OK, got it
Fix Android WiFi is Connected but No Internet Access
Sometimes you will find that WiFi is connected but there is no Internet access on your Android device. If this happens to you, there are a few ways to deal with this issue and get access to the Internet. Here we show some of the effective ways to fix the issue.
Author Avatar Joy Taylor Last Updated: Jul. 25, 2024
Sometimes it happens that the hotspot is connected but has no internet, or your Android device connects to your WiFi network successfully but has no internet access. Then, no Internet connection will cause downloads don’t start and remain at 0%, Google Play not working, you can not surf the web page, etc. This usually happens when there is a problem with either your phone or the router.
Basically, if the connection between your phone and your router is working just fine, the issue lies somewhere internally and that is what the following guide is going to help you figure out. You will learn some of the common reasons why this issue occurs and how you can fix it.
Why Does My Phone Say no Internet Connection when I Have WiFi
A phone connected without internet usually means that your phone is connected to the WiFi, but can’t reach the internet. And, your phone is not getting an internet connection usually because of the internet provider first, including Router/Modem settings, IP conflicting, etc.
1. Issues with the Router
A common reason why your phone has a WiFi connection but no Internet access is that there is a technical issue with your router. If your router is experiencing any kind of bugs or problems, that affects how your Android devices stay connected to WiFi.
A faulty router cannot provide your Android phone with Internet access. As a result, your phone will connect to your router just fine but it will not be able to access the web.
2. Issues with the Internet Connection
It is possible that your router works just fine but there is an issue with your Internet connection. If your Internet is not reliable for some reason, your phone will be able to connect to the router but it will then not be able to further connect to the web.
This usually happens due to bad weather and broken cables of your Internet connection. Sometimes, this happens due to an error at your Internet service provider (ISP).
3. A Conflict with the IP Address
IP address conflicts are pretty rare but you might run into them sometimes. An IP address conflict is basically nothing but two devices on the same network acquiring the same IP address. When this happens, your router does not send the correct data to your phone and therefore your phone cannot access the Internet.
This issue usually occurs when the DHCP is not properly working on your router and is assigning the same IP address to multiple phones or other devices on the network.
4. DNS Problems
If you do not already know, the DNS servers help your device translate a website URL into an IP address. If a DNS server is experiencing issues, it can cause your Android phone not to connect to the Internet. This is very rare but it does happen and it can make the world wide web inaccessible on your device.
Now, check the methods below to fix WiFi connected without internet:
1. Restart Your Router
A major reason why you have an Internet access issue on your device is that there is a problem with your router. Therefore, the first thing you need to do is to fix your router.
WiFi Router
WiFi Router
If you are not into any technical things, the easiest way to fix the most common router problems is to reboot your router. When you do this, your router re-connects to your Internet service provider and all your settings get freshened up.
You can do that by turning the plug for your router to the off position. Then, wait for about a minute, and then turn your router back on.
2. Contact the Internet Provider Directly
If it is not just your Android device and you have no access to the Internet on your other devices as well, the problem might be with your Internet provider. In this case, it is best that you get in touch with them and ask them to help you fix the issue.
If there is an Internet outage or something, your ISP should be able to tell you about that. If there is another issue, they will be able to help you fix that with your router or your device.
3. Forget the WiFi Network and Reconnect to It
Sometimes, a simple fix like reconnecting to your WiFi network can resolve the Internet access issue on your phone. When you forget your network, your phone deletes the saved preferences of that network. When you reconnect your phone to your WiFi, your phone then gets assigned a fresh new IP address which helps it connect to the Internet.
Step 1. Head to Settings > Wi-Fi & network > Wi-Fi on your device.
Step 2. Tap your WiFi network and select Forget.
Forget the Details for WiFi Network
Step 3. Head back to one menu and tap on your WiFi network again to connect to it.
Step 4. Enter the password for your network and your phone will connect to it.
4. Assign a Static IP to Your Android Device
If your DHCP server fails to assign a unique IP address to your devices, it might be the time that you assign a static IP to your Android phone. This way, you will be able to avoid IP address conflicts, and if this is why you cannot access the Internet, getting a static IP will fix the problem for you.
Here we show how to do that.
Step 1. Head to Settings > Wi-Fi & network > Wi-Fi on your phone.
Step 2. Tap your WiFi network and then tap the pencil icon at the top.
Step 3. Expand Advanced Options and select Static from IP settings.
Use a Static IP on Your Android Device
Step 4. Enter an IP address in the IP address field, input other values, and tap Save.
5. Configure the Correct Date and Time Settings
It is important that you have the correct date and time settings set on your device. Incorrect date and time settings can sometimes lead you to experience issues, like the one you currently have.
It is actually pretty easy to set up the time and date on your phone, and you can do that as follows.
Step 1. Open Settings, scroll down, and tap System.
Step 2. Tap Date & time and then enter the correct date and time settings.
Configure Date and Time Settings
6. Reset Network Settings on Your Android Device
Whatever changes you make to your network settings, your Android device saves those changes for you. This way, the next time you are doing something, your phone can pull up your settings and perform the tasks accordingly.
It is worth resetting these network settings to see if that fixes the Internet access issue on your device. You can always reconfigure the settings when you want.
Step 1. Launch the Settings app, scroll all the way down, and select System.
Step 2. Tap the Reset options on the following screen.
Step 3. Select the Reset Wi-Fi, mobile & Bluetooth option to reset your network settings.
Reset Android Network Settings
You should only do this if you know how to reconfigure your network settings. Do not reset the settings if you then cannot reconfigure your phone.
7. Fix WiFi Connected without Internet Samsung
If all the methods above can’t solve your problem and you still can’t upload web pages, you may try out DroidKit Android system repair. It fixes almost all system problems on a Samsung device, such as Android black screen, Android phone frozen, Android stuck in fastboot modeXiaomi touch screen not working, etc. With an intuitive UI and a step-by-step tutorial, DroidKit makes the fixing process easy for everyone to follow. Download DroidKit and follow the steps below.
Step 1. Download and install DroidKit on your computer. Launch DroidKit and connect your Android device to the computer. after that, tap on the System Fix mode.
Click System Fix Function
Step 2. Once DroidKit detects your device, a page will show as below. Click the Start button to continue.
Start to Repair Samsung Phone
Step 3. The software will match the PDA code of your phone automatically. You need to click the Download Now button to download the firmware (If there is no PAD code matched, you need to put your device into recovery mode to get it).
Access Matched PDA Code and Download Firmware
Step 4. After the firmware is downloaded, click the Fix Now button to start the fixing process. Also, you need to follow the instructions to put your device into download mode.
Download the Matched Firmware
Step 5. After that, it will automatically start repairing your Android system. Wait a minute, the process will be completed and you will see a page below.
Completing the Repair Process
8. Reset Your Device to the Factory Settings
If nothing else worked, you can reset your phone as the final resort. This will remove everything that you have ever stored on your phone. You will lose all your settings as well. Make sure you have backed up your data safely and you can restore Android backup at any time. To reset your phone and fix no internet:
Step 1. Head to Settings > System > Reset options on your Android device.
Step 2. Tap the option that says Erase all data (factory reset) and follow the on-screen instructions.
Factory Reset an Android Device
Step 3. Set up your phone when the phone is erased.
This will reset everything on your phone and so be cautious while doing this. You will lose all your files and settings forever. Please back up your device before doing that.
You now know what to do if you ever find your Android device connected to WiFi but you have no Internet access. One of these ways will fix the issue on your phone giving you access to the entire world wide web. Among them, DroidKit is a solution worth considering. Download it and fix your WiFi problem.
