Accidentally removed some significant Kik files from your Kik chat history? Don’t panic, 3 methods in the follow-up text will help you recover Kik messages and pictures from Android phone.
Kik Messenger, as one of the most popular chatting apps on both Android and iOS devices, has a large number of registered users and plays an important role in the user’s daily life. The mistaken deletion of phone content that should not be deleted always happens, Kik files are no exception. The messages and images in Kik chat history mean a lot to users, then how to recover deleted Kik messages and pictures if you encountered this misfortune?
This article is going to share with you easy and effective ways to recover deleted Kik messages or pictures on Android phones. Keep reading and get the methods to get lost or deleted Kik messages and images effortlessly.
Also Read:
What to Do When Kik Not Working >
How to Fix Kik Images Not Available Issue? >
Many users may not know that Kik Messenger will auto-save the last 600 messages in a conversation for at least 48 hours and 200 messages that exist for more than 2 days. If you accidentally deleted some messages or pictures records with someone, maybe your friend or colleague, you can ask them to check the Kik history on his or her phone and sent you again. It’s easy to make it, why not have a try?
Recover Kik Messages & Images from Kik History
Thanks to the built-in “backup & restore” feature of Android, it will be easy to recover deleted Kik messages and images if you have backed up your Android phone before. Here are the steps:
Also Read: How to Save Kik Photos 2021 >
If you don’t want to bother your friends or colleagues and have no available backup either, then the ultimate method to retrieve deleted Kik messages and pictures is using professional Android data recovery. Here we recommend you one of the best Android data recovery – PhoneRescue for Android data recovery. Why? Since it will bring you great convenience and lots of benefits.
Prior to following the below steps of recovering deleted Kik messages and pictures on Android, download and install PhoneRescue for Android and run it afterward.
Install PhoneRescue for Android on your Mac or PC computer, then connect your Android phone via its USB cable.
Recover Kik Messages & Pictures from Android without Backup – Step 1
Check the data categories, it will select all categories by default, uncheck all, and select App Documents and click the Next button.
Recover Kik Messages & Pictures from Android without Backup – Step 2
Preview the deleted Kik files and select the one(s) you prefer > Click the To Computer or To Device button on the bottom right corner to begin the recovery process.
Generally, making a Kik backup regularly will minimize the lost risk of your Kik messages. Known for all, backup sure takes lots of space on phones and would slow down the phone working stream. Therefore, easily backing up Kik messages to the computer or choosing a reliable third-party tool to keep the Kik data will be good.
Now you may want to meet AppTrans, a tool that not only can it back up your Kik messages on the phone, but also supports transfer apps between different phones, restore app and app data from various backups, and install apps you may need in an easy way. Furthermore, it can make WhatsApp data migration between Android and iPhone possible.
App Backup Overview
Hope you can get back your deleted Kik messages and pictures from your Android phone with the above 3 methods. Nobody wants to lose important data, thus it is necessary to regularly backup your phone content in case of data loss. Just give it a try on PhoneRescue, the sooner you turn to it for help, the bigger chance you will recover what you want.
