Unplug the headphone from Android but the phone stuck in headphone mode? Here are the reasons why this issue happens. Find your solutions to fix headphone mode stuck in this post.
Headphones are one of the most common Smartphone accessories that enable you to listen to music or talk to your friends and colleagues without having to hold the phone. However, Android devices can get stuck in the Headphone Mode after you unplug the headphones which prevents you from using them normally.
Even though this problem can be frustrating, it is easily solvable. In most cases, you won’t have to take your phone to a licensed Android repair center since you can handle this problem on your own. In this article, we are going to explore some of the best solutions to the Android phones stuck in the Headphone Mode issue.
Also Read: How to Fix An Android Phone Not Receiving Texts >
A temporary software glitch is the most common reason why your device remains in headphone mode after you unplug the headphones. It may trick the device into thinking that the headphones are still connected to it which prevents you from using it normally. Moreover, a faulty headphone port may be the reason why the device doesn’t recognize that the headphone jack was removed.
Sometimes, users may think repairing the headphone port may be the only way to get your phone unstuck from the Headphone Mode. Also, there are some proven methods that you can try to fix the issue.
There are a number of routine actions you can perform that will enable your Android phone to recognize that it should exit the Headphone Mode. So, let’s take a look at how to get Android phone off headphone mode.
The quickest way to get rid of the issue is to get Android system repair once you are stuck in headphone mode. DroidKit has developed a special mode – Fix System Issues to help Android users fix various types of problems considering an unstable Android operating system.
With the help of DroidKit, you can easily and quickly get out of the dilemma when Samsung is stuck in black screen, Samsung suffers from the white screen of death, Samsung touch screen is not working, etc. Check some of DroidKit’s features below.
Step 1. Download and install DroidKit on your computer. Launch DroidKit and choose System Fix mode.
Click System Fix Function
Step 2. When your device is detected by DroidKit, choose the Start button.
Click the Start Button to Continue Fixing
Step 3. DroidKit will get the PAD code. Please click the Download Now button to get the firmware package.
Start to Download Firmware Package
Step 4. After downloaded, choose Fix Now, and follow the instructions to put your device into Download Mode.
Get Your Phone into Download Mode
Step 5. After that, DroidKit will start fixing the problem of your device automaticlly. When the fix process is complete, you will get the System Fixed Successfully page on the screen.
If you notice that your phone remained in the Headphone Mode after you removed the headphones, you should simply insert the headphones again. This should give the device the command to enter this mode again.
Unplug the headphone jack from the device and check if the device is stuck. If the device is still in this mode you should repeat this process several times to check if it produces any results.
In case your attempts to exit the Headphone Mode by removing and reinserting the headphones have failed, you should restart the phone. The device’s OS may be experiencing a glitch and a reboot will enable it to resolve the issue that caused the glitch.
Restart the Device
Restarting an Android phone may not be enough to get it to exit the Headphone mode. However, turning off the device and taking the battery out may fix this issue. Most modern Android phones don’t have removable batteries, so this solution is only available if you have a model with a removable battery.
Pull the Battery Out of Your Phone
If you have an Android phone with a removable battery, you should take a few minutes before reinserting it and switching on the device. The problem should be resolved once you reenter the phone’s interface.
Also Read: How to Fix Android Battery Drains Too Fast >
A piece of dirt that is stuck in the device’s headphone port can be the reason why it remains stuck in the Headphone Mode. Carrying your phone in your pocket increases the chance of dirt reaching and blocking the headphone port.
Using a cotton swab that is thin enough to enter the headphone port will enable you to remove the dirt.
Faulty headphones can also be the reason why your phone cannot exit the Headphone Mode. Plug in a new headphone set into your device to see if it remains stuck. This method will enable you to quickly determine if the headphones were causing the problem.
Optionally, you can install an app like Disable Headphone to overwrite the current audio settings on your device.
If none of the above solutions work, you should try resetting your device to the factory settings. You should keep in mind that all your data is going to be deleted from the phone and that you should create a backup before initiating the factory data reset.
Here’s how you can reset an Android phone to the factory settings.
1. how to turn off headphone mode on Android (without headphones in)?
To turn off headphone mode on Android without headphones, try these steps:
2. why is my phone connected to headphones when it’s not?
Your phone may appear connected to headphones when it’s not due to:
3. why does my phone say I have headphones in when I don’t?
Your phone may indicate headphones are in due to:
There is no reason to panic if your Android phone is stuck in the Headphone Mode since this issue can be resolved quickly. Plugging in and unplugging the headphones a few times, restarting your phone, cleaning the headphone port, or download and use DroidKit to repair the Android system issues are some of the most common solutions to this issue. We hope that this article has helped you unstuck your phone from Headphone Mode. Leave a comment and let us know.
