Proven Ways to Recover Data from Phone That Won’t Turn On
Are you looking for ways to recover data from phone that won’t turn on? A phone that won’t turn on might seem useless, but you can still retrieve the data from it by using the effective methods that we have listed here! Read on and solve your issue without any hassle!
Author Avatar Joy Taylor Last Updated: Mar. 11, 2025
DroidKit – Recover Data from Dead Phone Without Backup
If your phone won’t turn on, how to recover data on it? Don’t worry, free download DroidKit to recover data from a phone that won’t turn on within only a few minutes. Covers all data types like pictures, videos, etc. No skills requirements. Supports all Samsung device models.
Android is always a good-to-go device that boasts various features but sometimes creates issues due to system errors. One common issue faced by multiple Android users is that their devices won’t turn on. In this situation, how to recover data from phone that won’t turn on might be a great challenge. Many users reported that they want to retrieve pictures from a Samsung Galaxy phone that is not turning on but don’t know how. Don’t panic! Here we’ll share top solutions to recover data from phones that won’t turn on, as well as some quick fixes to fix dead phones without data loss.
Also Read: How to Recover Data from iPhone that won’t Turn on >
Can You Recover Data from Phone That Won’t Turn On?
Before moving on to the methods recover data from phone that won’t turn on, it’s crucial for you to know why this issue arises and whether it is really possible to get data off a phone that is not turning on. Firstly, talking about the reasons behind this problem, then your Android device won’t turn on due to any one or more reasons stated below!
  • Your Android device is frozen in sleep mode or power-off mode. In this case, it will fail to switch ON when you initiate it.
  • The battery needs to be charged.
  • The installed software or Operating System might be corrupted.
  • Your Android device is clogged up with lint and dust, thus causing the hardware not to work perfectly.
  • The Power Button is broken and the required action can not trigger your Android device.
As you have got to know the reasons why your Android device won’t turn on, now it’s time for you to know: Is it possible to retrieve data from a dead phone? The answer to this question is “YES”! Fortunately, you can quickly recover data from a phone that won’t turn on, but this is possible only if you follow the right methods. So, let’s discover the best methods to do this in the following section of this article.
    How to Recover Data from Phone That Won’t Turn On?
    How can I retrieve data from a broken phone that won’t turn on? Due to the availability of data in the SD Card or phone backup, you can quickly recover your data on it simply by using your PC. So, just read on to learn the top ways to solve how to recover data from a phone that won’t turn on.
    Solution 1. Extract Files from SD Card Android
    The first and foremost way to recover data from phone that won’t turn on is by extracting files from the SD card. For this, you simply need to retrieve the data by using a USB card reader. If the SD card is encrypted, then accessing its data from a phone that can’t be powered on is almost impossible due to security measures. USB debugging needs to be enabled, otherwise, external tools cannot interface with the device to recover data. Also, contacts on the phone cannot be recovered. Now let’s see how to get pictures from a broken phone that won’t turn on Samsung/Android in this way.
    Step 1. Remove the SD card from your Android device and insert it into the USB card reader.
    Step 2. Now, connect the USB card reader to your PC.
    Step 3. Once the computer detects the USB card reader, all the data saved in your Android phone will be displayed on the screen.
    You can try to open the file and check the relevant data that you are looking for! If you found your SD card is accidentally formatted, try to recover files on the formatted SD card here.
    Solution 2. Recover Data from Phone Backup
    Another way to recover data from phone that won’t turn on is by using the phone’s backup. You can use multiple cloud storage services like Google Drive to back up the data from the internal memory of your dead Android device. However, if you don’t back up your phone, the unbacked-up data won’t be retrieved by this method.
    Here’s a detailed guide on how to recover data from broken phone via Google Drive backup:
    Step 1. Go to Google Drive’s official website on your PC and log in to your Google account with the email ID that is linked with your Android device.
    Sign into your Google Account
    Step 2. On the main interface of Google Drive, click on “Storage” and then tap on “Backups” option at the top-right corner of the screen.
    Click on Storage and Backups
    Step 3. Here, you will see the latest backup of all the devices connected with your Google account. You can simply click on the backup file related to your Android device and hit the “Download” button to recover the backup on your PC.
    Choose and Download the Backup that you Need
    It was easy to recover data from the phone that won’t turn on by using phone backup!
    Solution 3. Recover Data from Dead Phone Without Backup
    Although the above methods can recover data, they contain some restrictions, such as data type limits, backup requirements, etc. Here we recommend DroidKit – an Android Data Recovery tool to help you recover data from phone that won’t turn on without limits. DriodKit supports recovering 13 data types, like pictures, contacts, messages, WhatsApp & Line media files, etc. It covers all broken Samsung devices caused by any system issue. Whether your phone is non-working, water damaged, black screen, etc., you can recover data from your phone with DroidKit. No USB debugging and backup are required. Before recovery, you can also preview your internal data and extract them selectively or wholly.
