7 Ways to Fix Android System Intelligence Keeps Stopping
Do you have any issues with your Android system intelligence, and need to fix it? If so, you can apply any of the 7 tips for repairing Android system intelligence won’t update issues.
Author Avatar Joy Taylor Last Updated: Dec. 22, 2023
Android System Intelligence is one of the smartest innovations you will come across on an Android device that’s running on the latest operating system. This tech hosts several incredible features, which makes it the brainbox of your Android smartphone. Imagine an app that controls Live Caption, Live Translation, Auto Rotate, Voice Recognition, and more- all in one place.
Just like every other app, Android System Intelligence is often updated from time to time to enhance the performance, and clear bugs or glitches. While the update is free to download, many users still face issues trying to install it. So here we will focus on how to fix Android System Intelligence issues.
7 Solutions to Fix Android System Intelligence Keeps Stopping
Fix 1. Update Android System Intelligence in Google PlayStore
The Android System Intelligence feature is designed to update itself from time to time without issues. However, if you encounter Android System Intelligence won’t update automatically, then you should proceed with manual update.
Here’s the quick guide to follow to update Android System Intelligence manually on your device:
Step 1: Open Google PlayStore on your Android device by tapping on the appropriate icon on your mobile screen. On the page that comes up, enter Android System Intelligence in the search box and hit the Search icon.
Step 2: In response to your request, an interface with Android System Intelligence app will come up. Find the Update icon, and click on it.
Step 3: Ensure you are connected to a stable internet source for smooth and quick installation. Wait until the update is completely installed, then try checking your device again, it should be free of the issues you were experiencing.
Fix 2. Clear Cache on Google Play
Cache is a component of an app/software installed on a computer or mobile device capable of collecting, and storing data of all of the operations you carry out, so as to hasten and ease access in future. Some of the data collected, and stored on Cache include scripts, images, and more.
Although Cache comes in handy, it often slows down the operation of the corresponding app. It can cause Google PlayStore not to update important applications, like Android System Intelligence. When such happens, you have to clear the Cache on Google Play.
Here are the instructions to do that:
  • Unlock your Android phone, and click the gear icon to access the Settings menu page.
  • Head down the page, and click on Applications
  • Another screen should come up with all of the applications available on your device. Locate Google PlayStore, click on it and select Storage
  • Now click CLEAR CACHE.
  • Once done, proceed to install Android System Intelligence from Google PlayStore again.
Clear Cache on Google Play Store
Fix 3. Restart Android
Should Android System Intelligence still fail to update after the solutions above, then consider restarting your device. There is a possibility that your device is running down on operation due to bugs or temporary glitches.
Rebooting the phone is the best way to restore the operation back to normal. Here’s how to do this on your Android device:
  • Hold down the Power icon until you find a screen similar to what we have below:
  • Click Restart, and your device will go off in response to your command.
  • Wait a while, and it will come up itself.
Restart Your Android Device
Fix 4. Update Android Software
Another quick and cost-free solution to fix Android System Intelligence won’t update is to install the latest OS on your Android device. Android develops new updates from time to time to help enhance the performance of all devices running underneath its operation.
You must install the update to get the best from your device.  Failure to do that can cause your device to malfunction, and you get issues like Android System Intelligence won’t update, frozen screen, and more.
To avoid such, follow the directions below to update your Android operating system:
  • Connect your Android phone to a stable WiFi source, or cellular network.
  • Hit the gear con on your Home Screen to open Settings.
  • Select System on the next screen.
  • Next, click System Update (also known as Software Update on some devices).
  • In case there’s an update, you will find the Download and install icon. Click on it to install the update. Once the update is completed, try updating the Android System Intelligence again.
Choose the "System Update" Option
Choose the “System Update” Option
Fix 5. Using Android Repair Tool
An Android Repair Tool is the next available option to fix Android System Intelligence won’t update issues, and DroidKit is a great software in this case. With DroidKit, Android users can easily fix their devices, and clear any bugs cl slowing down the operations.
DroidKit – Fix Android System Intelligence
  • Fix various Android OS issues in minutes.
  • Find the best solution for your Android problems.
  • No need to root your Android device and no technical skills are required.
  • Revive dead Android devices in a few simple steps.
Step 1. Free install DroidKit and open the program on your computer > Click the System Fix mode.
Click System Fix Function
Step 2. On the System Fix page, you can read the notes before hitting the Start button to initiate the process.
Start to Repair Samsung Phone
Step 3. DroidKit will match Android PDA code automatically > Click  Download Now to get the firmware package, which is used to repair the system issue.
Access Matched PDA Code and Download Firmware
Step 4. When the firmware is downloaded, please follow the instruction to put your phone in Download Mode > Tap on the Next button to continue. When the Fix process is complete, you will see the page below.
Completing the Repair Process
Fix 6. Reinstall PlayStore
PlayStore is a system app where every other installable app can be installed. It’s readily available on every Android phone, and should always update itself. In a scenario where it doesn’t, you may experience Android System Intelligence won’t update.
To fix that, we advise that you reinstall the app. Here’s how to reinstall PlayStore:
  • Launch the Google PlayStore app, and click on your profile icon, which is situated on the upper right corner of your screen.
  • Select Settings and click on the About. Confirm that you have the latest PlayStore version. If you don’t, kindly download APKMirror Installer
  • Launch the APKMirror Installer to download Google PlayStore APK version. Once done, click Browse Files, and find Google PlayStore APK on the list.
  • When you find it, click Install Package, and tap on the appropriate buttons to get your Google PlayStore updated.
Fix 7. Factory Reset Android
Lastly, we have factory reset Android as the next solution to fix Android System Intelligence won’t update. This solution helps you restore the corresponding Android device by bringing it back to default mode, just like when you newly bought it.
To factory reset Android, follow the instructions down here:
  • Open your Android phone and click on Settings
  • Locate the Backup and Reset button, and click on it.
  • Next, click Factory Data Reset to proceed.
  • Another screen will come up for you to confirm your action. Click Reset Device > Erase Everything
Note: The method above works for Android devices running on the latest OS. If your Android runs on an older OS, follow the steps below:
  • Tap on the Settings icon, and select General & Backup and Reset.
  • Next, hit the Factory Data Reset icon.
  • After that, tap on Reset Device > Delete All
Perform Factory Reset
Your Android device should reset in no time. Once done, try to update the Android System Intelligence app again. There shouldn’t be any issues.
FAQs
Find below some popular queries about Android System Intelligence won’t update, and the corresponding answers:
Q1. Why you shouldn’t uninstall or disable Android System Intelligence?
Android System Intelligence is a core part of an Android device. It’s responsible for several automated tasks such as Live Caption, Voice Recognition and more. An attempt to uninstall or disable it means you are willing to take full control of all automated operations, which can be challenging.
Q2. How can I reset Android System Intelligence?
Below, we have the guide to reset Android System Intelligence on an Android phone:
  • Launch Settings by simply clicking on the gear ⚙️ icon on your Home Screen.
  • Next, tap on Apps and Notifications and scroll down to where you have the Android System Intelligence icon. Click on the icon to proceed.
  • Now tap on Storage > Clear Data
  • Hit the OK button to confirm your entry.
Final Words
Fixing Android System Intelligence won’t update issue shouldn’t be a challenge anymore with the guide above. We shared the 7 hacks required to repair your Android System Intelligence. Apply now to save your device.
Our best pick from the solution involves DroidKit. The software repairs your Android phone without crashing the system, or clearing the data on it. Install it today to fix your device.
