Are you faced with the dropping call issues on your Android phone? If so, and you need to fix it, then you can try any of the 9 hacks shared in this post.
Hi there, Recently, I observed that my calls keep dropping for no reason. I’ve tried asking the other participant to host the call but it’s the same thing. So I decided to come here to seek help. Does anyone know how to fix dropping calls? Please help out!
Dropping calls on iPhone or Android is one of the greatest nightmares you may encounter on a mobile device. It’s a common issue, which involves the sudden disconnection of phone calls without any physical interaction, whether on the host’s end or the participant’s.
Although it can be frustrating, there are ways to fix it. We will walk you through the various techniques to fix dropping calls on your Android phone without stress. Let’s dive in.
Call Drop simply means the sudden disconnection from a phone call. It’s one of the most annoying issues you get to encounter once in a while, and it’s not limited to your phone brand, or network provider. without finishing the conversation.
This issue (call drop) can be quite provoking, especially when you are in a business call with your clients. Call drop occurs for several reasons, from poor network to exhausted airtime, faulty screen, and more. We will discuss in detail what causes Call Drop in the next section of this article, so read on.
There are several reasons you may encounter Call Dropping issues on your device. Some of them are listed below with detailed explanations:
A cellular network requires several cell towers to establish a connection, whether call or internet. If your phone cannot receive a signal from a nearby tower, then Android phone dropping calls will occur.
Do you reside in an area with poor cellular network? If so, then you can experience sudden disconnection while hosting or participating in calls on your Android device.
Another potential reason why you face Android phone dropping calls could be attributed to a malfunctioning device, which could be software, or hardware related. Hardware related issues range from broken screen, to damaged SIM Cards, and more. For software related issues, we have outdated OS, or firmware packages.
As we all know, radio waves, which are responsible for network connection, can only travel several miles from the source (cell tower). The farther you are from the tower, the weaker the network connection, which in turn leads to Android dropping calls issues.
Fix Android phone dropping calls issues today using any of the solutions given down here:
A quick solution to fix Android phone dropping calls is booting the corresponding device to Safe Mode. This solution helps you analyze the device, so as to figure the potential cause of dropping calls.
You can put your Android phone in Safe mode by following the illustrative guide below:
If the steps above fail to work due to faulty screen, then follow the one down here, so you can use your buttons to enter Safe Mode:
Allow the Phone to Enter Safe Mode
After you’ve successfully entered Safe Mode, try hosting a call with your device to see if dropped calls still occur. If the problem clears, then there’s an app causing your phone to malfunction. However, if Android phone dropping calls persists, then the problem is with your network provider.
Do you use third-party applications like Truecaller for your phone calls? If so, and you experience Android phone dropping calls issues, then you should consider force quitting the corresponding app.
To do that,
If the above doesn’t work, you can try checking Google PlayStore for new updates. Should you come across any update on the app, kindly download it.
However, if the problem persists, you can try to install another calling app entirely via Google PlayStore. There might be an issue with the previous app you are using.
If you experience dropped calls while hosting, or participating in online calls, then you need to refresh the network settings to stabilize connection. Here’s the simple way to do that on your Android phone:
Reset Android Network Settings
Your SIM Card is the powerhouse to any operation, whether internet related, call hosting, or texting, you are carrying out on your mobile device. The SIM Card must be physically intact, as in undamaged. Also, it must be well positioned on the SIM Card tray for you to connect smoothly.
Another effective solution to Android phone dropping calls is toggling between Airplane modes. This solution helps you to refresh your cellular network, so it starts working properly. Follow the simple instructional guide below to toggle between Airplane mode on your Android phone:
Alternatively:
As we all know, Android updates its system from time to time. The update is aimed at improving the features, and clearing bugs, so as to enhance the performance. All devices running on Android operating systems are required to download the update to enjoy everything the new product has in store. Failure to do this can cause troubles like Android phone dropping calls, frozen screen, and more.
To avoid such troubles, follow the guide below to install the latest updates on your Android phone:
Choose the “System Update” Option
Sometimes background apps can cause your device to drop calls abruptly, especially when you run too many of them at the same time. In such a situation, you have to close all running apps to host, or participate in calls conveniently.
Should all the solutions above fail, then an Android repair tool is what you need to fix your device. Though there are lots of them on the net, DroidKit is the most trusted for the job.
With DroidKit, you can fix Android phone dropping calls from the comfort of your home without complications. This intuitive Android repair tool features everything you need to get your faulty Android phone working again.
Whether you encounter frozen screens, unresponsive keys, black screens, or any Android related issues, DroidKit can be of help. The repairs your device by recommending a compatible firmware package, which must be installed to fix it.
Step 1. Download DroidKit on your computer, open it and go to the System Fix panel.
Click System Fix Function
Step 2. Connect your device and tap on the Start button.
Start to Repair Samsung Phone
Step 3. Get a matching code and click Download Now to get the corresponding firmware. If there is no code matched, put your device into recovery mode first.
PDA Code Matched
Step 4. When the firmware package is downloaded, tap on Fix Now button. Then put your device in download mode, and click the Next button to continue.
Step 5. After that, DroidKit will start the repairing process. Wait a minute, and you will get the system fixed successfully page as below.
Completing the Repair Process
If you haven’t solved the problem of Android phone dropping calls after trying all the above methods, then you need to consider whether the phone has a hardware problem. Usually if the phone has been dropped from a high place or into the water, then there is a high probability of hardware problem.
Now you know why an Android phone drops during calls, and the possible solution to fix it. Apply two or more of the solutions to repair your device and start enjoying my endless call sessions on your device.
The best solution for us is the one involving DroidKit. This software has proven to be the best overtime. So you should try it out now.
