Restart a Google Pixel Device
Press and hold down the Power button for about half a minute.
3. Force Restart an LG Device
Press and hold down the Power and Volume Down buttons simultaneously.
4. Force Restart an HTC Device
Hold down the Volume Down and Power buttons and let them go when the phone vibrates.
Fix 3. Pull Out the Phone Battery
If force reboot did not fix the issue for you, and your device continues to display the no command error, you have a physical method to try. You can remove the battery from your device and this will turn your device off. This might help you come out of the no-command boot loop on your phone or tablet. However, similar to force restart, this method has a low success rate to fix the no command error in Recovery Mode.
Step 1. Remove the back cover of your device.
Step 2. Pull the battery out of your device.
Step 3. Keep the battery aside for two minutes.
Step 4. Put the battery back into your device and turn your device on.
Pull the Battery Out of Your Phone
Fix 4. Factory Reset the Android Device
How do I fix my Android it won’t boot into recovery. Don’t worry, since the no command error on Android devices is directly related to your phone’s system, there are not many methods to resolve this issue. One thing you can do, though, is to reset your device to the factory settings. You can do this either when your phone turns on or in recovery mode. However, this way will erase all your data on the device. If you don’t have a backup, and the data is important to you, you can choose other methods mentioned in the post.
1. Reset the Phone from Settings
If the no command error appears occasionally, you can reset your phone when the phone turns on just fine.
  • Open the Settings app and tap System at the bottom.
  • Select Reset options and then choose to Erase all data (factory reset).
Reset an Android Phone
2. Reset the Phone from Recovery
If you can get into recovery mode somehow, select the Wipe data/factory reset option.
Factory Reset Android
Fix 5. Flash a ROM
If your issue is still not fixed, one of the things you can do is install a ROM on your device. This should mostly work if you have a custom recovery like CWM or TWRP installed on your phone. You can download a compatible ROM for your phone from a site like XDA, and then use recovery to install it. Whereas, Flashing a ROM will also erase your data. The process might require some technical knowledge, and the wrong operations can cause the device to fail. This installs a customized version of Android on your device. This can potentially fix no command errors.
Step 1. Download a ROM for your device to your computer.
Step 2. Move the ROM ZIP file over to your phone’s SD card or internal storage.
Step 3. Get your phone into recovery mode and choose Install.
Step 4.  Choose the ROM you just transferred and install it.
FAQs about No Command Android
1. What is XOS no command meaning?
In XOS (the Android-based operating system commonly used on Infinix devices), “No Command” in recovery mode indicates that the device is temporarily in a state where it is waiting for instructions.
2. How to fix a phone that says “NO COMMAND” in recovery mode?
Fixing a phone that says “NO COMMAND” in recovery mode is easier than you might think. You can reboot your device, factory reset your device, or try various other ways to potentially fix the problem.
3. How to fix the no command boot loop on Android?
If you are in the no command bootloop on Android, your best solution is to either factory reset your device or flash a ROM on your device. This should fix the very core files of your device, and this should help get rid of no command errors.
This post covered 5 practical methods to fix the Android no command in Recovery Mode, including DroidKit, force restart, pulling out the phone battery, factory reset, and flashing a ROM. Among them, DroidKit is distinguished for its high success rate. Thanks to the intuitive interface and easy steps, Droid can solve the no-command issue on Android phones within minutes. Download it for free! Just give it a try.
