If you accidentally delete an important SMS, it’s good to know how to recover it. The most appropriate reaction in this situation is to use some of the best SMS recovery apps for Android and instantly bring back all your lost messages without any part of the content missing.
Can SMS be recovered? The answer is YES. Free download DroidKit to recover SMS messages. No technical skills are required.
SMS is used far less than before, but it is a great option to stay in touch with parents, friends, and co-workers and still has a role in our daily lives. Sometimes you can accidentally delete a message that contains significant information, and you want to restore it immediately. It’s good to know that SMS is not permanently erased from Android, as all deleted messages are stored deep in the phone memory and can be saved with the right software tools.
So, you may wonder how can I recover deleted SMS from my Android phone? Is there a free message recovery app to recover old text messages? In the next paragraphs, we will introduce you to 5 of the best SMS recovery apps for Android. Let’s see how they work.
Also Read: Best Recovery App for Android without Root >
DroidKit, as one of the best Android data recovery tools to recover deleted text messages Android, can restore all your deleted SMS messages, even if you don’t have a backup. This is a great feature because users often forget to perform a regular backup, and only become aware of the importance of that after some of the content is lost.
The Recover Lost Data function has two options for recovering deleted SMS with DroidKit: Quick recovery mode and Deep recovery mode. Quick Recovery instantly scans your Android and doesn’t require rooting the device. Processes will be finished in a minute and your messages will reappear. Deep Recovery, as the name implies, can search for data in deep memory, and you need to take a few steps to retrieve erased content. This procedure is not too complicated.
Step 1. Download the latest version of DroidKit on your computer > Choose Deep Recovery > Deep Recovery from Device.
Choose Deep Recovery from Device from Recover Lost Data
Step 2. Select Messages to san deeply from your Android phone.
Select the Data Type You Need to Recover
Step 3. Connect with your Android Phone.
Connect Your Android Device to the Computer
Step 4. DroidKit will start checking the root status of your device. To finish Deep Recovery, it is necessary to root the device first. If your Android Phone is unrooted, please click the “Root Now” button. After rooting your device, DroidKit will start scanning your Android phone to find the deleted SMS messages.
Check Root Status
Step 5. Choose the messages you want to recover to your Android device, and click the To Device button.
Select Messages You Want
Dr.Fone is most commonly used for resolving problems of deleted data, including SMS messages. It is an effective solution with which you can get back the lost messages, without any of them getting damaged in the process.
Connecting your phone to a computer with a USB cable enables you to access the app’s interface where you can gain access to all messages stored on your device. You can preview messages, and choose the ones you want to recover. That is convenient because you don’t have to sift through hundreds of deleted messages you don’t want to be returned to the phone. Also, Dr. Fone’s list of supported mobile devices is extensive and you can select your model from the list before starting the recovery.
Dr.Fone – Data Recovery
Pros:
Cons:
One more solution on the list of the best SMS recovery app for Android is EaseUs MobiSaver. Depending on your needs, you can choose between the Free and Business version. The free app version is perfectly equipped to help you to restore lost SMS.
Downloading this app to your computer will enable you to initiate the SMS recovery process in just a few clicks. Advanced features allow you to filter the scan results via filename or date, while the messages you want to keep will be saved to the Android SD card in .txt or .html format. In order to scan the entire phone memory and recover other types of content (i.e. music or videos), you might need to upgrade to the Business version.
EaseUS MobiSaver Screenshot
Pros:
Cons:
MyJad Android Data Recovery has a huge range of tasks it can successfully perform, including recovery of SMS. It works just as expected with no changes to the content or compatibility issues. It supports many brands of Android phones so you can easily retrieve any SMS you want, even if you own a device that’s a couple of years old. Also, it can be a great backup solution for all of your mobile content.
The app interface is simple and fast, but you need to be patient during the installation process since it may take some time to complete. The rest of the recovery procedure is quite straightforward – just make sure to connect the mobile phone with PC and shut down any other Android management software you might have on your phone.
Best Android Data Recovery Software – MyJad
Pros:
Cons:
Except for the above SMS recovery from PC software, there are also some SMS recovery app for mobile. One of them is SMS Backup & Restore, which allows you to back up SMS and MMS messages currently on your Android device. Therefore, you can use SMS Backup & Restore app to recover deleted text messages from the existing backup.
Pros:
Cons:
Apps |
Performance |
Success rate |
Price |
Rating |
DroidKit | Best SMS recovery app, supported 30+ data type, 100% safe to use |
99.9% |
35.99$/Year |
4.9/5 |
Dr.Fone | User-friendly interface; expensive |
95% |
99.95$/year |
4.3/5 |
EaseUs MobiSaver | Support many Android devices, Complicated interface |
94% |
$39.95/lifetime |
4.4/5 |
MyJad Android Data Recovery | Easy to use, Needs to root Android |
95% |
$49.95/lifetime |
4.2/5 |
SMS Backup & Restore | Free, Many limitations |
95% |
Free |
4.3/5 |
When you accidentally deleted text messages from your phone, they are not permanently deleted right away. Deleted messages will be temporarily stored in your internal storage, which can only be accessed from the folder and can not be viewed easily.
Therefore, you can only restore the whole message from your Google backup with a factory reset. Besides, the third-party recovery tool is a solution to recover deleted messages if not backed up.
We often keep the SMS messages that contain important information or have sentimental value and the thought of losing such a message is never pleasant. However, you shouldn’t worry needlessly in case you accidentally deleted an SMS, since you can use some of the best SMS recovery apps to retrieve them. And DroidKit is the first choice. Just download it and have a try!
DroidKit is a powerful Android data recovery tool. It will help you recover all the lost data of your Android device, such as SMS messages in a couple of minutes.
