Apps won’t open on your Android phone? Keep reading and follow this article to learn how to easily fix app won’t open Android issue!
Free download DroidKit to 1-click fix all Android system issues, including the “apps won’t open” error.
Android phones are widely used and favored by people all around the world. Nowadays, there are more and more mobile users who choose to use Android. Sadly, we accepted some feedback that some users encountered apps that won’t open on Android recently.
Previously, we have already talked about how to fix apps not opening on iPhone. In this article, we will mainly discuss the possible reasons why apps fail to open on Android and how to fix this issue with ease.
Suddenly, an app or some apps won’t open on your Android. In this part, I’d like to brief you on some specific reasons why an app or some apps fail to open on Android phones to fix this issue correspondingly. The possible causes of the app won’t open on Android might be no internet connection, the lack of storage space, corrupted software, data crash, and the outdated operating system version of your Android.
In this part, 6 effective solutions will be presented to help you fix apps not open on Android phone issues. Next, browse and choose the solution you prefer to easily address this issue!
Internet connection is a must in this era. Without the internet, we are not able to surf the internet, including opening some apps that require an internet connection when launching them.
Therefore, when you encounter apps that won’t open issues, please check the internet connection of your phone first. This is useful for both Android and iOS devices.
If you have checked the internet connection, and there are no problems here, it may be a system error. If so, you need a professional Android system repair tool. Here we give you DroidKit – Android Phone Toolkit. It is one of the best Android device system repairers that can fix almost all the system issues you may have known of.
DroidKit has reliable solutions to Android problems. It can solve problems like black screen, device frozen, touch screen not working, apps crashing, the camera failing, stuck on logo, etc. The best part of it is that you don’t need to root the device to do the things above. So you won’t lose the data while fixing the errors.
Let’s take a look at the steps to fix the “apps not open” issue with DroidKit.
Step 1. Download and launch DroidKit on your computer, connect your device to the computer, and choose Fix System Issue which is located in the middle of the interface.
Click Fix System Issues
Step 2. Tap on the Start button to go on issue fixing.
Click the Start Button to Continue Fixing
Step 3. Following the on-screen instructions, you will be asked to download the firmware. Once the firmware is downloaded, you need to put your device in download mode. Then, DroidKit will start to fix the issue.
Click Fix Now after Firmware Downloaded
Step 4. Minutes later, you will find your device gets restarted again which means the fixing process is completed.
System Fixed Successfully
As we mentioned above, the lack of storage space is also one of the major reasons why apps can’t be open smoothly on your Android. Under such circumstances, you’d better delete some useless apps, pictures or files, etc. Moreover, you can clear the cache and data of the app that won’t open on your Android.
Clear Contacts App Cache
When an app doesn’t work or can’t be opened, force closing and then restarting it might be a solution that is simple and effective. Here are steps to force close the app that won’t open.
After force-stopping the app, you can try to reopen it once again to check whether this solution works. To be more convenient, you can clear all the background apps that operating on your Android by accessing the multitasking interface and swiping these apps to close them.
Some apps can’t be compliant with the outdated operating system, that’s why the app won’t open on Android. Hence, you can go to Settings on your Android to check whether there has the newest OS version. Here, I will tell you how to update the Android operating system to the newest one.
Updating or reinstalling the app is one of the solutions that is worth having a try as well. To update it, you can do as follows.
In addition, you can uninstall the app and then download and reinstall it to fix the app that won’t open the Android problem.
When you fail to open the app, one extremely simple way you can try is to restart your phone which can fix most of the simple issues of both Android and iPhone. You can press the side button on your Android for a while until your phone pops up an interface, and then please click the Power Off option. After that, you can long-press the side button once again to restart it.
In this article, we mentioned 7 solutions to help you fix the app that won’t open the Android issue. All of them are easy to operate and effective. But to help you fix your problem quickly, we recommend you download and use DroidKit to fix the Android system.
