Retrieving photos from Samsung Cloud can be a challenge but not when you have the ultimate guide shared in this post at hand. Here, we discuss in detail how to retrieve photos from Samsung Cloud, plus what could be backed up to the cloud storage media.
With DroidKit, you cna easily retrive photos from Samsung phones, and Samsung Cloud. Not only photos, you can also recover contacts, messages, call logs, etc.
Hello, I used the Samsung Cloud to sync my photos in the past, and now I wish to retrieve and store them on another device. Is there any way I can do this?
Sounds familiar right?
Well, there is no doubt that Samsung Cloud is one of the most innovative cloud storage facilities available for Samsung owners to store valuable data online. While the storage facility is capable of keeping data, you can also count on it to restore the stored data.
However, you must be experienced to carry out data restoration services. For folks who don’t know how it’s done, this post is here to guide you. Here, we focus on how to restore photos from Samsung Cloud. So read on!
Samsung Cloud is one of the game changers in the cloud storage industry, and has been around for sometimes now. However, recently, Samsung announced the closure of the cloud storage service, and that has left most users with the question: how do I access my Samsung Cloud account.
If you find yourself in a similar scenario, you can apply the guide below to access your Samsung Cloud profile today:
For Mobile Users
For PC Users
The Samsung Cloud storage system is capable of storing a large number of data types, ranging from photos to videos, music, documents, and more. You can also use this storage facility to keep emails, passwords, and other essential data on the internet.
However, mind you, your data files can only be backed up to Samsung Cloud if you sync them. Syncing your data to Samsung Cloud can be done manually or automatically. But we advise you to select the automatic process, so the days you fail or forget to backup manually, your data can sync naturally to the Samsung Cloud.
Retrieving photos from Samsung Cloud is pretty straightforward. You can do this directly from the Samsung Cloud itself or using a third party software. Here, we will look at how to retrieve photos from Samsung Cloud using the storage media itself.
However before then, let’s discuss how to enable Samsung Cloud for syncing photos. You can follow the steps below:
Step 1: Head to the Settings panel on your Samsung device and select Account and Cloud > Samsung Cloud.
Head to Samsung Cloud
Step 2: Login your Samsung Cloud credentials to access your profile page. You will be directed to a new page with your name on it. Locate and click the three vertical dots at the top right corner of your screen and select Settings from the options that pops up.
Step 3: Next, tap on Sync and Auto Backup icon to enable syncing over WiFi connection. On the next screen, toggle the slider beside each data file you want to sync. Once done, tap on the Sync Now button to enable manual synchronization of data.
Step 4: Now open the Samsung Cloud screen, then scroll down to the Gallery section, and click Sync > Albums to upload. Once you’ve completed the step above, your photos in the gallery will automatically sync to Samsung Cloud. Apply the instructions down here to retrieve photos from Samsung Cloud.
Step 5: Open the Settings pane, then scroll down and click Accounts and backup. Select Samsung Cloud when the next screen comes up.
Step 6: Now click Gallery > Trash, then select the lost or missing photos you want to retrieve. Once the selection is completed, tap on the Restore icon and your photos will be retrieved immediately.
Check App’s Recycle Bin
Note: Mind you, if you’ve cleared all photos in trash, you cannot retrieve them via Samsung Cloud, as Samsung will have cleared them from its database. Another dark side of this solution is that it takes several days for photos to appear on your device, and sometimes you may lose quality.
Restoring photos directly from Samsung Cloud is time-consuming, as you need to ensure the corresponding image has been backed up to the cloud storage service in the past. But what if you find yourself forgetting to back up to Samsung Cloud, or if the backup process fails and you lose those precious photos? Well, there’s an alternative way, which involves the use of a professional software like DroidKit.
DroidKit is a powerful data recovery solution majority of Android users use to retrieve lost or missing files. This software ensures your data is retrieved with high quality. It recovers over 13+ Android data types including photos, videos, documents and others.
Step 1. Download DroidKit and install it on the computer. Meanwhile, connect Samsung Galaxy to the computer with a fine USB cable. Go to Recover Lost Data and choose Deep Recovery from Device.
Choose Deep Recovery from Device under Data Recovery
Step 2. Choose the data category to scan. You should unselect all the data and only chose Photos. Then tap the “Start” button.
Select the Data Type You Need to Recover
Step 3. It won’t take minutes to get all the photos your device wants. You can preview the photo and choose the one to retrieve “To device” or “To PC”. Wait a sec, your photos will be recovered successfully.
Select Android Photos to Recover
Now that Samsung Cloud is shut down, you have another option created by Samsung itself- OneDrive. With OneDrive, you can easily backup and restore photos online without stress. This online storage facility stands out, as it offers smooth backup and restoration services, plus it’s very easy to use.
You can backup or restore your Samsung photos with OneDrive by applying the appropriate guide.
Sync and backup your photos to OneDrive by applying the steps down here:
Step 1: Launch the Gallery app on your phone and click on the Menu button at the bottom of your screen.
Step 2: Tap on Settings, then select Sync with OneDrive to backup data to your OneDrive account. You may be asked to sign in your Microsoft account. Kindly do so, so you can upload your photos to OneDrive.
Click Sync with OneDrive
Follow the steps down here if you’ve synced your photos to OneDrive in the past:
Step 1: Open a web browser on your mobile phone, and head to OneDrive official website.
Step 2: Find the image you want to restore and click on it. Hit the Download button to commence restoration. However, if you cannot find the download icon, kindly click on the three vertical dots at the upper right hand side of your screen, then select Download from the options that appear.
Download Photos to Restore
Although the page is still up, the Samsung Cloud storage facility is no longer available. Thus, you cannot sync, backup or restore data using the storage media.
Samsung Cloud offers free storage services with storage space as low as. This space is expansible, however, it comes with a cost. The table below shows the cost for the different Samsung Cloud storage packages:
50GB: 0.99$
200GB: 2.99$
With our ultimate guide at your fingertip, you can retrieve photos from Samsung Cloud without hassles. We introduced how to bring back photos directly from Samsung Cloud, plus with the aid of a professional software like DroidKit.
DroidKit retrieves photos at a remarkably high speed without compromising the quality, so it’s worth investing into. Additionally, the clean interface makes it the best data recovery option amongst others in the industry.
