Have you ever experienced the black screen of death issue while using your device? If not sure how to get rid of this problem effectively, read this post to learn some possible options and fix the Samsung black screen and recover data from it.
Is there something wrong with your Samsung Galaxy’s screen? Have you found yourself in a situation where your Samsung phone isn’t responding, and the screen all of a sudden turned off black? Well, you are not solo; there are many people facing the Samsung Galaxy black screen issues.
You may be afraid of losing your contacts, messages, images, or any other data in such a situation. There are inevitable mishaps that happen without warning and leave you feeling miserable. This informative article will show you how to recover data from a Samsung phone with a black screen.
Further Reading: Broken Samsung Data Recovery >
When your phone is black screen of death, there are some different situations that happen. For example, Samsung phone is on but the screen is black, which means the phone will ring and get notifications but you can not react. Or, the phone totally can not interact with your finger and you can not get any ring notifications neither. Then, what causes these black screen of death?
If you already checked your battery life and phone memory, black screen is usually caused by software problems or hardware issues. It firstly means some serious system errors happen caused by the operating software, such as a custom OS, or after your phone suffered extreme weather, etc. Your phone or tablet is black screen because of software issues. Secondly, if phones can ring or get notifications but the display is not working, it means there are hardware problems happen.
Can a black screen on a Samsung be fixed? As we mention above, if your Samsung phone is working but the screen is black, you just need to replace a new screen. If not, you can first try to fix the black screen issue by yourself. But for data safe, first you need to extract data from it when your Samsung screen goes black. Check the methods below to recover data from black screen Samsung:
First, we’d like to recommend to you DroidKit – a complete Android solution toolkit. You can recover data from the black screen device with its function – broken data extraction. It supports you to get back 13 types of essential data, including photos, WhatsApp & Line attachments, messages, contacts, videos, audio, call Logs, etc. Despite a black screen, you can also access phone data when it’s frozen, phone bricked, touch screen not working, etc.
DroidKit will help you copy files from black screen phone to computer or another phone, and without USB debugging:
Now, you can follow the steps below to recover data from a black screen Samsung tablet or device:
Step 1. Launch the software and connect your device > Go to Data Extractor > Choose From System Crashed Device.
Select Extract from System Crashed Device
Step 2. Choose what data types you want to recover or you can select all. Here we take photos as an example.
Select Photos and Start
Step 3. Then DroidKit will match the PDA code for your device > Click Download Firmware. If not, you need to enter recovery mode first and continue.
Enter PDA Code
Step 4. After the firmware package downloaded, follow the on-screen instruction to put your device into Download mode. Wait a minute, you will get a system fixed successfully page, which means Samsung black screen was fixed. And click Complete button.
Crashed System Fixed Successfully
Step 5. Confirm your device is connected again and continue. DroidKit will scan your phone and give you all the photos. You can click To Device or To PC according to your needs.
Select the Data to Recover from Crashed Phone
If you see Black Screen on your Samsung device and are looking for ways to recover data, no worries. You can always get your lost data using Google Account.
Below are the steps on how to do the same.
Manage Google Backup
The next solution to extract data is using an SD card, but this is only possible when your SD card is removable. To do so, follow the steps below.
If your SD is non-removable, then you can use any third-party tool to recover your data from Samsung devices.
Also Read: How to Recover Files from Formatted SD Card Android >
To retrieve data from a black screen Samsung phone, you can manually transfer the data to your computer using a USB connection.
Step1. Use a USB data cable to connect your phone to the computer. Once the computer recognizes the phone, unlock the device (if possible) and enable file transfer mode via the notification that appears. This option, called File Transfer or MTP, allows the computer to access your phone’s internal storage.
Step2. Open the File Explorer on your computer, find the connected Samsung device, and browse its internal storage or SD card. From here, navigate to a specific folder containing photos, videos, or other important files.
Step3. Select the required files and copy them to a folder on your computer.
This simple method can help you recover data if your screen just stops working. Once done, safely eject the device and remove the USB cable.
If your Samsung phone is stuck on the black screen of death, your Android OS will die. The question now is, How can I fix the black screen of death on my Samsung smartphone? So, don’t be concerned; simply scroll down to discover the solutions to this problem.
Wiping the cache partition is a popular way to resolve the Samsung Black Screen of Death problem. To do this, follow the steps below:
Wipe Cache Partition
Finally, you can determine whether your phone can function normally or not. If the response is negative, proceed to the next method.
If you have installed an APP on your Samsung device and it repeatedly crashes, this could be the cause of the Samsung Black Screen of Death. To resolve this issue, you need to uninstall this APP by booting into Safe Mode.
Follow the steps to uninstall incompatible applications.
If the above fixes do not work for you, you will need to factory reset your Android device. Please refer to the next method.
When you encounter the Samsung black screen of death issues, the above solutions will hopefully help you recover your essential data. And DroidKit is designed to help Android users out of various phone disasters, including black screen, stuck Samsung logo, keep restarting, phone locked when you forgot password or FRP information. etc. Why not download it and recover data from the black screen with ease. Besides, this article also introduces several methods for resolving black screen on Android phone concerns. You can try them to get rid of this issue in no time!
