You may need to perform a factory reset on your Android phone to enhance its performance or clear unexpected data. How to recover data after factory reset? Here, we offer 5 ways to help you recover data after factory reset, with or without backup.
Free download DroidKit to recover data after factory reset Android without backup or recover data after factory reset Android without root.
How do I recover photos after factory reset without backup?
I had to do a rest of my phone cause it wasn’t working properly but I didn’t realize it would get rid of my stuff also I didn’t have anything backed up can anyone help with this?
You may also choose factory reset your phones to fix abnormal conditions. A factory reset, sometimes known as a hard reset would remove personal data, settings, and changes from your mobile device, returning it to the same condition that it had when it left the factory.
Factory Reset Android Phone
Normally, there are many signs given by your Android phone to perform a factory reset.
These are some of the situations that you will never expect to arrive. However, since you may lose your important data after a factory reset, you will need to recover data after factory reset. And sometimes, you may even need to recover data after factory resetting Android without backup.
In this guide, we will mention proven methods to help you recover data after factory resetting Android without backup or recover data after factory reset Android without root. Keep reading and figure out the detailed steps.
Further Reading: Recover Deleted Messages With/Without Samsung Backup >
The answer is YES. You can recover data after factory reset without backup since normally, a deletion or factory resetting will not completely erase data on your Android phone. When your Android phone is commanded to delete something, it will be marked as ‘deleted’, which indicates the data could be overwritten in this case. Nevertheless, the ‘deleted’ data still exists on your phone.
For this reason, it could be quite easy if you haven’t put any newly generated data in your Android phone. You can make it by taking the detailed steps in Method 1, which is also workable for users who haven’t backed up yet. On the other hand, if you have established a backup already, you can also restore data from it.
If you perform a factory reset to wipe Android phone before selling, you are suggested to import some unimportant photos, contacts, music, or other data to overwrite the old ones several times. This is because the more data you overwrote, the fewer data other users could recover.
Here, we collect 5 proven ways to help you recover data after factory reset in this guide. Considering the specific demands, you can use one or some of these methods to get back your important data after a factory reset.
Here we have a collection of solutions to recover date after factory reset with or without backup, you can use professional Android Data recovery tool-DroidKit to restore data without backup, or you can use Google Backup, Official Backup
As many Android users don’t back up their Android devices before performing a factory reset, in this situation, they need an Android data recovery tool, which is DroidKit Android Data Recovery. When it comes to restore data after factory reset android without backup, DroidKit doesn’t require a backup. You can recover data after factory reset Android without root via its ‘Quick Recovery’ mode and ‘Deep Recovery’ mode can give you a more comprehensive scan on your Android phone.
It is also one of the easiest and safest ways to recover Android data after factory reset. All you need is a computer and your Android device. As a professional Android data recovery tool, DroidKit can easily scan, preview, and selectively recover data after factory reset Android without root, as there are some disadvantages of rooting an Android phone. Despite this, DroidKit also has many other outstanding features when it comes to retrieving data from Android devices. Now, free download DroidKit and enjoy its “Quick Recovery from Device” feature to recover deleted data after factory reset with simple clicks!
Step 1. Open DroidKit on your computer > Hit Quick Recovery from Device on the welcome page.
Choose Quick Recovery from Device from Recover Lost Data
Step 2. You will see several types of data that the program supports recovering. Select all or some of them to get started.
Select the Data Type that You Want to Recover
Step 3. Follow the on-screen instructions to connect your Android device via a USB cable.
Connect your Samsung Phone and Continue
Step 4. Here, we take photos as an example. You can preview and recover photos after factory reset from Android To Device or To PC.
Preview and Select Deleted Photos to Retrieve
Step 5. When the restoring process finishes, you will see the Recovered Successfully interface as below.
Quick Recovery from Device Successfully
Remember to stop using Android device after factory reset in case newly generated data would overwrite the “deleted” data. In that case, you should go back to the first step to recover data after factory reset via the “Deep Recovery from Device” mode.
You can also refer to the video below to know the details about recovering data from factory reset Android.
The Google backup data can also play a role in recovering data after a factory reset. If you are one of the users who back up data regularly, you can easily find the lost data according to your needs.
View Google Backup and Restore
Suppose you’ve set up a Google account on your Android phone and have made synchronization enabled for all data, you can recover data by setting up the Google account once again on your Android device. Your lost Android data will be restored while carrying on the setup process:
As you can see, the official restoring steps don’t support previewing and selecting data you’d like to recover from Google account. Again, DroidKit allows you to recover contacts, photos, calendars, messages, call logs, and other important data from your Google account.
Click Contacts under the Google Account Box
Despite some well-known backup tools, there are also specific Cloud tools developed by Android manufacturers. This built-in feature can well match your Android model and more importantly, the auto-backup feature is enabled by default when you set up the correspondent account. Therefore, you can seek to find back lost data from your Android brand’s official backup.
For Samsung devices, you can backup & restore via a Samsung account.
Restore Data from Samsung Cloud
For Huawei devices, you can backup & restore via Huawei Cloud backup.
Restore Data from Huawei Cloud
If you are still using an SD card to save data on your Android phone, you can also try to recover data after a factory reset from the SD card. DroidKit also develops the correspondent feature to help Android users who want to see and recover data from SD cards.
Recover Data After Factory Reset From SD Card
Since retrieved data can only be restored to PC instead of the device itself considering the SD Card principles, you can import data from your computer to your Android device via a USB cable.
Guess you may make a proper backup, then recovering your photos or data can be really easy.
Step1: Open your phone’s “Settings” > “Backup and restore / reset” > “Local backups”.
Check Local Backups
Step 2: Check the files you want to restore.
Step 3: Click “Restore” to recover your deleted items.
As mentioned at the beginning of the post, factory reset will not permanently wipe all data on your Android phone. Some professional Android data recovery tools such as DroidKit can help you restore data after factory reset Android without backup or root. As it is dangerous to expose your private data to others, you can import some unimportant data to overwrite the data before selling.
