Has your Android device ever encountered a boot loop and failed to access the operation system? Don’t feel upset since this post offers 5 effective methods to get you out of the problem.
Free get DroidKit installed on your Windows PC or Mac computer. You can unfreeze your phone from boot loop screen. No matter Samsung Galaxy S5, or other Android phones like Xiaomi, Redmi, POCO devices , you can fix with it!
My phone was suddenly stuck in a never ending restart loop when I was in the middle of listening to a podcast and it would not even charge when plugged in. How do I fix Bootloop without losing data?
– An Android User
Android Stuck on Boot Loop
In recent years, the boot loop has become a more and more common issue for Android users. When it happens, the phone reboots by itself and won’t turn on, you can not switch it on or off. If a boot loop can not be fixed, your phone will keep stuck on the startup logo screen and you can not go into safe mode, or Android stuck in fastboot mode.
Then, how do I get my Android out of bootloop, how to fix bootloop without factory reset? Here in this post, we would like to introduce some proven methods, including the most effective Samsung bootloop repair tool, to help you fix a stuck boot loop.
What is the boot loop in Android? A boot loop happens when your Android smartphone continuously reboots without properly launching the operating system. It might make your gadget feel stuck in a loop, thus the name. Instead of returning to your home screen, the device repeatedly cycles through the boot-up process, rendering it nearly useless.
But what exactly causes a boot loop on Android? What is the fundamental reason for a boot loop?
A boot loop happens when there is faulty communication within the Android operating system, which prevents your Android device from completing its boot sequence and thus stuck in a boot loop, restarting itself repeatedly.
Android boot loop error is always caused by the following reasons:
That’s why your Motorola phone stuck on startup screen, LG phone, or other Android tablet stuck in reboot loop. Now, keep reading and get the most suitable ways for you to fix bootloop with a full factory reset, or without data loss.
You are encouraged to try on more than one method since whether you can get rid of the boot loop in minutes depends on the specific model of your Android phone and what caused the problem.
To fix Android boot loop, here are effective 5 ways.
DroidKit – Android Phone Toolkit is the top Android bootloop repair tool on the market. Its Android system repair allows you to download an Android boot loop fixer and get your phone back to normal mode. If you want to get out of the startup screen without factory reset, or get out of bootloop without recovery, check how can DroidKit help you as below:
Free get DroidKit and follow the steps to repair Android boot loop without factory reset:
Step 1. Download and install DroidKit on your computer > Click System Fix mode.
Click System Fix Function
Step 2. Connect your Android boot loop phone and click Start > DroidKit will get PAD code matched for your device > Click Download Now button to get the Android firmware package.
PDA Code Matched
Step 3. After downloading, click on Fix Now. Follow the on-screen instructions to put your device in Download mode> Tap on Next button to continue.
Step 4. After that, DroidKit will start fixing boot loop and other system issues on your Android. Once the repairing process is completed, you will get the System Fixed Successfully page as below.
Completing the Repair Process
One of the easiest ways of fixing the boot loop issue is to take out and reinstall the battery of your Android device. This soft reset operation can more or less fix the boot loop for your Android device without losing data.
To complete a soft reset operation fix, you can take the following steps:
Step 1. Firstly, you need to ensure your device is turned off.
Step 2. Use a tiny screwdriver to remove the back cover of your device.
Step 3. Pull out its battery and reattach it after a few seconds.
Step 4. Reboot your Android device to check if the boot loop issue still exists.
Remove and Reattach Its Battery
For Android models whose battery cannot be removed, you can simply shut down the device for a while. Then restart it to see if you can normally enter the operating system.
You can also try to remove SD card on your phone since some users reported it works. “I tried everything short of factory reset. finally, I remembered reading something saying to remove SD card and see if it would reboot normally. after my phone not doing anything but being stuck in the loop all day, I turned it on without sd card in it and it booted up normally and has stayed on with no problem! I have a moto e5 cruise.”
So, it is proven that pulling out SD card is one of ways to force Android phone to restart normally. Try it now.
Further Reading: How to Recover Data from Formatted SD Card >
Although the boot loop issue occurs for many reasons, most issues can be resolved by a factory reset. Since your operating system cannot run normally, you are unable to complete the factory reset under the Settings app. However, you are allowed to perform a hard factory reset using power and volume buttons.
Before you seek to hard reset your Android device, you need to note that normally a factory reset erases all your data and documents on your Android devices. Therefore, if you want to fix an issue through a factory reset, you’d better have backed up your Android device in advance.
Here is what you can do to complete the hard factory reset through power and volume buttons:
Hard Factory Reset The Device
Then your device will start to hard reset. You may need to wait for a few minutes until it completes the process.
Further Reading: How to Recover Photos after Factory Restet Android >
CWM custom recovery mode is one of the recovery modes developed for Android devices. It is used to replace or reinstall stock recovery features. You can use the CWM Recovery Mode to wipe the system of your Android device so as to address the boot loop issue. Every model of Android device can boot into its CWM custom recovery mode by pressing a combination of buttons.
Then you can reboot your phone to check whether your phone can launch in normal status.
CWM Recovery Mode
You may need: How to Fix iPhone Stuck in Boot Loop >
That’s all for fixing the Android boot loop issue. In rare cases, your Android device’s operating system is infected by a virus and you are suggested to ask a technician for help. If it doesn’t result from external violence, it mainly results from system issues. You can try the mentioned methods to get your device back to normal by yourself.
Don’t forget to try DroidKit to fix most system issues, including Android bootloop, Samsung black screen, stuck on Samsung logo, etc.
