How To Clear Cache and Cookies on Samsung
As it is important to clear cookies on your Android device, you can refer to this detailed guide to learn how to clear the cache and cookies on your Samsung phone. Take some minutes to make it so as to free up your Android phone!
Author Avatar Joy Taylor Last Updated: Jul. 05, 2021
Having trouble with unresponsive apps? Are apps on your phone crashing or is your phone running slowly? It may be a good idea to give it a quick cleaning. The good news is that you don’t need to uninstall the application or reset your device. Instead, clearing the cache data and cookies on your Android phone will delete any troublesome files or errors in the app.
This guide will help you with every possible way to clear cache Samsung and cookies on your Samsung device. You will find the solutions for clearing an app’s cache, cookies on the Samsung browser, and the ways for clearing cache with a click.
How to Clear an App’s Cache and Data?
Clearing the app cache is like a cleanse for your apps. It will get free of residual logs that could be slowing down the app. If you wish to clear an app’s cache and data, follow the steps outlined below, and you are done!
Step 1. Open the “Settings” of your phone.
Step 2. Swipe down and click on the “Apps” option.
Find Apps from Settings
Step 3. Select the application you want to clear the cache of and tap on it.
Step 4. Click on the “Storage” and then tap on “Clear Cache”, and you are done.
Click Clear Cache from Storage
If you also want to empty all the data of an app, you can enable that with ease. But you need to pay attention that all of this app’s data will be deleted permanently, including all files, settings, accounts, database etc. And you need to set up the app as you never used it.
Here’s how to clear an app’s data:
Also, go to Settings > Swipe down and find Apps > Click or search for one app > Click Storage > Tap on Clear data andf click OK to confirm.
Then all the data and settings will be deleted and reset this application to the original.
How to Clear Cache and Cookies on Samsung Browser?
If you wish to clear cache Samsung and cookies on the Samsung browser to get the optimal performance and smooth functioning, follow the steps given below:
Step 1. Open your “Samsung Internet Browser.”
Step 2. At the bottom right of the screen, click on the “Menu” or the “three-lined dots.”
Step 3. Go on the “Settings.”
Step 4. Under the Advanced option, click on “Privacy & Security.”
Step 5. Find the Personal Data option and select “Delete browsing data.”
Click Delete Browsing Data
Step 6. You can now select what you wish to clear from your browsing data. You can choose the browsing history, cache data, and cookies.
Choose to Delete Browsing History Cache and Cookies
Choose to Delete Browsing Data
Step 7. Click on the “Delete” option and done. It is that easy!
How to Clear Cache All at Once?
Your Samsung device utilizes cache data to store temporary files for the apps on your device. This cache data can eventually become bulky, consume excessive room in your device, or even slow down browsing. If you want to clear all cached data at once, you can use DroidKit to take a try.
DroidKit – Clear Cache Data All at Once
  • Clear Various Types of Junk: large files, cache files, APK files, etc.
  • Support Almost All Android – mainstream brands and system versions.
  • Select What to Clean: Preview and select what to clean with simple hits.
  • Speed up Android devices in simple steps.
Step 1. Launch DroidKit on your computer > Go to the Clean System Junk mode.
Click the Clean System Junk Mode
Step 2. You will see the Clean System Junk interface > Click the Start button to initiate the process.
Hit Start to Initiate the Clean Process
Step 3. Connect your Samsung phone to the computer > Hit the Start button again.
Connect Your Android Device via a USB Cable
Step 4. Now you can preview and select cache files to clean by taping on Clean Now.
Preview and select System Junk Data to Clean
Preview and Select Cache Data to Clean
Bonus Tip.  How to Enable Cookies on Samsung?
On the Samsung Internet app, you can manage your cookie settings for all websites in one place. It implies that you don’t need to control the settings for each website. Follow the steps outlined below if you wish to enable cookies on your Samsung device, and you are ready to go.
Step 1. Navigate to the “settings” of your Samsung device and open “Apps.”
Settings and Apps
Settings and Apps
Step 2. Click on the “settings icon”next to Samsung Internet.
Samsung Internet
Samsung Internet
Step 3. Select “Privacy and Security.”
Internet Settings
Internet Settings
Step 4. Tap on “Accept Cookies.”
Accept Cookies
Accept Cookies
Step 5. Swipe on the “switch ON toggle” to enable cookies.
Toggle Accept Cookies
While there are several methods to the question “how to clear cookies on Samsung and clear cache Samsung?”  We hope that by following the steps outlined above, you were able to resolve the problem in no time.