    Main Benefits of DroidKit Data Recovery Tool:
    • Retrieve data from Android without backup.
    • No USB debugging & technical skills are required.
    • Fast process to recover data from dead phones in minutes.
    • Supports preview before Android data recovery.
    Here’s how to recover data from a phone that won’t turn on:
    Step 1. Get the latest version of DroidKit for free on your computer (supports Windows PC & Mac). Launch the software and connect your dead phone > Head to Extract Needed Data and choose From System System Crashed Device.
    Select Extract from System Crashed Device
    Step 2. Preview what data type that you can recover with DroidKit. Here we take Photos as an example.
    Select Photos and Start
    Step 3. Put your device into recovery mode and get a PDA code. Then enter the code and click Download Firmware to fix broken system.
    Enter PDA Code
    Enter PDA Code
    Step 4. Once you get the System Fixed Successfully page, you can tap on Scan Now button.
    Crashed System Fixed Successfully
    Step 5. Later, all your photos in the internal storage will be listed here. Choose the wanted files to get pictures off the phone that won’t turn on.
    Select the Data to Recover from Crashed Phone
    Try to Fix the Phone that Won’t Turn On without Data Loss
    With the above ways, you can successfully recover data from phone that won’t turn on. And here, as a bonus tip, we will let you know some of the best quick fixes to fix the Android device that won’t turn ON. All these quick fixes are easy to get your hands on, and you will be able to fix your Android device without causing any data loss!
    Method 1. Wipe Cache Partition
    Your Android device creates cache files so that the applications and software on your device can be accessed more quickly than before. So, you can simply try wiping the cache partition to turn ON your device but always remember that you won’t lose any data to enter Recovery Mode and wipe the cache partition.
    Here’s a guide on how to wipe cache partition on a Samsung device!
    Step 1: Long press the “Volume Up” button + “Home” button and “Power” button simultaneously.
    Step 2: Leave the “Power” button only as soon as the Samsung logo appears on the screen with Recovery Mode on.
    Step 3: Now, use the “Volume Down” button to navigate to the “Wipe Cache Partition” option and press the “Power” button to make a selection.
    You have successfully cleared the cache partition in your Android device. You can now check if your device is turning ON or not! If no then try fixing it with the next method.
    Method 2. Remove the SD Card
    The SD Card or Memory Card in your Android device might be a possible reason that won’t let your Android device Turn ON. So, you can simply try to move the SD Card out from your phone and reboot your Android device.
    Take Out SD Card
    Take Out SD Card
    If you are able to turn ON your Android device after removing the SD card, then the SD Card is to blame.
    If you want to recover data from your SD card, check this guide: The Best SD Card Recovery Software for Android >
    Method 3. Charge Your Android Device
    If your Android device refuses to boot at all even after pressing the “Power” button, then it might be out of power. Basically, it won’t boot instantly after your charge it because the battery might be completely drained out, and therefore you need to wait for a few minutes to let your phone turn ON.
    So, simply plug in the charger to your Android device, leave it for 30-40 minutes and then try turning it ON.
    With any of the 3 methods above, you can easily fix your Android device that won’t turn without causing any data loss!
    FAQs about Data Recovery from Dead Phones
    Q1: How to Recover Data from Samsung Phone That Won’t Turn on?
    If you want to recover data from a dead Samsung device, there are still some ways to recover data, depending on the cause of the problem. For common issues, retrieving data from an SD card and phone backup would solve your difficulty. If your Samsung is crashed or your problem cannot be solved with the above two, a third-party recovery tool such as DroidKit can be helpful in retrieving files from internal storage without hassle.
    Q2: How to Recover Data from a Samsung Phone with a Broken Screen Free?
    If your Samsung phone has a broken screen but is still functional, you can recover your data for free using a USB Cable by following the steps below:
    • Connect your Samsung phone to a computer via USB.
    • If the phone is recognized and USB file transfer is enabled, you can manually copy files.
    • If the screen is unresponsive but still visible, use a USB OTG adapter with a mouse to navigate.
    Q3: How Can I Retrieve Data from a Broken Phone That Won’t Turn On?
    If your broken phone won’t turn on, you can try several methods to retrieve your data. SD card and phone backup would also be your solution. Also, DroidKit can help you to recover complete data in easy steps without backup and USB debugging.
    This article has clearly stated the best methods to recover data from phone that won’t turn on! You can follow any of the methods above but make sure to follow the step-by-step guide appropriately so that you won’t be stuck in between. And we highly recommend you try DroidKit for free first, because it supports all system-crashed Samsung devices and can recover all data types for you. Also, don’t forget to try fixing your Android device by following the fixes that won’t cause data loss!
